Question about Xerox CopyCentre C123 Copier
Access authorization code
I need to change the access code so that people from other departments do not use my copier (copycentre c123). How can I do that? Thanks.
I want ir 400 printer asked authorization code .how to solve it this problem pls tell me sir.
Posted on Nov 21, 2011
    President:
  • 2,072 Answers
I think this is the one you want to change. If not let me know please.
  1. Press the [Log In / Out] button on the Control Panel. The Login screen will be displayed.
  2. Enter the System Administrator userID using the numeric keypad on the Control Panel, or select the [Keyboard] button on the Touch Screen to enter the userID, and then select [Save] on the Touch Screen.
  3. If necessary, enter the System Administrator password using the numeric keypad, or select the [Keyboard] button to enter the password, and then select [Save] on the Touch Screen.
    NOTE: The default userID is 11111, and the default password is x-admin (must be entered in lower case). If the userID and / or password have been forgotten, a service call must be placed.
  4. Select [Confirm] on the Touch Screen. The System Administrator Menu screen will be displayed.
  5. Select [System Settings]. The System Settings screen will be displayed.
  6. Select [System Administrator Settings]. The System Administrator Settings screen will be displayed.
  7. Select [System Administrator Login ID]. The System Administrator Login ID screen will be displayed.
  8. Select [On].
  9. Enter a new System Administrator userID in the field provided using the numeric keypad, or select [Keyboard] to use the Touch Screen keyboard.
  10. Select [Next] and re-enter the System Administrator userID in the field provided.
  11. Select [Save] to save the changes.
  12. Select [System Administrator Password]. The System Administrator Password screen will be displayed.
  13. Enter a new System Administrator password in the field provided using the numeric keypad, or select [Keyboard] to use the Touch Screen keyboard.
  14. Select [Next] and re-enter the System Administrator password in the field provided.
  15. Select [Save] to save the password.
  16. Select [Close] three times.
  17. Select [Exit].
    NOTE: Make note of the new System Administrator userID and password. If the new System Administrator userID and password are forgotten, a service call must be placed
Posted on Jan 29, 2009
How do I turn off copy-card default on xerox copycenter c123
http://www.support.xerox.com/support/copycentre-c123-c128/support/enus.html
This is how to turn off Auditron but this is the same menu as "foreign interface device" or copy card.
Jan 17, 2014 | Xerox CopyCentre C123 Copier
How do I do a password for the machine Xerox CopyCentre C128
Click on the link below and select to view the Xerox CopyCentre C128 owners manualm inside the manual will show you how to set the password
http://www.support.xerox.com/support/copycentre-c123-c128/documentation/enus.html
Dec 19, 2010 | Xerox CopyCentre C128 Black and White...
How to change toner
Open the front door. There are instructions on the label glued on the door. Toner box is a black plastic container which comes out if you grasp the handle....look at the instructions my dear!
Aug 05, 2010 | Xerox CopyCentre C123 Copier
CopyCentre C123 Copier Copier: CODE 116-331...
It may be a defective Main System Controller board 160K91660 or Hard Drive 960K01120.
There is a diagnostic which requires the Xerox Technician's Laptop to test the Hard Drive.
You might get lucky just reseating the Hard Drive.
Whit
Item, Inc.
May 17, 2010 | Xerox CopyCentre C123 Copier Copier
Code 010-327
These are the possible codes and the reason for occurence of this code in your copier
010-150, 155 -Too much or not enough paper in duplex tray
010-300 --Fuser thermistor, 010-302 --Low fuser temperature , 010-304-- Bad fuser temp, 010-308 --High fuser temperature or open thermistor, 010-310 --High fuser temperature , 010-312 --Fuser not up to temperature after energy save, 010-314 --Fuser problem , 010-320 --Fuser web finished , 010-330,327, 335, 340-- Exit switch, vertical sensor switch actuated when power is turned on
Thank you!!
May 18, 2010 | Xerox CopyCentre C123 Black and White...
My Xerox Copy centre C123 shows error code 124-315 pls help
Thats a weird one. The machine is detecting the wrong speeds.
Try this.
  1. Enter Diagnostic Mode ( UI Diagnostic Mode).
  2. At the Control Panel, press and hold the 0 key for 5 seconds, then press the Start button while still pressing the 0 key.
  3. Press buttons 6, 7, 8, and 9 on keypad and press Confirm.
  4. Press the Log In/Out button (button with Key symbol) on the Control Panel.
  5. Select System Settings.
  6. Select Common Settings.
  7. Select Maintenance/Diagnostics.
Then look at these 3 locations and see if they match, If they do not set them to match the machine speed.
  • [700-600]
  • [700-601]
  • [700-602]
Feb 11, 2010 | Xerox CopyCentre C123 Copier
Gives an error code 062-277
You will have to call in a xerox tech, it seems that one of the boards on the scanner is u\s
Apr 13, 2009 | Xerox CopyCentre C123 Black and White...
Set PDF Format as default on scanner
Yes you can,you just select the settings in the e-mail settings to scan to pdf,Wat is the make and model of the copier?
Feb 19, 2009 | Xerox CopyCentre C123 Copier
414 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
