Question about Acer Aspire 5315 Notebook
Can not log on
My Acer is new and I was having trouble getting around. I'm not sure what I did, but I had a choose of what I wanted to do ie shut down, log off, etc. I chose to log off, unfortunately I can not log back on. I never made a password.(I thought I was logging out of current program-AOL) I am running Vista. Is there a way to get into my computer? I tried the new password option, however I am getting a mesage telling me to use a password disk or flashdrive memory something or other. I dont have either. I do not want to buy a password program because I heard they don't work. what are my options?
  • aharty1204 Jan 29, 2009
    thanks for getting back to me so quickly. I will pass this advise over to my IT guy:) I am definately going to make sure I have a password recovery disk and my boyfriend has made sure to do this for himself just in case he ever comes across this problem. I'll also get back to you with our results.
  • 53 Answers
If you never entered a password it won't ask you for one when you log in. If you have forgotten the password of your user you can create a livecd from the following iso. Use the newly created disk to boot your machine you might have to set you bios to boot from the cd/dvd drive first or hit F8 to enter boot list menu watch your screen at startup to see what keys get you into the bios F2 and the boot menu. Then boot from the disc and crack your password. You will need another computer with a cd/dvd burner and a burner program. I recommend ImgBurn. Good Luck
PS I recommend making a password recovery disk once you get back in.
Posted on Jan 29, 2009
  • Celenous Jan 29, 2009
    Please rate the solution I provided. Thanks. Unfortunately Microsoft has made it difficult to fix this issue with re-installing Vista or cracking your lost password.
I have an acer aspire 3610. I just replaces the hard drive with a new one. Now when I try to install windows on the new hard drive it will go as far as 18% formatted and then will completely shut down,...
Hello
When you do the setup using the windows disc,choose the delete partition option.
If this is not a choice then choose the create partition option.Then format using the quick option.Once done run setup again choosing c: drive
Also make sure the windows disc is clean no smudges or deep scratches,a little windex and a paper towell will do.
Last,be sure the cooling fans are clean and running,the setup program uses alot of power and can create heat.So i want to make sure your not shuting down on high heat.A can of air or a vacum will do.
Dec 16, 2010 | Acer Aspire 3610 Notebook
Have Desktop & Laptop that use the same Router & Modeum to access the Internet with no trouble, However I cannot get the 2 computers to talk to each other,ie, cannot view file or transfer file from...
Hi, If you want to share files on both computers, you need to check the shared folders option on both version of the operating system. You can right-click on the folder you want to share then choose properties and choose shared option to check both settings. On windows 7, you have to go to Network and Sharing Center to check the setting on your option. you have to to turn on the sharing options and also if there is a password on both computer when you log on , that would be the username and password you need to share the documents.
Thank you for using Fixya, your recommendation is highly appreciated for the free support.
Oct 09, 2010 | Acer Computers & Internet
The log in screen is locked and i forgot my password
If you have forgot the login password, I would suggest a full system recovery. Inorder to do so, turn Off the computer. Now, when you turn ON the computer make sure you press the Alt key and tap on F10 key ie ALT+F10. It will go to the factory recovery screen. Choose full system restore or recovery and follow onscreen instruction.
Thanks and regards,
Anil.B.R
Sep 25, 2010 | Acer Aspire 5610-4648 Notebook
Windows Vista Home Basic
If it does indeed go to the Desktop, then you have joined a very large group of patient people whom have changed there XP to Vista, myself included.This is an inherant charitoristic of Vista.
Sep 10, 2009 | Acer Aspire 5315 Notebook
My laptop boots and reboots on its own... When I login it logs the user off
Hello ! i want you to try something re install the operating program on this computer   .the operating program might be corrupted  . thats why its behaving that way  .also run an anti virus  to check the hard disk for program infections .ie before X P installation .
best of luck
Aug 04, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
Installing RHEL 5 on ACER ASPIRE 4530
1) Get SATA drivers for Windows (whatever flavour you use)
For you who want to get driver AHCI for Acer 4530, the driver can be download here:
http://rapidshare.com/files/196616727/Driver_AHCI_Acer_4530_-_Windows_XP.rar
2) Control Panel, Add New Hardware.
3) Yes, already connected, browse to the bottom, hit “add a new device”
4) No, point it to the directory of your SATA drivers
5) Choose your driver from the list that returns. (Mine was the nVidia SATA controller)
6) Uninstall other standard IDE controllers (Not Primary nor Secondary)
7) Reboot and enter your BIOS
8) Change to AHCI mode
9) Boot to Windows… , if you success you will not meet the Blue Screen and Windows will install and find the driver automatically.
10) Windows wants to reboot. Do that.
11) Go to Device Manager and then uninstall the AHCI controller that you installed (there will be two or more now, but must Uninstall the one with the exclamation mark)
12) Success!
Jun 04, 2009 | Acer Aspire 4530-5889 Notebook PC
Microsoft Internet Explorer
Well I'd consider this kind of a browser hijack.
You can download it here:
Hijackthis
I'm not sure how the new version is but the concept should be the same. Look for the www.microsoft.com/windows/downloads/ie/getitnow.mspx
entry and then have the program remove it.
You usually have to restart the browser and / or the computer for the settings to take effect.
Let me know if you have any trouble.
Best of luck!
Feb 27, 2009 | Computers & Internet
Hi, my screensaver acer aspire one doesn't work. can you help ?
To set up your screensaver, right click on your desktop and choose Properties. Choose the Screen Saver tab. In the drop down menu for Screen saver, make sure something is selected instead of (None). Next click the Preview and it will give you a glimpse of what the screensaver you chose will look like. Move the mouse to get out of it and select apply if you like that one or choose a different one.
Jan 14, 2009 | Acer Aspire One PC Notebook
Password forgotten
Unfortunately, there are only 2 ways around this. Reinstallation of te OS will wipe out everything but allow a new account to be created. If this is the case, create 2 accounts both with admin priveleges for future scenarios. Restore her important files from her backups ( she did backup on a regular basis, didn't she?).
If there are no backups and she doesn't want to lose what's on there, Google "password recovery software" and choose from the multitude of hits that are returned. I can't recommend any of them as I have never had to use them before.
Thanks for using Fixya.com. Keep us in mind for future needs and please rate this tip accordingly.
Jan 10, 2009 | Acer Aspire 5315 Notebook
Shutdown problems
Windows does not shut down. Windows 95/98/ME may not Shut Down successfully or may lockup / freeze because ... may be difficult to trouble shoot or determine where the problem exists.
E-mail CHID: 5608 WHILE I SHUTDOWN THE COMPUTER IT WILL TAKE LONG TIME TO SHUTDOWM PROPERLY.
Read and follow instructions.Good Luck, Please dont for get to Vote/Thank You.
Dec 22, 2007 | Acer Aspire 3680 Laptop
Acer Aspire 5315 Notebook Logo
89 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
