Question about Dell OptiPlex GX260 PC Desktop
Same as before
What is Registry Editor and where do I find it? I'm not even sure what that is..?? Thanx.
The registry editor is a tool, provided with Windows since at least version 3.1. In layman's terms, the registry is a one-stop shop for a lot of your computer's various settings, values, and information. When most programs are installed they write values to the registry called "keys". These keys are usually configuration information of various kinds and sorts, which are later referenced by programs when needed. Windows itself keeps many values in the registry for things like user preferences and privileges, hardware information, startup services, and more! You can edit the registry by clicking on the "start" button, then "run", and finally typing "regedit" into the run dialog box. A word of caution however, the registry is a vital component of a Windows operating system, and should NOT be toyed with unless all other possibilities for fixing a problem are exhausted. The registry is intended to primarily be used by your computer, and it's information often looks like just a bunch of gobbledy-gook to us. You should NEVER edit a key unless you know exactly what you are doing. You could feasibly render your computer unusable if you set a value incorrectly! A common problem with the registry is that when programs are removed, they often don't clean up after themselves very well. Old keys can begin to clog the registry with useless and erroneous information; causing general system slowdowns, errors, and other odd behavior. A registry cleaner is used to remove some of this old data. A clean registry can general speed up access and, in certain cases, improve stability. A good tool I have found for registry cleaning is PC Tools' Registry Mechanic. It can be downloaded for free here: http://www.pctools.com/registry-mechanic/download/ . Once run, Registry mechanic will preform a scan of your registry, and tell you how many items can be cleaned. With this information you can see just how much junk can build up in the registry, but to actually clean these old keys out you must buy Registry Mechanic. Other tools for registry cleaning exist, but in my experience they frequently do more harm than good. If there is anything else you would like to know concerning the registry, try Wikipedia. They have a fairly in-depth article on the registry that will perhaps fill in any areas I have not covered. http://en.wikipedia.org/wiki/Registry_Editor
Posted on Jul 27, 2007
Start > Run > type "Regedit" and click OK. Why do you need to run the registry editor?
Hi. I have a HL-DT-ST DVD-RAm GSA-H40N. Normally with no DVD in the driveletter will read DVD-RAM but when I insert just a blank dual layer 8.5G disk it will read it as a CD ROM Drive. De driver for this...
Log on to Windows by using an account that has administrator rights and permissions. Then, follow these steps.
Step 1: Start Registry Editor
Click Start, click Run, type regedit, and then click OK. Registry Editor starts.
Step 2: Delete the UpperFilters registry entry
1. In Registry Editor, expand My Computer, and then expand HKEY_LOCAL_MACHINE.
2. Expand SYSTEM, and then expand CurrentControlSet.
3. Expand Control, and then expand Class.
4. Under Class, click {4D36E965-E325-11CE-BFC1-08002BE10318}.
5. In the right pane (topic area), click UpperFilters.
Note An UpperFilters.bak registry entry may also appear. To delete the UpperFilters registry entry, you must click UpperFilters and not UpperFilters.bak.
6. On the Edit menu, click Delete.
7. When you receive the following message, click Yes to confirm the deletion of the UpperFilters registry entry:
Are you sure you want to delete this value?
The UpperFilters registry entry is removed from the {4D36E965-E325-11CE-BFC1-08002BE10318} registry subkey.
Note Do not exit Registry Editor. You must have this program for the next step.
Step 3: Delete the LowerFilters registry entry
5. In the right pane (topic area), click LowerFilters.
Note An LowerFilters.bak registry entry may also appear. To delete the LowerFilters registry entry, you must click LowerFilters and not LowerFilters.bak.
7. When you receive the following message, click Yes to confirm the deletion of the LowerFilters registry entry:
The LowerFilters registry entry is removed from the {4D36E965-E325-11CE-BFC1-08002BE10318} registry subkey.
8. Exit Registry Editor.
Step 4: Restart the computer
Your problem will have resolve after reboot.
Best of Luck
Mar 11, 2011 | IBM Lenovo ThinkCentre M55e PC Desktop
Dvd driver of toshiba
THere is no need to get DVD drivers as they are included in standard windows package and are integrated.
In case you have windows Vista installed and dVD is with exclamation mark in Device manager you jut need to delete upper and lower filters in regestry.
Click Start, click Run, type regedit, and then click OK. Registry Editor starts. (In Vista, right-click Registry Editor, and select Run as Administrator)
Important: If a CD recording program no longer works after you restart the computer, you must reinstall the CD recording program.
