Question about KitchenAid Dishwashers
Water keeps running into dishwasher causing overflow
When the dishwasher is turned off water is still running into the dishwasher from a hole in the side of the dishwasher causing it to fill and overflow. The hole has a plastic piece witrh a plastic nut. I shut the water off under the sink to the dishwasher and the water stopped running out of the fill hole.
  • Pam Breech Jan 29, 2009
    The plastic float is working. Water runs into the dishwasher unless I turn off the water supply to the dishwasher under the sink. It might be the water inlet valve - does anyone know if you can clean these or do they have to be replaced?
  • 3 Answers
Had the same problem with my Bush dishwash..fixed it by pushing the float up and down a few times to break up the salt etc in the plastic float chamber now works great. ken Torrevieja Spain casadersas184@gmail.com
Posted on Aug 27, 2012
I had a diswasher with thils problem several years ago. The problem was wiith the plastic float at the bottom. It had hardend greese buildup that kept the float from moving freely. Removing the float and cleanning fixed the problem.
Posted on Jan 29, 2009
Hi... I just bought Electrolux Dishwasher ESF2433W. When i first time turn it on, light at "Normal" button keep on flashing with beeping sound. After checking the trouble shooting manual, it actually refer...
E4 Overflow
Sometimes during trasport it is possible that styrofoam float mechanicaly activated overflow microswitch. So, you should check complitely overflow system.
At any time, if overflow micro-switch act and keep for longer than 2 seconds, the E4 would occur. When E4 occurs, the drain pump will run until flowmeter keep motionless for 2 minutes (if the model with the pressure switch (83/63),drain pump would run till the pressure switch reset and continue draining for 60 seconds.) and all the other components will be stopped immediately. At the same time, the buzzer will alarm for 30 seconds and error 4 will be shown. Note: Priority level of E4 is the highest. E4 operation is valid after other error operations have done. When E4 operation has done, all the others are invalid.
Dado
Feb 20, 2015 | Electrolux Dishwashers
The water keeps running inside the dishwasher slowly like a valve will not close all the way, water will overflow if I dont turn it off
You are on the right track...On Comerical Dishmachines this happens when mineral deposits build up in the rinse or fill solenoid blocking it from closing all the way. We install a rebuild kit and delime the solenoid itself.
On a home machine this is not really a practical solution due to their construction.
Best thing to do is locate the valve and replace it in as they are often plastic sealed units on household dishmachines.
In addition your machine should have an overflow drain hole somewhere which may be clogged with food or debries. Snake it whith a single strand of thick copper wire.
Good Luck..
Dec 09, 2009 | Hotpoint Dishwashers
I was an idiot and put dishsoap in the dishwasher because I ran out of regular dishwasher soap. Now the dishwasher keeps overflowing with bubbles. I keep wiping all the bubbles and extra water out but...
you must rinse all the soap out the best way is to make the drain hose lower than the tub of the washer and run the garden hose into the drum and slowly rotate the drum as you rinse it out after a complete rinse you should run a rinse and spin cycle a few times and you should be fine.
Aug 27, 2009 | Dishwashers
Dishwasher overflows
Sounds like you've got a problem with the water intake valve(s). If it takes on water without water running in the sink, that is where I would look. If it happens when you use the sink, then I would also check your drain hose placement
Jun 22, 2009 | Dishwashers
Water refilling after dishwasher is cycled off
Leave the D/W door open and make sure the water is not coming from the water inlet .
It may be oozing up from the bottom when you run water in the kitchen sink.
Does your dishwasher vent through a counter top Y siphon. It could be clogged causing water to re-enter the D/W.
Feb 10, 2009 | Bosch 24 in. SHU53 Built-in Dishwasher
Leak from dishwasher fill funnel
Hi . the air gap is required by law, to have it there.to stop water in the tub, to end up in your water system, which would never happen. try setting the pressure down, and use the dishwasher. it should work fine . turn down taps ,till it stops leaking . should be ok
Oct 06, 2008 | Kenmore 15129 Built-in Dishwasher
Sears Kenmore Automatic Dishwasher: Models No. 14041 /14045 /14045... Problem:
Many dishwasher have their drainlines tied into under sink disposers. If a person caps the sink drain while dishwasher is running, it can back the water back to the washer keeping dishes dirty and backing up water
Jul 05, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Water keeps running will not shut off causes and overflow
If it only overflows while the washer is running, check the pressure switch, or water level switch. The hose may have come loose, or could have a hole in it somewhere. Otherwise the switch may be stuck or may need to be replaced.
If it's overflowing when the washer is off (i.e. in the middle of the night when there is no laundry in it), then check the water valve.
Mar 26, 2008 | Hotpoint VBXR1090B Top Load Washer
Dishwashers Logo
452 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
