Question about Canon L220 Plain Paper Laser Fax
Faxes in memory
I had problems with getting faxes out of the memory when it asked for me to submit the paper size. I've eventually found out you press the function key, followed by memory reference key then press OK. Hope this is of use to anyone.
To retrieve faxes from the memory simply press the Function key, followed by the memory referance key then press OK.
hope this is of help to you folk out there struggling with this machine as i am.
Posted on Jan 30, 2009
Our fax machine - panasonic model fp-342 can't received fax due to error display "fax memory full" . How can i fix that?
This fax machine stores the faxes in memory and then prints them out.
If it's unable to print them, is either because there is no paper or no ink.
The memory eventually gets full and stops receiving faxes.
Apr 01, 2011 | Office Equipment & Supplies
Can you retreive a sent fax from memory
The fax element of the Printer contains a memory feature for storing faxes in the event of a printing problem. This feature is useful for protecting yourself against missing faxes if your printer runs out of paper. In order to retrieve missed faxes, the feature must be switched on when the faxes arrive. You can reprint faxes stored in the device's memory from the main control panel. You should allow approximately 5 minutes for this task, or longer if many faxes are stored in the memory.
Instructions:
Load paper in the input tray.
Press the "Setup" button on the front of the printer.
Select "Tools," then "Reprint Faxes From Memory."
Press "Cancel" to stop printing. Faxes are printed in reverse order; the most recent fax is the last to print.
Dec 03, 2010 | HP Office Equipment & Supplies
On my Canon MX310, the display says "Waiting for Report". Fax Memory is clear, but the In Use/Memory light stays on.
Try this step ... found it on Canon's website
Issue: ERROR LCD: WAITING FOR REPORT
Solution: Set [AUTO PRINT RX] to ON (MX300 / MX310)
AUTO PRINT RX When [AUTO PRINT RX] is set to [OFF], incoming received faxes will be temporarily stored to memory and transaction reports (TX, RX and Activity) remain in memory. The default setting is [ON], which means incoming received faxes and transaction reports will automatically print. The fax machine will not automatically print a received fax and will store it in memory in the following conditions.
  • Ink is low or has run out
  • The paper size and type is not set correctly
  • Paper has run out
  • The Output Tray is closed
To set AUTO PRINT to ON, please follow these steps.
  1. Press the <FAX> button to enter the Fax menu.
  2. Press the <Menu> button. [FAX SETTINGS] is displayed
  3. Press the left or right arrow button to select [RX SETTINGS] , then press <OK> two times.
  4. Press the left arrow to select [ON], then press <OK>.
    Note: When AUTO PRINT RX is set ON, a sub-menu will appear to PRINT WHEN NO INK.
  5. At sub-menu PRINT WHEN NO INK, decide if you'd like the machine to continue to print incoming received faxes if ink is low.
    CAUTION: When this option is set ON, the fax machine will not monitor the ink level of the ink cartridges. If ink is low or out, received faxes will print with streaks or blank. Furthermore, once the fax is printed, it will be deleted from memory.
    1. To print received faxes when ink is low or out, press the left or right arrow to select [ON] and then press <OK>.
    2. To store received faxes in memory when ink is low or out, press the left or right arrow to select [OFF] and then press <OK>.
  6. Press the <Stop/Reset> repeatedly to return to Fax standby mode.
Nov 17, 2009 | Canon PIXMA MX310 All-In-One Printer
Incoming faxes stuck in memory, how do I print them. Prior to this the faxes were coming through, but half printing then jamming, so press start and that peice of paper would come out then the next go in...
This answer maybe a little late for you but for anyone else tring to print fax stored in memory:
1. Press Menu - Fax Functions will display
2. Press 2 - Print report will display
3. Press Enter - Last Transact will display
4. Press 7 - Reprint Faxes will display printed the pages
5. Press Enter
This will print all faxes in memory. Press Stop when you have printed the pages you need.
You can print fax log (Press 2 after step 3) to see what is in memory
Oct 01, 2009 | HP 1020 Plain Paper Thermal transfer Fax
FAX 560 Brothers displays message "Memory Full"
Do you have faxes in memory? You may need to either erase faxes in memory or print them out.
Printing a Fax in Memory
If you have Fax Storage ON for remote retrieval, you can still print a fax in the
memory when you are at your machine:
1 Press Function/Set, 8, 4.
2 Press Start.
3 Press Stop.
(See Turning On Fax Storage, page R-2.)
Apr 04, 2009 | Brother IntelliFAX 560 Plain Paper Fax
Incorrect Paper Size Canon super G3 fax
Sometimes turning it off and on again fixes it. However, we started having a problem where it would print out one page after you powered it back on again and then give the "incorrect paper size" message. I've found that by either holding down the green button or repeatedly pressing it while it powers back on (and held until the first page prints) fixes the problem.
Jun 02, 2008 | Canon - SUPER G3 FAX BOARD-T1 (0450B002AA)
Incoming fax problem
DON'T KNOW IF THIS WILL HELP-BUT MY PROBLEM WAS SIMILAR--MINE WAS SAYING PAPER TOO NARROW WHEN I WAS TRYING TO PRINT AND COPY. I JUST KEPT MOVING THE FRONT SLIDER AND THE LEFT HAND SIDE SLIDERS BACK AND FORTH AND TOOK THE PAPER IN AND OUT --TRIED AGAIN AFTER EACH TIME--IT EVENTUALLY FIGURED OUT I DID HAVE THE RIGHT SIZE PAPER--
ALSO TRY---MENU--THEN--COPY SET-UP--THEN PAPER SIZE--SEE IF PAPER SIZE IS SET RIGHT.
Mar 01, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Fax in memory light stays on
I've had this 830 for about 5 months now and am very impressed with its speed, but the glitches, Holy Smoke.
The one you're describing is one I've had before. The only solution I've found is to unplug the machine, wait about one minute and plug it back in. All is then OK. The problem with that system is that if there are any more docs in memory, you've lost them.
I'm having a similar problem with receiving faxes. The first sheet prints, and then the display indicates that there is a 'fax output error check page size and press OK'. The memory light shows that there are more pages of the fax (I presume) that need to be printed, but they won't be because of this error. Of course one checks the size and presses OK but it simply prints out the same page followed by the same error message. This could go on for eons if one would allow it. I then have to unplug the printer, wait and plug it back in, and again all is well, but I've lost the documents in memory.
There are so many little quirks with this machine I am almost tempted to go back to my miserable HP, but I've chosen to keep working with the MP830 with the hopes that after years of learning its idiosyncracies, there will eventually be a class action suit against Canon which I will be part of, to cover the cost of psych services and physical therapy (bas shoulder from throwing the machine out the window.
Wes
Oct 13, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Constant messages "Check Paper Size"
Try this first..... Some faxes can be configured for different paper sizes for timing of the preinting process. This would be either tabs on the back of the paper drawer of a soft setting found in the owners manual.
Apr 17, 2007 | Canon FAX-L350 Plain Paper Laser
Canon L220 Plain Paper Laser Fax Logo
162 people viewed this question
old marine
old marine
