Question about Canon PIXMA MP160 All-In-One InkJet Printer
Error code E, 7 what?
I have an MP 160 here at the office. It is telling me the above error code with a 2 . I have looked to see what is going on with the cartridges. They are installed in place so.... why won't it work.
Prior to this the E,8 came up and I coded that to eliminate the error, but now I can't get the printer to work at all. Do I need a new printer?
We have to cut payroll today. HELP!
  • Carlos Perez
    Carlos Perez May 11, 2010
    so what;'s the error you get ... im sorry you said you get E, 7 with a 2 ??? could you 'spell' the error out for me again?
    President:
  • 8,637 Answers
Normal 0 Could have a corrupt driver.
Disconnectthe printer or at least be sure it is turned off. I'd doboth and when the CD software program asks you to connect the printerto the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 30, 2009
What does 5100 code mean?
What is error code 5100 on the MP460? - Canon Community
community.usa.canon.com/t5/Personal.../What...code-5100.../103212
Jul 7, 2014 - Please remove foreign objects so that the print head holder can move: ... closet and hooked it up this morning, I was getting the 5100 message.
How to resolve error 5100 on an MX452 / MX459 - Canon
https://support.usa.canon.com/kb/index?page=content&id...
There are several reasons for error 5100 to appear. ... If the above recommendations donot help you resolve the error, the printer will need to be repaired.
How To Fix Canon Printer Error 5100 - YouTube
? 2:23
https://www.youtube.com/watch?v=rJQVwwRxPv4
Mar 14, 2013 - Uploaded by ITJungles
Learn how to fix the Canon printer error 5100, and have your printer running again. ... Reset error Canon ...
Jan 05, 2016 | Canon PIXMA MX340 Wireless Office...
Error 5B00
Canon PIXMA MP180 All-In-One InkJet Printer
Error 5B00
Jul 04, 2012 | Canon PIXMA MP180 All-In-One InkJet...
Techwood DDR95 av keeps going into protect mode
Protect is an error code for short and or overload. It will appear once the processor sense a malfunction either on the power supply or on the load (high chance is the output IC). DIY steps are as follow to determine where the fault is : 1. Allow the unit to cool down for an hour. Give proper ventilation and keep away all obstruction from the vent to have a sufficient air flow. 2. Disconnect one at a time the speakers, inputs, from the unit while powering it on.
If the unit back to normal again then you've confirmed that any of the above caused the error code. If #1 is the caused, you have to check also the exhaust fan, clean it as much as possible, replaced if faulty. If #2 is the caused (speaker) check the wire and speakers for short, (input) check the RCA cord for short or replaced if necessary.
If the above simple fix didn't cure the error code, you can try the next steps if you are an electronics enthusiast. Now after removing the cover, you have to concentrate first on the power supply board. Look for bulged electrolytic capacitor. Leaky capacitor will affect the regulation of the supply and will trigger the error code. Look for dry joints. Check it also in the pre-amplifier stage, main output board where a big heat sink is located. Next disable the output amplifier stage by disconnecting the supply. If the unit come out, make some re-soldering on the board, spot the cold solder and dry joints and then try to connect again. If the error code appear again, high chance that your output IC is faulty but still to be confirmed. Using the disoldering pump and soldering iron pull-out the output IC from the board then try the unit. If the error code disappear, confirmed that your IC is faulty.After trying the above steps-by-steps guide and still the symptoms persist this is the time for you to send it to repair shop. Remember that your unit has a lot of parts and only some basic steps have done, leave the expert to troubleshoot the entire unit.
Dec 15, 2011 | Audio Players & Recorders
Canon D340 Copier System Error E000
Your printer show Error code E000 suggests the problem history has recognized all of these of the following error codes four moments: Error code E001;Code E002;Error E003. Printer Canon E000 error will be removed in the service mode.
Please try reset factory your canon printer..but if it still show error code E000 again ,you can try with a genuine fuser unit (reseting fuser unit). Good luck
Solution 3: Try this, atempt will clear canon E000 code in Service mode:
1.Press ADDITIONAL FUNCTIONS, #
2.Go to #7 Printer and Press OK
3.Go to #4 Printer Reset and Press OK
4.Yes = ( * )
Sep 09, 2010 | Canon PC-D340 All-In-One Laser Printer
GETTING ERROR CODE E27, INK ABSORBER FULL
Canon error e27 ink absorber full/reset process
printer powered off but connected on power source , you must:
1. Press & hold stop/reset button, and then press & hold [ON/OFF] button.
2. When Green power lit, leave stop/reset button & press twice stop/reset (see orange indicator).
3. Leave On/Off button. Printer in actually service mode.
4. Press stop/reset 4 times (see orange indicator) if not blink restart above process from top.
5. After press stop/reset 4 times successful press On/Off button 3 times. printer will off.
6. Press On/Off button.
May 13, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Ink absober is full error 2 and 7 canon MP 160
it looks like you will need to take to a service center to get it replaced. You probably have used your machine a lot and the waste pads are full.
Apr 17, 2009 | Office Equipment & Supplies
E16
press stop reset button for few seconds and you can use your black cartridge for printing,but do remember to put use black only setting in ur printer cartridge settings.
Nov 09, 2007 | Canon PIXMA MP150 All-In-One InkJet...
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
old marine
old marine
