Question about Maytag PYE2300AY Electric Dryer
Is there an adapter for a 4-prong plug to fit a 3-prong 220
Have a 4-prong electrical plug, and is there an adapter to make it fit a 3-prong 200 outlet in the wall? I know the dryer plug can be changed, but is it safe for my 1 yr old Maytag dryer to use a 3-prong instead of a 4. If I do not have to change the plug, would prefer to use some kind of adapter between the dryer and the 220 outlet.
    Genius:
  • 2,920 Answers
They dont sell adapters like that..you have to change the cord and it wont hurt the dryer at all
Posted on Jan 29, 2009
How do i hook up a3 prong 200 and 30 amp welder 200 e^x 4500 with a four prong female plug
You can go to any Boat Marina and they sell small Pigtail adapters for doing this sort of stuff. Very common .
You can possibly buy one for your application OR buzz out one of their adapters so you can go home and wire yours accordingly
May 27, 2015 | Welding Tools
Tip
How to Adjust an Air Compressor Regulator
  • Plug the air compressor into the appropriate electrical socket. There are a few air compressors that come with a 4-prong electrical cord, but most of them will come equipped with a 3-prong electrical cord. The 3-prong electrical cord is set for use with a standard 110 outlet. The 4-prong electrical cord is generally used for 220 outlets.
  • Turn on the machine.
  • The air compressor should be fill completely to the range from 100 to over 200 per-square-inches, depending on the unit capacity.
  • The manufacture guide will inform you which tools can be used with the unit once it has reached full pressure.
  • The tool should be connected to the air hose and the air hose to the compressor.
  • To drop air pressure you should turn the regulator adjustment knob counterclockwise and to increase the air pressure you should turn it clockwise.
on Aug 27, 2008 | Campbell Hausfeld 04 Gallon Twin Stack...
I have a three prong plug washer/dryer but a 4 prong outlet need an adapter
YOU DONT ADAPT IT, U REPLACE THE RECEPTACLE OR USE THE CORRECT PRONG CORD. THE CORDS ARE NOT THAT EXPENSIVE FROM 20 TO 30 BUCKS AND EVEN CHEAPER ON LINE. IF U HAVE A NEWER HOME IT IS MANDATED BY LAW THAT YOU USE 4 PRONG CORD NOT 3 PRONG UNLESS THE HOME CAME WITH A 3 PRONG OUTLET.
Feb 16, 2014 | Frigidaire Washing Machines
The wall plug does not fit in the wall socket, it has weird prongs
If the power plug prongs are not the same as what you normally have, (assuming the prongs were not messed up, i.e. they are from a foreign country) you can get and use an adapter ... that fits the "weird prongs" on one side and has the "normal" prongs on the other side ... to plug into the outlet.
Jan 08, 2014 | Sony KV-XJ29M50 29" TV
I have a Frigidaire FAFS4473LW Steam Washer- 3 prong. I moved into a new place with a 4 prong. Do I need a 4 prong cord, or can I change the 4 prong adapter on the wall?
Hi nancy huerta...
You can change the cord or the receptical...
It will be easier to change the cord...
Purchase a four prong plug cord that will fit into your receptical, then wire your dryer for 4 wire instead of three wire use.
To see a picture and explanation of how to wire your dryer for a 4 wire plug go to the following webpage.
Please take time to rate me
http://www.selfhelpandmore.com/switch-outlet/dryer-circuit-wiring-and-hookup.php
Sep 06, 2011 | Frigidaire GLER331A Electric Dryer
Swich 4 cord to 3 cord plug in
To switch from a 4 prong to a 3 prong. First remove 4 prong cord, save screws you will need them. Look a 3 prong, it will be flat with 3 wires next to each other with metal fittings on the ends. The 2 outside which are hot wires go to the outside screws on the block, and the center which is neutral goes in the center. The only difference in the cords is the 4 prong has a ground, in new construction this is code. You don't need a ground if house is wired for a 3 prong.
Jun 15, 2010 | Roper REX4634KQ Electric Dryer
Need to change 4 prong drier plug to fit 3 prong eletric
Purchase a 3 prong dryer cord. It is simpler and safer than changing the wall outlet.
Nov 03, 2009 | Dryers
I have a maytag dryer model MD-31(Atlantis) that had a 4 prong plug when I purchased it. Without realizing, I moved into an apartment with a 3 pronged outlet. I picked up an adapter that I thought would...
Return it...and get a 3 prong dryer cord.
Place the middle conductor on the middle of the terminal block and the two outside conductors on the two outside terminals of the block. It makes no difference which way just so they are not on the middle terminal. Make sure they are tight but don't over-tighten to break the terminal block. The cord will probably cost less than the "adapter" did.
Good Luck
Sep 11, 2009 | Dryers
We have a kenmore 70 series electric dryer, and we have a three prong receptacle, but the plug is 4 prong. What type of adapter do we need?
According to the National Electrical Code, as of 2000 all newer homes are required to have a 4-prong receptacle for all 220VAC appliances. However, if your home already had a pre-existing 3 prong outlet, you shouldn't have to upgrade to a 4 prong. The following link explains:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
The main difference is how the neutral (WHITE) and green (GROUND) wires are termnated. In a 4 wire configuration, the neutral and ground are independent of each other. In a 3 wire configuration these two wires are terminated together. The instructions to convert a 4-prong appliance to a 3-prong are at the bottom of the page in the link I provided.
NOTE: If this is a new dryer, keep in mind, some REQUIRE a 4-prong plug even if you have a pre-existing 3 prong outlet. Read through your installation instructions that came with the appliance if in doubt. If this is the case, you will need to have a 4 wire outlet installed by a certified electrician.
If you have questions, please let me know. I hope this helps you.
Aug 02, 2009 | Dryers
3 prong to 4 prong cord
the bare wires are not a good thing when it comes to electric, you should either remove the plug and restrip the wires to fit or consult a pro to do this for you
Mar 06, 2009 | Maytag Neptune MDE6700A Electric Dryer
Maytag PYE2300AY Electric Dryer Logo
876 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