Sep 14, 2009 | Toshiba Satellite A105 Notebook
Dvd drive wont work
error code 19 stands for registry is corrupt follow these steps:
Start Registry Editor.
In the details pane of Registry Editor, on the right side, click UpperFilters.
Note You may also see an UpperFilters.bak registry entry. You do not have to remove that entry. Click UpperFilters only.
If you see the UpperFilters registry entry in the details pane of Registry Editor, go to step 6.
If you do not see the UpperFilters registry entry, you still might have to remove the LowerFilters registry entry. To do this, go to "Step 3: Delete the LowerFilters registry entry."
Click Yes when you receive the following message:
The UpperFilters registry entry is removed.
In the details pane of Registry Editor, on the right side, click LowerFilters.
Note You might see a LowerFilters.bak registry entry. You do not have to remove that entry. Click LowerFilters only.
If you do not see the LowerFilters registry entry, unfortunately this content is unable to help you any more. Go to the "Next Steps" section for information about how you can find more solutions or more help on the Microsoft Web site.
The LowerFilters registry entry is removed.
Also uninstall cd/dvd drives from device manager and reboot the system.
Feb 08, 2009 | Acer Aspire 5610-4648 Notebook
I canĀ“t star my dvd rom say the code 19
Does the drive even show up in My Computer? If not use this:
Step 1: Start Registry Editor loadTOCNode(3, 'whattotry'); Start Registry Editor. Step 2: Delete the UpperFilters registry entry loadTOCNode(3, 'whattotry');
  5. In the details pane of Registry Editor, on the right side, click UpperFilters.
    • If you see the UpperFilters registry entry in the details pane of Registry Editor, go to step 6.
    • If you do not see the UpperFilters registry entry, you still might have to remove the LowerFilters registry entry. To do this, go to "Step 3: Delete the LowerFilters registry entry."
  7. Click Yes when you receive the following message: Are you sure you want to delete this value?
The UpperFilters registry entry is removed. Step 3: Delete the LowerFilters registry entry loadTOCNode(3, 'whattotry');
  1. In the details pane of Registry Editor, on the right side, click LowerFilters.
  2. On the Edit menu, click Delete.
  3. Click Yes when you receive the following message: Are you sure you want to delete this value?The LowerFilters registry entry is removed.
  4. Exit Registry Editor.
Step 4: Restart your computer
Jan 27, 2009 | Computers & Internet
Cd/dvd rom is not picked up by windows. is an LG drive part:HL-DT-ST DVDRAM GSA-T10N.How doi get it towork as the device manager has a exclamation on it and says that it wont start up(Code10)??? Thanx for...
  • Start Registry Editor Click Start, click Run, type regedit, and then click OK. On Vista systems just type regedit in the Start Search box
  • The Registry Editor starts
  • In the Registry Editor, Expand (click the + sign to the left) My Computer
  • Expand HKEY_LOCAL_MACHINE.
  • Expand SYSTEM
  • Expand CurrentControlSet
  • Expand Control
  • Expand Class
  • Under Class, click (Do Not Expand) the entry {4D36E965-E325-11CE-BFC1-08002BE10318}
  • In the right pane (topic area), click UpperFilters
  • On the Edit menu, click Delete
  • You will receive the following message: Are you sure you want to delete this value?
  • Click Yes to confirm the deletion of the UpperFilter
  • In the right pane (topic area), click LowerFilters
  • Click Yes to confirm the deletion of the LowerFilters
  • go into device manager and un-install the dvd drive.
  • you will have to restart machine then.
  • this will fix the problem kallie ;)
  • Dec 28, 2008 | Computers & Internet
    Can play CD but not DVD
    Try this
    To start registry editor click on Start button than click on run and type in regedit and click on OK.Step 2: Delete the UpperFilters registry entry loadTOCNode(3, 'whattotry');
    Step 4: Restart your computer loadTOCNode(3, 'whattotry'); Restart your computer. After you have done this, try to access the CD or DVD drive. If you can access the CD or DVD drive, and if you do not receive an error message, the problem is resolved. You can reinstall your CD or DVD writing or recording software.
    Dec 28, 2008 | LG (GCC4522BK) CD-RW/DVD-ROM Combo Drive
    My toshiba dvd player cannot start due to a code 10 error
    try this: Click Start, click Run, type regedit, and then click OK. Registry Editor starts. Step 2: Delete the UpperFilters registry entry loadTOCNode(3, 'resolution'); 1. In Registry Editor, expand My Computer, and then expand HKEY_LOCAL_MACHINE. 2. Expand SYSTEM, and then expand CurrentControlSet. 3. Expand Control, and then expand Class. 4. Under Class, click {4D36E965-E325-11CE-BFC1-08002BE10318}. 5. In the right pane (topic area), click UpperFilters.
