Question about Xerox CopyCentre C123 Copier
I need to change the access code as some non authorized people are using my photocopier. How can I do that?
    President:
  • 2,072 Answers
I am answering this twice since it appeared twice, If this isnt the code you want to change let me know. I believe this is the one you are asking.
  1. Press the [Log In / Out] button on the Control Panel. The Login screen will be displayed.
  2. Enter the System Administrator userID using the numeric keypad on the Control Panel, or select the [Keyboard] button on the Touch Screen to enter the userID, and then select [Save] on the Touch Screen.
  3. If necessary, enter the System Administrator password using the numeric keypad, or select the [Keyboard] button to enter the password, and then select [Save] on the Touch Screen.
    NOTE: The default userID is 11111, and the default password is x-admin (must be entered in lower case). If the userID and / or password have been forgotten, a service call must be placed.
  4. Select [Confirm] on the Touch Screen. The System Administrator Menu screen will be displayed.
  5. Select [System Settings]. The System Settings screen will be displayed.
  6. Select [System Administrator Settings]. The System Administrator Settings screen will be displayed.
  7. Select [System Administrator Login ID]. The System Administrator Login ID screen will be displayed.
  8. Select [On].
  9. Enter a new System Administrator userID in the field provided using the numeric keypad, or select [Keyboard] to use the Touch Screen keyboard.
  10. Select [Next] and re-enter the System Administrator userID in the field provided.
  11. Select [Save] to save the changes.
  12. Select [System Administrator Password]. The System Administrator Password screen will be displayed.
  13. Enter a new System Administrator password in the field provided using the numeric keypad, or select [Keyboard] to use the Touch Screen keyboard.
  14. Select [Next] and re-enter the System Administrator password in the field provided.
  15. Select [Save] to save the password.
  16. Select [Close] three times.
  17. Select [Exit].
    NOTE: Make note of the new System Administrator userID and password. If the new System Administrator userID and password are forgotten, a service call must be placed
Posted on Jan 29, 2009
Problems picking up paper
You should get it checked by an Authorized Service Professional. If this doesn't do, check if your paper is of a compatible weight (GSM) Check your Machine for compatible paper specification and to know this you may read user manual or your machine. Then check your Paper Packet. If your paper is of a compatible weight, you should call authorized service engineer of your machine. If you find you were trying with a non-compatible type of paper, change to a compatible paper and if it still jams, something wrong with your machine is definite. Contact Authorized Service engineer in such a case.
Apr 24, 2014 | Ricoh Aficio Mp 2000 Copy Machine
A while ago I changed the default security code 12345 on my nokia 2760 and now have forgotton the changed code because I have not used it for long time. My mobile IMEI number is 353116/02/385223/6. Pls...
You will need to get a Nokia Authorized Repair Agent to upgrade the software on your phone and reset the phone back to factory default - including the security code back to default 12345.
As this is not a warranty issue, it would most likely cost you a non-warranty fee to do this.
Apr 06, 2012 | Nokia 2760 Cellular Phone
Toshiba estudio 160 Password
Code 08- 263 does not work with the e160
And I cannot find anywhere in the service manual where it specifies how to read it...
Nov 09, 2009 | Toshiba Office Equipment & Supplies
Black ink not working on Brother Intellifax 1860C
All i needed to do, after messing with it non stop, was turn it off and reboot the machine. Simple solution! Thank god!
Apr 28, 2009 | Brother IntelliFax-1860C Plain Paper...
Frequent paper jams with my Konica 2223 photocopier
I wish I could help you, You need to call for service for your copier. An authorized dealer or Konica minolta branch service in your area. You might need a fuser unit that the upper separating claws disloge or broken, exit paper detect actuator is broken or disloged, or you need a new developer.
Feb 05, 2009 | Konica Minolta DiALTA Di200 Copier
I want total codes and details of code,s about recoh ft5832
Check on copytechnet.com. There are authorized Ricoh technicians who might be able to help you with this matter.
Jan 25, 2009 | Ricoh FT5832 Copier
Hi!
TRY THIS
access service mode .by depressing STOP- 00 --STOP- 0 -1
and than select counter, select trouble count and scroll untel you see what that cod means .
get back to me if you need more help
Oct 15, 2008 | Office Equipment & Supplies
Canon IR2800
e000007 is related to the fuser..you need to change the fixing film or clean the sensor
Sep 07, 2007 | Canon imageRUNNER 600 Printer
537 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
