Question about Chicago Pneumatic Heavy Duty Jitterbug Air Sander
Trigger is stuck
The hand trigger for the sander is stuck down any one know how to fix that or even how to take apart...
  • Rick Reichlein May 11, 2010
    Have you tried to use penetrating oil such as wd-40 on it?
    Sergeant:
  • 172 Answers
I had one do the same thing and all i did was spray some wd40 all around the trigger its lie a plunger valve and alot of dust was built up in mine ...It worked on mine hope it helps yours
Posted on Nov 17, 2009
Dewalt air Palm sander, just bought and tried it a couple times and worked just fine but when I hit the trigger about the 5th time u can just hear air coming through the sander
the vanes in the small air motor are stuck
try a small amount ( couple of drops ) of sewing machine oil in the air inlet and see it it will spin
you may need to bump the pad on the bench to jar the shaft to start rotating
Nov 04, 2015 | Dewalt Tools & Hardware - Others
How do I install paper to Skil Dual Action Sander model # 7372?
Sander has 2 slotted rotating rollers one on each end the paper gets fed in as you rotate roller, which will grasp paper and hold, feed/wind roller with slotted screwdriver till paper secure. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Skil nbsp7372 TYPE 1 nbspDUAL ACTION SANDER 348542
Jul 28, 2014 | Skil Tools & Hardware - Others
Does not start when trigger is pulled; is there a reset somewhere that I can' find
trigger switch is probably bad or wire has broken or come lose,obtain parts list from sears to change trigger switch,or see if it is still under warranty.
Jun 12, 2011 | Craftsman 3 x 21" Variable Speed Belt...
I spilled lemon ade in my psp and it only affected the "L" button, its stuck as if i am holding it down but i am not. is there a way i can fix it at home? the button isnt stuck down literally but...
There is a pad underneath the L Trigger that makes contact with the receiver for the button. The pad is either stuck to the receiver or the lemonade is causing a false contact. You can take it apart to clean it, once you remove the shell, you can remove and clean both triggers. Here is a link:
http://forums.afterdawn.com/thread_view.cfm/370436
May 22, 2011 | Sony PlayStation Portable (PSP) Console
My CP7200S has stopped working. The air simply comes out of the bottom of the sander through the filter. Any suggestions?
the units gummed up from the air,get a can of air tool oil and pour it into the air hose inlet,then work the trigger to let the oil into the sander,then pour more in and connect the air hose and see if it will start,if not you may need to dis assemble and one of the reeds may be frozen in place or stuck letting air go by it and out the exhaust
May 19, 2011 | Chicago Pneumatic Cp7200s Mini Random...
I have a pts4 porter cable pneumatic sander that spins but stops on contact with a 100 grit pad or any pad that ive tried and this hapens even at the start before the compressor even kicks on. it didnt...
this unit takes 90 pounds per constant for desired function. Most machine shops have Huge compressors that will run these at a constant rate ,, also check the exhaust ( towards the vacuum hookup to check for clogs,, ) compressors that have a gauge that read 90 lbs doesn't necesarly mean they have the CFM to keep the pressure at what you need to keep it running
May 03, 2011 | Porter Cable PTS4 5 Inch Vacuum Ready...
Porter Cable random Orbital Sander (Quicksand) Model 333, Double insulated When sanding, it stops and starts, it sounds as thogh it is stuck and then gets going for a short while
Hi, Sanders are prone to getting lots and lots of dust inside the unit. The cooling fan makes this problem inevitable. The only way to fix this is to take it apart and and blast it with a pressurized air tool. Hopefully this will bring back some life to your sander. The effectiveness of this procedure is dependent on how well you can remove all of the dust. hope this helps.
Nov 16, 2010 | Porter Cable 332K Quicksand Random Orbit...
MY hoover steam vac hand held hose cleaner leaks profusely
try taking a sharp knife and shaving a little off the edge of the plastic, or a small file if you can get to it, see if it is getting binded. If its getting stuck internally, you will have to replace the switch instead of risking takin it apart.
Jul 09, 2009 | Hoover F5810 SteamVac Upright Vacuum
Chicago Pneumatic  Heavy Duty Jitterbug Air Sander Logo
199 people viewed this question
Top Chicago Pneumatic Air Tools & Compressors Experts
John Trevino
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Chicago Pneumatic Air Tool and Compressor Expert? Answer questions, earn points and help others
