Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
Oven broiler and auto clean not working.
Whirlpool Gold oven/microwave unit.
Is this reasonable fix ? can I do myself if it is replacement componet ?
    President:
  • 1,314 Answers
If the oven broiler isnt working self clean wont either check the broiler element to see if its burned out pretty easy to replace most of the times you can replace it from inside the oven be sure to turn the power off then remove the two retainers from inside and pull element out
Posted on Jan 29, 2009
Microwave runs, but not heating. Whirlpool Gold
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, & testing.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can download Whirlpool owner's manuals and installation instructions (very handy when removing the oven form the wall for parts replacement) here.
You can find helpful exploded view diagrams and order parts here.
Nov 22, 2009 | Microwave Ovens
I have a Whirlpool Gold oven model GW395LEGB5 that won't heat. The broiler works fine. Sometimes, after the broiler is lit, the oven will heat up. But no more. Just the broiler works. Is this...
If the broiler works fine, but the oven does not, more than likely this is caused by an igniter that has gone bad. The intermittent symptoms you were experiencing is a sign that the ingiter probably became weak due to age and finally failed. The following link explains how these igniters work and how to replace one:
http://www.fixya.com/support/r401858-replacing_oven_igniter_gas_range
Since both oven manifolds are fed from the same gas source, this can be narrowed down to an igniter problem. Your oven should have the Norton type igniter. The part number for a replacement is 9782065 and can be found at appliancepartspros.com for about $71, You can search around if you like, but this was the cheapest I could find it.
Your oven has interchangeable igniters. Meaning the broil manifold and bake manifold use the same type of igniter. You can swap igniters while awaiting parts, if you wish to use the oven to bake.
NOTE: If the connector plug on the ingiter you receive does not match the receptacle in your stove, you will instructed to cut the leads and connect them together using ceramic wire lugs (included in the kit you receive). Do not attempt to use standard wire lugs as they will melt. The wires and ceramic lugs are heat resistant.
If you have any questions, or need additional assistance, please let me know. I hope this helps you.
Sep 07, 2009 | Kitchen Ranges
Oven won't heat
The only reason I know the answer to your question is because I am having the same problem. Our appliance quit working after we used the cleaning option. Both the bake and broiler quit at the same time. Our local repair man said that the problem is caused from a malfunctioning thermostat, which is about a $300 fix.
May 18, 2009 | Whirlpool RBS245PD Electric Single Oven
No Cooktop Lamps
9a1ba72.jpg You can solder a wire on here to bridge the broken trace. 1 min fix!
Jan 31, 2009 | Whirlpool MH1140XMS Microwave Oven
Jenn-air microwave dead
I'm afraid since Jenn Air has become a division of Whirlpool (along with numerous others) the quality has suffered.
I was going to suggest that you purchase a service manual for your unit so you could 'reset' it yourself. Service manuals can cost from $12-$40 US and in many cases obviate the need for 'professional' service calls. However, I couldn't find one offered for your model number so your only choices are to continue to pay for 'service' or examine the guts visually to see if you can locate any reset feature. This is what I would do.
When microwaves fail, older ones generally need a diode, a big capacitor or the magnetron replaced. Newer units are suffering power supply failures as many have moved from the reliable but less efficient 'linear' power supplies to 'switched mode' types that are more efficient but more complex and prone to failure. These later types usually have the word 'inverter' in the model description.
Jan 04, 2009 | Jenn-Air JMC8130DD Microwave Oven
Oven will not shut off broiler element stays on
The control knob more than likely operates a relay that has gotten stuck in the energized position. If this isn't the case then the Temp sensor or thermostat probably shorted internally. Unplug the unit before attempting any work.
Nov 16, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool electric wall oven rbs305 oven is on, control panel shows on, 350, etc, but elements don't heat. Same for broiler element. Auto clean was run last week and the oven hasn't been used...
you have a thermal fuse open it is called a "T.O.D" it is located on the back of the unit or up in the top. the self clean very often pops these especially on the whirlpool units made 4-5 years ago very cheap part like $20 you can find it with the wiring diagram easy fix good luck
Apr 22, 2008 | Kitchen Ranges
Integra fan convection - rsa regency
you might be able to just clean the ignitor to get it working again. Take it out and give it a good cleaning. If that doesn't work then it could be your spark module. If it is your spark module it will have to be replaced. I have replaced spark modules and ignitors of ovens or ranges that you can no longer get parts for with whirlpool modules and ignitors. There are basically two types, just make sure you get the same type. One type , typically used by GE uses a continous ignitor that glows when it works, and Whirlpool (on most models) uses the spark module and ignitor that makes the clicking sound like your oven did for ignition.
Jul 24, 2006 | Bosch HLK4525GB Convection/Microwave Oven
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
121 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
