Question about Motorola Mobility V551
My cell phone wont display anything
Okay here are the symptoms: 1. last time my phone was displaying it was already frozen 2. i closed it and when i opened it again there's no display 3. only the keyboard lights up, blinks then its gone 4 end point i cant open my phone totally
I had the same problem with an old razor. I ended up having to discard the phone and got a v557. But these were the steps I took: 1. Took out the battery for about 5 min. I called tech support and they said that most problems are due to software errors and can be fixed by taking out the battery then reinserting it. 2. I reinserted the battery and booted it up. The keyboard lit up and the welcome screen played. After that, it shut off. 3. I charged the battery completely and tried to reboot. Same thing happened. If none of these work, it's probably the battery's fault or the phone's fault. Either way, you should get a new phone or contact a professional fixman. Hope this helps.
Posted on Jul 27, 2007
SOURCE:
The screen is frozen won't do anything
Search Results
    2 Easy Ways to Fix a Frozen Mobile Phone (with Pictures)
    www.wikihow.com > ... > Phones and Gadgets > Cell Phones
    wikiHowHow to Fix a Frozen Mobile Phone. ... If your phone isn't responding to your Power button or screen taps, you may be able to force the device to restart.
    How do I force my phone to reboot or restart when screen is ...
    https://motorola-global-en-uk.custhelp.com/app/answers/detail/a.../72260
    How do I force my phone to reboot or restart when screen is frozen or phone is ... Note: If your phone displays "AP Fastboot Flash Mode" (CLICK HERE to view ...
    iPhrozen? How to reset an unresponsive iPhone - WhistleOut
    www.whistleout.com > Cell Phones > Cell Phone Guides
    Apr 28, 2015 - Don't freak out, there's probably an easy fix if your phone has frozen. First thing's first ... Swipe it upwards off the screen and it should close.
    How To Fix Samsung Galaxy Phone Problems - Gazelle The ...
    https://www.gazelle.com/.../how-to-fix-samsung-galaxy-phone-pr...
    Gazelle
Jan 26, 2016 | Cell Phones
Tip
Nokia Tips
`Your Nokia cell phone can be programmed to pick up radar speed traps, when programmed your cell phone picks up the radar and alerts you on the message alert tone. 1. Enter your menu 2. Select settings 3. Select security settings 4. Select closed user group 5. Select on 6. Enter 00000 7. Press ok 8. Clear back to normal, within a few seconds your phone will display a radar sign with five zero's next to it. It is now activated. Unfortunately only Nokia phones have this function. Cell info display needs to be de-activated. Settings -> Phone Settings -> Cell Info display Each time you turn off your phone, or even each time you loose contact with your carrier, you´ll have to activate it again... It is done by steps 1 through 5, but the number (00000) will be already on the field as default. If you put the number 500 in the closed user group, and you go out of a store with detection ports thy will go off. Firmware version: *#0000# *#51x0# or *#9999# View Serial No., Date Made, Programming Date, Repaired: *#92772689# Thanks to Ben-Dov for this code IMEI (International Mobile Equipment Identity) Code: *#06# Enhanced Full Rate (EFR): *3370# to activate EFR. Makes calls sound better, but decreases battery life by about 5%. #3370# to deactivate EFR Half Rate Mode (HFR): *4720# to activate HFR. Decreases call quality but increases battery life by about 30%. #4270# to deactivate HFR. Default Security Code: 12345 Warranty Code: *#92702689# [*#war0anty#] asks warranty code. You can then type a number of codes (Thanks to Mike Pfaff for these codes): 6232 - Display date of manufacture 7332 - Display date of last repair 7832 - Display purchasing date 9268 - Display serial number 37832 - Set purchasing date to MMYY 87267 - Confirm Transfer, Related to firmware upgrades #746025625# says SIM CLOCK STOP ALLOWED or similar, depending on your SIM card. Newer SIMs have a feature called 'clock stopping' that allows the phone to save energy -- it is a kind of sleep mode for SIM cards. Not all versions of software support this. You cannot turn the SIM clock on and off, the phone will do it automatically if the SIM supports clock stopping.
on May 20, 2010 | Cell Phones
Tip
Nokia
1. Enter your menu
2. Select settings
5. Select on
6. Enter 00000
7. Press ok
Firmware version:
*#0000#
*#51x0# or
*#9999#
*#92772689#
*#06#
12345
Warranty Code:
on Dec 09, 2009 | Cell Phones
Describe your imei register code Problem. My imei 359542017228279 plz sent register code. My phone number:9095151085
*#92702689# - takes you to a secret menu where you may find some of the information below:
1. Displays Serial Number.
2. Displays the Month and Year of Manufacture
3. Displays (if there) the date where the phone was purchased (MMYY)
4. Displays the date of the last repair - if found (0000)
5. Shows life timer of phone (time passes since last start)
Feb 21, 2011 | Nokia 7610
Want to know the purchasing date for nokia 1209 - IME # 351507040352454
Feb 14, 2011 | Nokia E71 Smartphone
Please help.,.,i need my license key.,., imie 35227201819836.,., thanks
insert code :
and
View the firmware version of the phone
Dial using the keypad: * # 0000 # - the version number displayed on the display.
like this example :
V 5.16
22-06-99
NSM-1
V 5.16 - software version
22-06-99 - date
NSM-1 - The hardware (model)
View IMEI
Dial using the keypad: * # 06 # - IMEI number is displayed on the display.
i hope this helpful
thank you for using fixya
Feb 07, 2011 | Nokia 6600
Knowing the date of Manufacture, version, serial number.
please enter the below number
*#92702689#
It gives the following informations:
Jul 22, 2010 | Nokia 6020 Cellular Phone
HOW TO FIND OUT MAKE AND MODEL OF SONY ERICSSON CELLULOR PHONE MODEL W200i
you will have a special menu in sony ericsson by typing below sequence in your phone. you wont see anything on display while pressing keys, so keep doing what is written, you need to try 2-3 times to properly get it done.
you need to press joystick in this directions:
1 time Right
1 time *
2 time Left
1 time *
1 time Left
1 time *
Jan 01, 2009 | Sony Ericsson W200i Cellular Phone
Phone won't turn on properly
hi Miss_Pink03
most likely those symptoms appears when the phone Flesx cable is faulty
What is the phone flex cable??
its the electronic stuff that connects the keypad to the Main and Mini Display
u most replace it and its not an easy task though
plz do rate this post
Oct 07, 2008 | Nokia 7390 Cellular Phone
Motorola Mobility V551 Logo
102 people viewed this question
Top Motorola Mobility Cell Phones Experts
D. E. Hev
vince
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
