Question about OKIFAX 4580 Plain Paper LED Fax
Cannot get messages out of memory
The alarm button is on. We are not receiving faxes. The message shows "MSG in Memory". It is being stored in memory. We can, however, send a fax. We followed the instructions under "Receiving Faxes in Memory" and the Print Operation button keeps stating Not Programmed. Before this happened, we had received a fax but it did not completely print out and stopped. Thank you for any help you can give us.
We switch our off, wait 10 seconds, switch on & fax is printed. We don't think we have lost any faxes this way but be aware it might happen.
Posted on Mar 28, 2011
SOURCE:
Memory info retrieving from lexmark x5630 fax machine
Usually, faxes are temporarily sent to the printer's memory when one of the cartridges' ink level is not substantial for printing at the instance of receiving the fax. When this happens, try to replace the cartridge(s), *without navigating away from the message "fax sent to memory", by opening the printer cover and replacing the low-ink or empty cartridge(s). After the new cartridge is installed, close the printer cover and press the OK button. Your printer should then print the fax stored in the memory.
*Make sure not to navigate away from the "fax sent to memory" message, otherwise, data will be lost.
Dec 30, 2011 | Lexmark X5650 ALL-IN-ONE PRINTER
How to print faxes from the lexmark x5630 which is stored in the memory
Dec 30, 2011 | Lexmark X5650 All-in-One InkJet Printer
Brother FAX-8070P memory shows full and does not send all pages at one time?
This message means the memory capacity of the unit has been exceeded. The amount of memory used depends on the amount or type of data on the documents being faxed or copied.
  1. If you get an "Out of Memory" message while scanning the first page of a fax, press Stop/Exit to cancel scanning.
  2. If you get an "Out of Memory" message while scanning a subsequent page, you can either press Fax Start to transmit the pages that were scanned so far or press Stop/Exit to cancel the operation.
When Fax Storage is set to On, a copy of all received faxes are stored in the memory, thus using up a % of the memory available for other functions.
The Fax Storage feature is utilized for Fax Forwarding, Fax Paging and Remote Retrieval. If you do not need these features, verify Fax Storage is set to Off by doing the following:
  1. Press the Menu/Set key.
  2. Press the arrow key until FAX appears on the LCD. Then, press Menu/Set.
  3. Press the arrow key until REMOTE FAX OPT appears and then press Menu/Set.
  4. Pressthe arrow key until FAX STORAGE and then press Menu/Set.
  5. Check the setting. The display will read ON or OFF. If the setting is ON, press the arrow key until the display reads OFF.
  6. Press Menu/Set.
  7. If you have faxes stored in the memory, you will receive a message that reads Erase all fax? 1. Yes 2. No. If you want to erase all the faxes in the memory without printing them out, press 1 (Yes) and then press Stop/Exit.
Note
    If you would like to reprint the saved faxes, press 2 (No), press Stop/Exit and continue to the following steps for instructions on how to print stored faxes.
If you do need the features that require Fax Storage to be On, the stored faxes will need to be erased or printed to remove them from the memory and to allow additional memory to be available. Follow these steps to print the stored faxes:
  2. Press the arrow key until FAX appears on the LCD and press Menu/Set.
  4. Press the arrow key until PRINT FAX or PRINT DOCUMENT appears and press Menu/Set.
  5. Press Fax Start.
  6. After printing is finished, press Stop/Exit.
Jun 06, 2011 | Brother FAX-8070P Plain Paper Laser
I HAVE A SHARP UX-A450 FAX MACHINE AND WANT TO EMPTY THE FAX MEMORY.
MEMORY IS FULL / SEE MANUAL (alternating messages)
The memory is full. You may have too many messages recorded in the answering machine. To erase messages, see below. This may occur during fax reception if too much data is received before the pages can be printed out. If faxes have been received to memory because printing is not possible (an additional message will indicate the problem), resolve the problem so that printing can continue (see Substitute Reception to Memory on page 66). If you are attempting to transmit from memory, see If the memory becomes full on page 57. If you are copying, see If MEMORY IS FULL appears on page 67.
Erasing received messages:
It is important to erase received messages after you listen to them to ensure
that the memory does not become full.
? Erasing all messages: To erase all messages, press FUNCTION, DELETE, and then START/MEMORY.
? Erasing a single message: To erase a single message, press DELETE while the message is being played.
If the memory becomes full while the document is being scanned, MEMORY
IS FULL and SEE MANUAL will alternately appear in the display.
? Press START / MEMORY if you want to transmit the pages which have been stored up to that point in memory. The remaining pages will be ejected from the feeder. After transmission, the memory will be cleared and you can transmit the remaining pages. You will also need to transmit the page which was being scanned when the memory filled up.
? Press STOP if you want to cancel the entire transmission.
Nov 25, 2010 | Sharp Office Equipment & Supplies
My fax machine can't receive message, "fax memory full"...how to erase the fax memory?
It will depend on the model and make and you have not supplied that information.
If this information in memory was received information then the machine should print out the documents as long as there is nothing in the display saying it needs toner, paper etc, etc.
If it is not received information in memory then it can only be scanned information for copying or transmitting....again, not knowing make or model...you should be able to use your users manual and delete the pages you have stored into memory.
Oct 07, 2010 | Office Equipment & Supplies
I just received a fax on my Cannon Mx310 but I
mailcenter12 --
Here are the instructions for retrieving the fax's from the memory:
(I found this at: http://safemanuals.com/annexe_MX310%20series%20Easy%20Setup%20Instructions_CANON_PIXMA%20MX310-_E.htm
�� Printing a List of Documents in Memory
The machine can print a list of documents stored in memory (the memory list) showing the
transaction number (TX/RX NO.), transaction mode, recipient, number of pages, date, and
transmission time of each document. When printing or deleting documents in memory, specify a
document by its transaction number.
1 Press the FAX button, then press the Menu button.
2 Press the [ or ] button to select MEMORY REFERENCE.
3 Press the OK button two times.
The memory list is printed.
�� Printing or Deleting a Document in Memory
3 Press the OK button.
Hope this helps!
-- RT
PS - If useful, don't forget to vote!
Sep 16, 2009 | Canon PIXMA MX310 All-In-One Printer
FAX MEMORY FULL
Please feed paper in fax machine and get prints of all messages. this will free machine memory. 2nd option is to reset the fax machine, if this option is available in your fax.
Aug 20, 2008 | Office Equipment & Supplies
Reg. printing of memory received messages
Yes, after refilling the cartridge, fax in memory automatically print out with charms. :) thanks for your help.
Aug 18, 2008 | Office Equipment & Supplies
Help increase msg memory of RAZR V3i
you can not store msg to your card nor can you increase the msg storage area for your phone.
Jun 20, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Ready Memory Received
Dear guys, your toner cartridge is low and as a preventive measure, the unit stores the faxes in order to give priority to copying and printing. If you are using remanufactured cartridges, the unit might not be displaying the low toner warning.
Jan 24, 2008 | Samsung SCX-4216F All-In-One Laser Printer
OKIFAX 4580 Plain Paper LED Fax Logo
234 people viewed this question
Top OKI Office Equipment & Supplies Experts
Steve Allison
Steve Allison
WTF Chuck.....
WTF Chuck.....
Clive
Clive
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
