Question about Pioneer DVR A03 DVD-RW Burner
Not reading dvd r or rw as writable disk
For some reason it seems not to be reading blank DVD discs, and I am unable to record. When I put in a blank Sony DVD+RW, my computer tells me it is not a readable disc. Also, when I put in a blank Maxwell DVD-R, it says there is nothing in the drive.
  • 41 Answers
It sounds like you are having issues with all DVD writable disks. From the specs I was able to find online about your DVD writer, DVD+RW discs may not be compatible with the the drive. Make sure you are using DVD-RW (note the minus instead of +). I think you might need to reinstall your DVD drivers. This should solve the issue.
Posted on Jul 27, 2007
SOURCE:
I have a Philips 615 DVD recorder that has worked wonderfully since I got it in 2005. However, this weekend it decided to stop reading any DVD put into the tray. I was recording something and finalized it....
Sometimes a blank DVD will not be the proper format. Upgrades have been done to DVD-R disks, and your recorder might not recognize the upgraded format on the newer disks. This has happened with Philips, Emerson machines- they all use a Funai burner. I have found with my FUNAI/Philips/Emerson recorder that purchasing the Philips, 1-16 speed DVD-R blank disks fixes this problem on my 2 machines. If you have an older DVD-RW 2 speed disk, it should work as well.
Jul 01, 2017 | Televison & Video
I have a toshiba dvd recorder D-R160SB and am trying to record from sky plus to a verbatim dvd-rw (as recomended by the manual). When i put the disk in the dvd recorder it immediately starts to format the...
Two in ten discs usually are corrupt out of the box unfortunately. Try a different brand. As for it coming out in 4:3 or 16:9 try the settings on your SKY box. This should work.
Mar 01, 2014 | Televison & Video
Player won't load a blank DVD-RW disc
because there is nothing to read in blank cd rw , because dvd operating system is not meant to write cd ,but only to read the disk
Jan 31, 2013 | Samsung DVDR120 DVD Recorder
I have dubbed vcr tape to a Sony DVD-RW disc and tried playing it back through a toshiba player and it keeps coming up Bad Disk. My PC won't even recognise it. When started dubbing the screen displayed 1hr...
Did you say you used a DVD-RW disc to transfer a videotape onto? The reason your PC won't recognise that disc is because the data format on it is a different language to what PCs understand - plus an unfinalised DVD-RW won't play in other DVD players - it is usually an incompatible format.
(DVD+RW discs with titles/top menus created in video mode CAN be played on a PC DVD drive or a normal DVD player as can finalised DVD-R discs (DVD-R discs MUST be recorded and finalised in the same recorder for compatible playback). DVD-RW discs can only be viewed on the unit they were written/recorded on.
The other reason for the 'remaining space' on the disc you describe showing less than 120 minutes is due to a title recently being recorded or erased - unless you format it - the 120 minute / 4.7GB DVD-RW will not show full available space. Erasing titles on re-writable DVDs does not increase space. The same rule applies to unfinalised +R / -R discs (you cannot re-format these to get the space back once recorded - they are 'once only' writables)
I recommend you invest in some DVD-R discs and re-copy your VHS tape to that - then if you are satisfied with the result, title etc., finalise the DVD-R - it will play on any DVD player or PC with DVD support (or it should). These discs are relatively inexpensive to buy just about anywhere.
Final note: do NOT finalise the DVD-RW you recorded (I hope you haven't already done this) - simply format/erase it - re-use it for something else or keep it until you need it.
You can use any brand of DVD, just take note of the format before recording/playing.
Mar 21, 2011 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Record errors
If your dvd player only supports dvd+r discs then that is the only way it will record. It will only record once onto the dvd-rw and, since it doesn't support the re-writables, it won't be able to use this function. This is the most likely reason for the first error. The second problem is a little confusing. Is it when you are trying to record on dvd-rs or dvd-rws that it says it can't record? I hope this post was helpful (for the first error, anyway). Good luck! I hope everything works out! Sincerely, Der Strom
Apr 06, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Will not read blank media so that I can record.
Ok, Firstly it sounds like you have reasonable knowledge on what you're doing.
But just to clarify a few things.
1.You say you have tried a couple of different brands of disc.Unless they are of good quality
or compatible with your machine they may not work properly.Try TDK or Verbatim for example.
Also make sure they are DVD-R or DVD-RW.
2.If no blank discs are successful,then you may need to clean the laser lens thoroughly.
I know you said you cleaned the lens,but was this with a lens cleaner disc?
If so it will only remove dust not built up grime from other sources such as smoke from cigarettes.
This would entail taking the cover off the unit and cleaning the laser lens directly with a
cotton bud dipped in cleaning fluid.If you are not confident in doing this,then you
would need to get someone qualified to do so!
I have gotten many DVD Players and DVD Recorders working again doing this.
May 20, 2009 | Samsung DVD-R130 DVD Recorder
I have a Sony CRX320E CD/DVD unable to write a DVD
CD-RW drives can only read all CD-rom and CD-RW formats and read DVD formats but cannot write to a DVD, if you want to write a DVDs you need to buy a DVD-RW burner which can burn all CD-formats
Jan 16, 2009 | Sony (CDR320E) CD-RW/DVD-ROM (Combo)...
Recording Error "Can not record on this disk/E4 54037380
I had that exact same problem. I would record a bunch of dvds with no problems for months and then some and one day it doesn't work. Only this showed up E4 EA03738B. However I've found the solution. Instead of going out and returning the recorder or buying new dvds just purchase a Laser Lense Cleaner. It's a dvd cleaner. Works like a charm.
May 05, 2008 | Emerson EWR20V4 DVD Recorder/VCR
JVC DR-M100S
I have a JVC DR-MH50 DVD/HD recorder and it will only record on DVD-R or DVD-RW not DVD+R or +RW. so check your format of disk you are trying to record on it may be as simple as that.
Sep 04, 2006 | JVC DR-M100S
Samsung DVD Rom drive SD 612B
Its a dvd-rom drive. READ ONLY MEMORY.
That drive will not burn a dvd...it has to say dvd-r/dvd-rw.
or be referred to as a super drive.
Hope this helps.
Aug 21, 2006 | Samsung (SD-612) Internal DVD Drive
Open Questions:
See all Pioneer DVR A03 DVD-RW Burner Questions
Pioneer DVR A03 DVD-RW Burner Logo
236 people viewed this question
Top Pioneer Computers & Internet Experts
Ekse
Damen Wong
Damen Wong
Are you a Pioneer Computer and Internet Expert? Answer questions, earn points and help others
