Question about Dewalt d55151 factory reconditioned emglo heavy - duty 2.5hp 4 gallon Electric hand carry compressor
Engine shuts off when max PSI is Reached, instead of cutting out and still running? does anyone have a solution.
  • JODY BRIDGERS May 11, 2010
    DOES IT HAVE AN ELECTRIC MOTOR OR IS IT GASOLINE
  • Dean
    Dean May 11, 2010
    It sounds like this is what it is supposed to do! When the tank pressure falls below 80 PSI or so, does the motor restart again to fill the tank back to max PSI?
  • 98 Answers
Dont understand the question , does the engine shut off after p-max is met , or does it continue to run , if it continues to run then you have a pressure switch problem
Posted on Jul 21, 2009
When max pressure reached engine dies instead of idle down
Has Pressure Switch Issues - About Air Compressors
www.about-air-compressors.com/has-pressure-switch-issues.html
Many times folks think that they have a pressure switch problem since air leaks out the ... The pressure switch does not kick off when the compressor has reached itsmaximum pressure. ... compressor sits humming and trying to turn the motor insteadof cutting out. It is a ... I have an old, about 20 year old, Ingersoll-rand T21.Missing: idle
[PDF]21 Front St. - Celtic Distributors Ltd
www.celticdistributors.com/content/Celtic/.../BasicCompressorTraining.p...
The air compressor motor and/or engine will get hot while in operation. .... enters thru the intake ?lter and the intake valve on the down stroke of the piston. .... My gas unit builds pressure but instead of idling the engine dies? 0 Check ... most single stage compressors only reach maximum pressure of 125 to 135 PSI. A slight.
[PDF]ALTRONIC GAS ENGINE GOVERNOR OPERATING ...
www.altronicinc.com/pdf/engine-controls/govinstall.pdf
Dec 16, 2015 | Ingersoll Rand SS3J5.5GH Wb Ir Portable...
Ive got a 1997 cavalier it will start but quickly dies out ive got fire to my plugs and fuel to the injectures ive just replaced the ignition switch is there somkind of a security
You need a new fuel pump relay. The engine fires up and runs off the oil pressure switch untill the oil pressure PSI is reached at normal operating conditions. When the oil pressure reaches its operating PSI the PCM or engines computer will shut off that circuit and turns on the fuel pump relay to run the fuel pump untill you shut the engine off
Apr 19, 2010 | 1997 Chevrolet Cavalier
Vehicle chokes, sputters, and then shuts off
Start with the simple and replace the fuel filter. The fuel filter may have reached the end of it's life time and is dirty causing the issues you have. The worst is the fuel pump it self has gone bad and needs to be replaced, the fuel pump should be producing 62 to 65 PSI when the engine is started and should drop no more then 5 PSI when the engine is running. You can check the fuel pressure at the shredder valve with a fuel pressure gauge. Good luck and keep me posted, be glad to help get your Yukon running 100% again.
Nov 16, 2009 | 2002 GMC Denali
I've messed with the settings on the three springs inside the mdr21 pressure switch and don't know how to adjust them correctly and which does what? I'm getting max pressure at 130psi and blow off to...
Normally you can find the setting instructions on the underside of the switch cover.
In almost all compressor switches you will find two adjustment screws. One is for the "Cut-in/Cut-out" or "Cut-on/Cut-off" psi. The other for "Cut-out" psi only. If there is no label the easiest way to tell the difference is by the springs. The "Cut-in/Cut-out" is the larger of the two springs.
Start by turning the smaller or "Cut-out" screw counter-clockwise. This will decrease the Cut-out psi. I would say to back it off 1 1/2 or 2 turns. Now run the compressor and check where your max psi is. Your target is 105psi if your present "Cut-in" psi is 80psi. Once you have that setting at 105psi, move to the larger screw or "Cut-in/Cut-out" adjustment. Turn the screw clock-wise making 1/4 turns adjustment until you reach the 100/125 psi.
By blow off I assume you mean the unloader valve. There really isn't any setting for the unloader because it's built in to the valve itself.
Since there are some variations for this switch please let me know and I'll explain how to make the adjustments for your type.
Or if you are unclear about anything here just let me know and I will be happy to help you out.
Hope this helps.
Nov 13, 2009 | Hitachi EC12 Portable Electric 2hp Air...
John Deere 3300 PSi pressure washer shutting off while in use.Everything appears fine Oil level,Gal level,Air cleaner ok etc.. May run 2 minutes or 12 minutes then spudders a bit then Bang "Off" as if i...
John Deere will replace the cap for free; they acknowledge the vendor who supplied Briggs & Stratton gas caps provided faulty caps. Call 1-888-228-3068 then 1 (English), 2, 1 and a technician will ask you for model number and Serial Number (which they need to replace the cap). Don't drill a hole in your cap: debris will find a way into the gas tank and end up possibly fouling the engine. Bob from NJ
Nov 03, 2009 | Dewalt 3800 PSI Pressure Washer
Hitachi twin stack problem.
You stated that the compressor started up fine. I'll assume it reached it's max psi then cut out. Then upon reaching it's cut-in psi the motor ran slowly for a few seconds, then kicked off. I also assume you mean check valve when you refer to the non return valve.
If this sounds about right then. The first thing I would do is bleed out all the air from both the tank and the pump supply line leading from the pump head to the tank's check valve. You can do this by simply loosening the fitting that attaches the line at the head or the check valve. Once done try running the compressor again.
The purpose of this is to check the unloader valve. This valve bleeds off the pressure that remains in the compression cylinder and the supply line up to the check valve. When functioning normaly it will bleed off this pressure once the motor shuts off. If it is not working correctly then when your compressor starts back up (once it is already been filled) the piston will be working against a psi close to the max psi.
If the problem reoccurs only after the compressor has reached it's max psi, then the unloader valve is most likely the problem. If however it will not start up at all even after a complete bleed then it has to be something internal to the pump and\or motor.
Please try this and let me know (or repost) your findings.
If it's the unloader valve I should be able to explain how to repair this valve.
Good luck.
Aug 11, 2009 | Hitachi EC119SA Twin-Stack Air Compressor...
Compressor shuts off before reaching max pressure
Yes,but if the max is 125 you don't want to increase it above 110 and set off the pressure relief valve.
Jul 21, 2009 | Craftsman 1 Hp, 4 Gal. Air Compressor
1998 900S turbo overboost
the turbo waste gate has vacuum to it regulated to make it open at a specific psi... try turbo city in anaheim,Ca for more answers to aftermarket stuff
Jan 13, 2009 | 1998 Saab 900
Dewalt d55151 factory reconditioned emglo heavy - duty 2.5hp 4 gallon Electric hand carry compressor Logo
183 people viewed this question
Top Dewalt Air Tools & Compressors Experts
John Trevino
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Dewalt Air Tool and Compressor Expert? Answer questions, earn points and help others