    Note An UpperFilters.bak registry entry may also appear. To delete the UpperFilters registry entry, you must click UpperFilters and not UpperFilters.bak. 6. On the Edit menu, click Delete. 7. When you receive the following message, click Yes to confirm the deletion of the UpperFilters registry entry: Are you sure you want to delete this value?The UpperFilters registry entry is removed from the {4D36E965-E325-11CE-BFC1-08002BE10318} registry subkey.
    Note Do not exit Registry Editor. You must have this program for the next step. Step 3: Delete the LowerFilters registry entry loadTOCNode(3, 'resolution'); 1. In Registry Editor, expand My Computer, and then expand HKEY_LOCAL_MACHINE. 2. Expand SYSTEM, and then expand CurrentControlSet. 3. Expand Control, and then expand Class. 4. Under Class, click {4D36E965-E325-11CE-BFC1-08002BE10318}. 5. In the right pane (topic area), click LowerFilters.
    Note An LowerFilters.bak registry entry may also appear. To delete the LowerFilters registry entry, you must click LowerFilters and not LowerFilters.bak. 6. On the Edit menu, click Delete. 7. When you receive the following message, click Yes to confirm the deletion of the LowerFilters registry entry: Are you sure you want to delete this value?The LowerFilters registry entry is removed from the {4D36E965-E325-11CE-BFC1-08002BE10318} registry subkey. 8. Exit Registry Editor. Step 4: Restart the computer loadTOCNode(3, 'resolution');
    Jun 19, 2008 | Computers & Internet
    Dvd
    Try doing this: Step 1: Start Registry Editor
    loadTOCNode(3, 'resolution'); Click Start, click Run, type regedit, and then click OK. Registry Editor starts. Step 2: Delete the UpperFilters registry entry loadTOCNode(3, 'resolution'); 1. In Registry Editor, expand My Computer, and then expand HKEY_LOCAL_MACHINE. 2. Expand SYSTEM, and then expand CurrentControlSet. 3. Expand Control, and then expand Class. 4. Under Class, click {4D36E965-E325-11CE-BFC1-08002BE10318}. 5. In the right pane (topic area), click UpperFilters.
    if after deleting the upper/lower filter it still doesnt work try to download the driver for the device and install it.
    inform me what happens
    francis
    Jun 04, 2008 | Acer Aspire 5100-5022 Notebook
    How to use the registry editor
    ok if ur so influenced in changing registry then u can change or else it would be too risky too enter into registry editor . To enter or to change registry editor just type the command regedit in ur run command thats it
    Apr 13, 2008 | Microsoft Windows XP Professional With...
    Down load problems
    hi thomas
    try this
    Log on to Windows by using an account that has administrator rights and permissions. Then, follow these steps. Step 1: Start Registry Editor loadTOCNode(3, 'resolution');Click Start, click Run, type regedit, and then click OK. Registry Editor starts. Step 2: Delete the UpperFilters registry entry loadTOCNode(3, 'resolution'); 1. In Registry Editor, expand My Computer, and then expand HKEY_LOCAL_MACHINE. 2. Expand SYSTEM, and then expand CurrentControlSet. 3. Expand Control, and then expand Class. 4. Under Class, click {4D36E965-E325-11CE-BFC1-08002BE10318}. 5. In the right pane (topic area), click UpperFilters.
    Note An UpperFilters.bak registry entry may also appear. To delete the UpperFilters registry entry, you must click UpperFilters and not UpperFilters.bak. 6. On the Edit menu, click Delete. 7. When you receive the following message, click Yes to confirm the deletion of the UpperFilters registry entry:Are you sure you want to delete this value?The UpperFilters registry entry is removed from the {4D36E965-E325-11CE-BFC1-08002BE10318} registry subkey.
    Note An LowerFilters.bak registry entry may also appear. To delete the LowerFilters registry entry, you must click LowerFilters and not LowerFilters.bak. 6. On the Edit menu, click Delete. 7. When you receive the following message, click Yes to confirm the deletion of the LowerFilters registry entry:Are you sure you want to delete this value?The LowerFilters registry entry is removed from the {4D36E965-E325-11CE-BFC1-08002BE10318} registry subkey. 8. Exit Registry Editor.
    oke
    succes for you
    cropp
    Mar 15, 2008 | Computers & Internet
    Dell OptiPlex GX260 PC Desktop Logo
    61 people viewed this question
    Alun Cox
