Question about Sony KV-32S42 32" TV
Sony kv-32s42 needs help.Tuner problems?
I'm receiving snow and the channels in the upper right hand corner continously evolve from 1-99. By luck or through persistantly turning the tv on and off I can eventually get a local channel ( I'm on an antanae}, and a good picture.Even when I get a good picture the channel numbers in the upper right hand corner still continue to evolve. When I do get a channel I don't dare turn it off or I'll have to start the process al over again! I also can not retrieve the menu, either by the front panel or the universal remote I purchased - made by Sony-. I don't have the original remote. By the way, the blinking lights have changed from five and beyond to ten with the unplugging of the tv if that matters Is this a commom problem? If I can just get the tv to stick to chanel 3 which is not a local channel, I could run everything through the vcr and be happy with my free tv. Can any body help? I'll wait by the mail box in anticipation. Thanks, Grasshoppa
Benimur, Thanks for you reply. Acouple weeks ago I managed to get the tv to stick on channel 3, I haven't turned the tv off since, I just leave it on the blue screen. However. I purchased a playstation last night and it called for turning the tv off to set the player, I cringed but turned of the tv and it onley took me 2 try of turning the tv off and on again to nail channel three, (by watching the the number progression and guessing when it was at channel 3. I believe I have tried your method already, but when I get brave enough again to turn the tv off I'll try again just to make sure. By the way, do they have to be RCA brand cables, and in that case how would I select between video 1 or 2? Thanks again, Grasshoppa
Posted on Aug 29, 2007
    Brigadier General:
  • 6,966 Answers
Hi Grasshoppa, I would venture a guess that your tuner is not at fault but most probably the logic circuits controlling it since as you posted, you can tune > get a good picture but "channel numbers in the upper right hand corner ...." If your intention is to use the VCR and thereafter change channel using the VCR, you may use the Audio/Video input. With an RCA 3 cable connector, connect the (Yellow) Video out, (Red/White) L/R Audio out of the VCR to the Video in &L/R Audio in of the TV. You don't need to set the TV to Ch 3 but rather select Video 1 or 2 or A/V. Hope this be of some help/idea to you. Post back how things are or should you need further information. Good luck and kind regards
Posted on Aug 27, 2007
  • Louie  Role
    Louie Role Aug 29, 2007
    Hi again,
    The RCA does not necessarily mean made by RCA, it refers to a type of connector normally used for video/audio and are very generic.
    Your remote normally would have the buttons for AV1, AV2 or just AV or Video.
    Cheers.
SOURCE:
How can I turn the screen voltage up?
from description you are on the right track--screen con inside will either be on the crt circuit board or on the high voltage transformer, on or the other--lots of the older Sony sets when the picture tube gets weaker need this done.
Dec 15, 2012 | Sony KV-32S42 32" TV
No picture, but sound
tried to hooked up with an air antenna. if you can not get any channel and just a white raster or snow, it could be the tuner get fried.
Jul 22, 2012 | Sony KV-32S45 32" TV
Can anyone offer any suggestions on how to delete/remove titles displaying in the upper left hand corner of my TV screen and right hand corner? For example, if I am watching a program on CITY, the title...
I believe the "Caption Vision" is selected. By pressing the "Display" button on the remote it should toggle through the choices until "Display Off" appears. That should be all.
Mar 05, 2011 | Sony KV-32S42 32" TV
My sony kv-36FV300 will not respond. won't turn off .....or turn stations. The picture is snow...and has a "7" in the upper right hand corner. ....and has "no signal" in lower left corner.
Just wondering if thesmiths860 found a solution to their issue w/ their Sony TV. My tv is doing the same thing i.e. snow, won't change channels and says "NO SIGNAL".
Does anyone have a solution? I don't have the original remote so I can't do a factory reset.
May 04, 2010 | Sony FD Trinitron WEGA KV-36FV300 36" TV
Green numeral in upper right hand corner will not
There should be a button marked i,press this and it should disappear
Dec 08, 2009 | Sony FD Trinitron WEGA KV-27FS120 27" TV
How to turn off channel number displayed in TV screen
Press " i " (info) button on Sony TV Remote so on-screen display will disappear.
Jun 09, 2009 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Bad reception on lower channels
Hello Moeggy,
Tuner of your TV set got defective and need to be replaced. Pls contact nearest Sony service shop for replacement of Tuner.
May 08, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Picture Problem
Your TV's tuner is the problem. 1st thing to try is just to sesolder its connections to the main circuit board. If that doesn't work replace the tuner. Also could put a meter on the power coming into the tuner and see if it is drooping in sync with your picture. Tuners are not that expensive to replace.
Jan 06, 2008 | Sony FD Trinitron WEGA KV-32FS100 32" TV
No picture or sound
If you see only snow and the words "NO SIGNAL" are displayed, and you know that you have the set hooked up to a good signal and the TV is set to the right channel, it means that your tuner has stopped working and needs to be replaced. First, though, make sure your signal is good. A good way to test this is to hook the TV to a good VCR, put in a good pre-recorded tape and hit play. Tune the TV to channel 3 (or 4) and if it is still all snow, have the tuner replaced by a qualified tech.
Sep 03, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Open Questions:
See all Sony KV-32S42 32" TV Questions
Sony KV-32S42 32" TV Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
