Question about Canon imageCLASS D880 All-In-One Laser Printer
Canon Imageclass D880 all-in-one
I went to use the printer and 1 piece of paper wound up on the wheel. I have tried numerous things to clear the paper jamb and I have been unsuccessful. How would I get the paper out of the machine? I have tried pulling the cartridge and the paper is not visable, I cannot see it to take it out. I have tried pulling out the paper tray and, again, the paper is not visable. It's wound up at the wheel were is suppose to feed out of the machine.
  • 2 more comments
  • mrsfoe87 Jan 19, 2008
    I have a paper jam but I have no clue where it is, I pulled out the cartridge, no paper was visible then I pulled out the paper tray-- again no paper is visible either, I have no clue where the jam is. HELP!!!!!
  • Anonymous Mar 07, 2008
    removed most of the jam but cannnot get to the rest that is lodged in the center of the rollers
    removed part of a paer jam but cannot clear rest that is lodged in the center of the roler
  • tpappas Apr 21, 2008
    I had a paper jam. I unjammed the printer now the paper copies crooked and edge is torn. I wonder if it needs to be realigned, or there is still a piece of paper that is jammed and I cannot see it.
    thank you
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 58 Answers
The area you are describing is the fuser exit rollers. Most likely the upper and lower rollers are worn out and the paper jammed there. You will need a technician with the background on repairing this machine to fix it. This is a major repair.
Posted on Jul 29, 2007
Can i use cardstock paper in my canon imageclass d880?
There maybe an adjustment on the rollers for different types of paper grades. If so adjust it for heavier paper weight.
Mar 02, 2012 | Canon imageCLASS D880 All-In-One Laser...
Paper jam in canon d880, Have tried every way to get paper out, but can't. Need to know what to do?
Make sure to blow off the optical device near the print head.
It may not have a paper jam at all.
Apr 07, 2010 | Canon imageCLASS D880 All-In-One Laser...
Canon Imageclass D880 automatic document feeder problems
Clean the ADF rollers and pad with alcohol.
Check to see if your ADF has done over 90 000 copies and if it has, change the ADF pick up assembly only.
Good Luck
Oct 19, 2009 | Canon imageCLASS D880 All-In-One Laser...
Paper jam in front roller of imageclass D880 (about 1/3 inside)
dirty pick up rollers. take the paper tray out and them you will see 2 half moon rollers, clean them with alcaho and you will be ok.
Oct 08, 2009 | Canon imageCLASS D880 All-In-One Laser...
D880 printer won't put toner on the paper (prints blank)
make sure the replaced toner is in good condition and is placed properly in printer refilled toner often alarm about low ink but work properly
Jul 22, 2009 | Canon imageCLASS D880 All-In-One Laser...
Main roller has a piece of paper wraped around it
What "main roller"? the drum? The "Fuser"?...either way, instructions are to detailed to list here.
If you're talking about the drum....just order a new cartridge (easiest solution)
May 13, 2009 | Canon ImageClass D880 Copier
WHERE TO FIND A SERVICE MANUAL FOR A IMAGECLASS D880 DICITAL COPIER
http://www.generalmanual.com/Printers/Canon-imageCLASS-D860-D880-Personal-Digital-Copier-Printer.htm
this is the link for your manual please rate my assistance
Apr 20, 2009 | Canon imageCLASS D880 All-In-One Laser...
Paper jam in canon Imageclass D861 copy machine
Where inside in fixing unit, drum unit,...
It is problem if its fixing unit jam.Best take it to service
Mar 30, 2009 | Canon imageCLASS D880 All-In-One Laser...
Squeeking
The squeeking sound usually is in the fuser area
open the fuser roller area( clear paper jam the rollers are hot wait until it cools down get some spray silicone(similar to wd 40 with a plastic tube to reach small areas spray small amount on any e
xposed gears(plastic ) do not spray the fuser rollers
if you see nay other moving parts give them a light spray
turn back on and see if sound has stopped
If not try to determine when squeeking starts
then spary appropriate area
Dec 29, 2008 | Canon ImageClass D880 Copier
Canon imageCLASS D880 All-In-One Laser Printer Logo
203 people viewed this question
Clive
Clive
old marine
old marine
