Question about Acer Aspire 5315 Notebook
Acer aspire 5315-2077
After using magic jack, i now have no sound. device manager says no audio device installed. tried re-installing all drivers to no avail. is there a replaceable sound card in this thing?
please help!!
  • 7 more comments
  • charles jorden Jan 29, 2009
    i have since disposed of magic jack. i have tried to uninstall and re-install all audio devices and drivers. even downloaded newest driver from realtek. the device manager says 'this device cannot start' (code 10).
    i scan weekly using avg. i also run spybot. i'm running vista home basic...
    driver date: 8/7/2007
    driver version: 6.0.1.5462
    i tried to update driver, but said it encountered an error 'this device cannot start' (code 10)
    did my sound card get fried?
    does it even have a sound card? i can only find limited info about this laptop, and nothing really useful.
    i'm thinking maybe on-board audio chip...
    slick little program!!!!
    thanks. i ran it, and it did find problems and fixed them. but not my sound issue :(
    it must be hardware.
    any other suggestions would be helpful. i cannot find out if it is on-board audio or add-on.
  • Dan rogers
    Dan rogers May 11, 2010
    that is always a possibility. You can try to contact the manufacturer and see if they have a software test you can run to check your chip
  • Dan rogers
    Try to download malwarebytes here. Run a full scan and see if anything comes up. I recommend malwarebytes over avg any day of the week. If your computer doesn't come up with anything i have one more idea but i am having a problem finding the program. I had the same problem with my cd-rom and i ran a registry program and it fixed something in the registry and now everything works. I think it would also fix your problem.....if I can Find it
  • Dan rogers
    When is the last time you scanned your computer with anti-virus software?
  • Dan rogers
    Try to go into the device manager again only this time have the computer search for new hardware. Hopefully it will pick up your sound device and then you can re-install the drivers.
    You can also look through the setting in your magic jack program and check to see if it automatically sets something else as your sound device
    Master:
  • 413 Answers
I found it!!! hopefully this will work for you as it worked for me
http://www.digitalsupporttech.com/en-us/download.htm#
Posted on Jan 29, 2009
  • Dan rogers
    Dan rogers Jan 29, 2009
  • Dan rogers
    Dan rogers Jan 30, 2009
    if you want to see if it is on the motherboard (it most likely is nowdays) it will be grouped up with all the other plugs in the back of the computer. If you look at what is normally the bottom of the case you can see expansion slots. This is where the soud plug would be if it was a daughter card
  • 679 Answers
It may show up under USB devices, your audio is Realtek, check to see if it's showing up in device manger. Old trick is to remove the hardware by deleting it from device mgr, reboot and it should pick up the hardware and then install the software for it. The realtek is what I am describing, make sure you physically remove the magic jack before doing this.
  • George Bill
    George Bill Jan 29, 2009
    If you look in the device mgr. fot audio devices, you should see sound devices. Expand that by dbl clicking on it. You should see the panel that has the driver for your realtek sound, tell me what it says. I can fix this easily if I could see it but I must rely on you to be my eyes and ears. Let's see if it says in the expanded applet that your sound device is working properly
No audio output device installed
Install your audio drivers, down load and install from the audio section, hope this helps :) acer aspire
May 29, 2011 | Acer Aspire 4520-5582 Notebook
No sound is coming out of my acer laptop at all
check to see if your sound driver is installed....if not, the try installing it to fix the problem....go to my computer----right click my computer----click on manage--click on device manager. then check if theres a yellow indicator on the sound pane...if there is, that means theres no driver for the sound...re-installing will do the magic.
Dec 16, 2010 | Acer Aspire 5100-5480 Notebook
Modem device on high definition Audio Bus for acer aspire 3680
These are the same thing , they will both disappear when you install the audio driver
http://support.acer-euro.com/drivers/notebook/as_3680.html
Click under Windows XP Drivers And Utilities And click Audio Driver
Always check the manufacturers site for your drivers!
Jan 24, 2009 | Acer Aspire 3680 Laptop
Sound problems
well, the driver is not installed properly.. you must install it first so that u can use your cam.. f installed already, check your connections and make sure your cam is detected by your computer
Nov 14, 2008 | Acer Aspire 5315 Notebook
Fix high definition audio decice acer 5610
i need the Intel 82801G (ICH7 Family) High Definition Audio Controller (rev 02) driver for my acer 5610z notebook please
Apr 25, 2008 | Acer Aspire 5610 Notebook
About sound in aspire 4520
dear friend
if u install a driver and it's not working and if u don't her any kind of sound then yr driver is not proper install first of all u chek device manager in coutrol panel then system then device manager and chek sound driver is install proper ( not showing yellow symbol show ) if it's show's then uninstall it and reinstall audio driver
try this one thanks for using fixya
Jo_chinmay
Apr 04, 2008 | Acer Aspire 5610-4648 Notebook
Acer aspire 4315!
It sounds like you have not properly installed the audio driver. You have to go in device manager and see if you have any question mark in any of the devices or the audio. To go to device manager you hit start then control panel and then click device system and then click device manager.
Jan 16, 2008 | Acer Aspire 5100 Notebook
Acer aspire 4720z audio driver for widows xp home edition sp2
is there any other way to solve the audio problem? after i install win xp sp3 in my acer aspire 5550,i get stuck in installing audio driver.i have download the driver from many website even in acer.com, but still cant solve it..please give me some idea..
Dec 02, 2007 | Acer Aspire 4720 Notebook
Acer Aspire 5315 Notebook Logo
360 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
