Question about Intuit QuickBooks® Pro 2006 Full Version for PC (5 User/s)
Problem loading Quickbooks
When I click on the icon it brings up the tan loading box then after about 1 sec of ''loading'' that box disappears and nothing else happens. It acts as if it wasn't even trying to load quickbooks in the first place. Any help would be much appreciated. Thanks, Mike
  • 32 Answers
Hi Mike,
First try reboot your machine, in case an update required a restart.
If that doesn't fix the problem, the next step would be to go to the task manager (Ctrl/Alt/Del) and go to the processes tab. Scroll down to QBW32.exe, highlight it and then click End Process (at the bottom right), then click file and exit.
Restart quickbooks from the icon by right clicking and clicking open. Do this only ONCE, hit it more than once will make Quickbooks attempt to start multiple times. Give the program time to launch.
If this doesn't work find the reboot.bat file (do a search for this if you can't find it in the quickbooks folder) - double click on it to run it. Once that is complete try again to restart Quickbooks.
If you are still having trouble you can try a a repair of quickbooks (2006 and higher). Go to the Control Panels, add remove programs, scroll down to quickbooks and click on Change remove button, choose the repair option.
If this doesn't work, you will need to do a clean install - (be sure to copy your quickbooks files to a remote disk or into another file (my documents would be a good place to put them if you have to put them on your hard drive) - If you get to that point ask about doing a clean install and I will be happy to walk you through it -
Posted on Feb 06, 2009
Desktop icons disappeared can't get qb to open
Update to the Latest Release of QuickBooks and open file in QuickBooks .
If company file is corrupted enough that it can't be opened then get some advise from http://support.quickbooks.intuit.com/support/articles/HOW12723 and need any guidance follow Intuit Customer Service .
Feb 17, 2014 | Intuit QuickBooks Computers & Internet
Hello I am not able yto get into quickbooks
If you were able to open the Quickbooks before then you can try these steps:
Run reboot.bat to register QuickBooks files in Microsoft Windows:
  1. Open the folder containing the reboot.bat file:
    • Windows 7 or Vista: Right-click the QuickBooks icon on your desktop and select Open file location.
    • Window XP:
      1. Right-click the QuickBooks icon on your desktop and select Properties.
      2. Click Find Target.
  2. Double-click the reboot.bat file.
  3. Restart the computer - Reopen Quickbooks.
If these would not work:
You have to reinstall Quickbooks.
Hope this helps!
Good Luck!
Mar 17, 2011 | Intuit QuickBooks: Pro 2005 for PC
Rt164 reset button does not work to default
Hi friend
I hope it will work for you,please follow the steps:
1) Give the router power,then with a pen press the reset button for 10 secs,after that unplug the power cable from the router for 10 secs and wait
2) After 10 secs plug the power cable back,and press the reset button for another 10 secs,after that unplug the power cable again for 10 secs. and wait.
3) After 10secs plug the power cable back and press the reset button for 10 secs, after that unplug the power cable again for 10 secs and wait.
It will bring the router back to default settings.
now if your ethernet ports have limited connectivity,please follow the steps:
If you have windows XP try this
1) connect the computer with a wire to the router
2) click start menu>contrlo panel>to your left you will see switch to classic view,click that
3) Double click and open the icon named network connection
4) right click the icon named local area network connection,click properties
5) Now click the tab named "configure" under the general tab
6) Click the tab named "Advanced"
7) Under that tab you will see something named "Property"
8) Inside that white box you will see either "Speed/Duplex" or "Link Speed/Duplex", select that
9) To your right just beside property you will see 10 mbps half duplex,select that and click OK
10)Click Ok if you find any or click Close,whicever is there.
Restart the computer and enjoy working without any limited connectivity.
warm regards
Chiranjeet Mitra
Oct 08, 2009 | Computers & Internet
Apple iphone wont register a charge, resets dont work
It's not booting up. hook it to the computer and see if iTunes sees it when you bring it up holding home and power for 6 secs. then releasing power and hold home longer. Restore it when itunes sees it and it should work again.
Aug 11, 2009 | Apple iPhone 3G Black Smartphone
Print job disappears withouth printing in Quickbooks
Go to the printers folder, right click the printer and chose properties. Under properties go to the advanced tab and check off print directly to this printer. I work with HP and find this solves the problem of printer 95% of the time
Jun 19, 2009 | Office Equipment & Supplies
(1+cotx-cosecx)(1+tanx+secx)=2
I shall attempt :D
1) cosec A + cot A = 3
we know that (cot A)^2 + 1 = (cosec A)^2
Hence, (cosec A)^2 - (cot A)^2 = 1
thus, (cosec A + cot A) (cosec A - cot A) = 1
3 (cosec A - cot A) = 1
(cosec A - cot A) = 1/3
(cosec A + cot A) = 3
Summing them, 2 cosec A = 3 1/3
cosec A = 6 2/3 = 5/3
sin A = 0.15
Thus, cos A = sqrt (1 - (sin A)^2) = 0.989
2) Prove that (1+tan x - sec x)(1 + cot x + cosec x) =2
expand
LHS= 1 + cot x + cosec x + tan x + 1 + tan x cosec x - sec x - sec x cot x - sec x cosec x
We can calculate that
tan x cosec x = sec x (since tan x = sin x / cos x)
sec x cot x = cosec x
so the above is
LHS = 1 + cot x + cosec x + tan x + 1 + sec x - sec x - cosec x - sec x cosec x
LHS = 2 + cot x + tan x - sec x cosec x
LHS = 2 + cos x / sin x + sin x / cos x - 1 / (sin x cos x)
LHS = 2 + [{cos x}^2 + {sin x}^2 - 1] / (sin x cos x)
LHS = 2 (proved)
May 12, 2009 | ValuSoft Bible Collection (10281) for PC
Went to open Quickbooks pro 2008 and received an error code of 80029c4a. It also said there was an error loading type library/DLL. Any solutions? Thanks
Update your Quickbooks, run reboot.bat, restart your computer and then restart Quickbooks
  2. Windows Vista: Right-click the QuickBooks icon on your desktop and select Open file location.
  • Window XP:
  1. Double-click the reboot.bat file
Jan 06, 2009 | Intuit QuickBooks Pro 2008: Windows
Ran SpyBot to fix lag issues, now can't access my Quickbooks 08
Spybot has been known to damage the QuickBooks program in the past.
You will need to reinstall the program.
Apr 15, 2008 | Intuit QuickBooks Premier 2008 (3-User...
Quickbooks pro 2005
I got this solution off the official site forums. This worked for me hope it does the same for you guys.
"Thanks for the post. Let me start by apologizing for this. We had sent out a message concerning IE7 and QuickBooks. What is going on is a dialog box is trying to load, but it is not loading completely. Windows is waiting for a response from this dialog box, that can't be seen. What we should be able to do to work around this for now is to press Alt-F4 at the same time. This should force this window that has not loaded correctly to close. Now we should be able to work in QuickBooks without any trouble. If this does not work we may want to hold the CTRL key down while double clicking on the QuickBooks Icon. The first solution I have seen not work only once."
Jan 14, 2008 | Intuit QuickBooks: Pro 2005 for PC
Intuit QuickBooks® Pro 2006 Full Version for PC (5 User/s) Logo
904 people viewed this question
Top Intuit Computers & Internet Experts
Alun Cox
Chris Larocque
Mike
Are you an Intuit Computer and Internet Expert? Answer questions, earn points and help others
