Question about Minolta EP4000/5000 CS/PRO Copier
My device show C0E01 on the display - Minolta EP4000/5000 CS/PRO Copier
  • mellat_adny Jan 29, 2009
Posted on Jan 30, 2009
Tried to reset DMPBD79last step it shut off it wouldnt turn back on I just get a blinking redlight.
This is for a diff. model but give it a try, they may be diff. #'s showing up then what pops up on screen then is listed below.
  1. Remove any disc from the drive and switch the device to stand-by
  2. Press and hold [OK], [BLUE] and [YELLOW] simultaneously on the remote control until the device turns on and shows "00 RET" on the display
  3. Repeatedly press [RIGHT] on the remote control until the device shows "08 FIN" on the display
  4. Press and hold [OK] on the remote control for at least 3 seconds -> The device will reset itself to factory condition and show "HELLO" on the display
  5. Press [POWER] button on the remote control -> The device will shut down
May 02, 2016 | Panasonic Televison & Video
How can i unlock screen on motorola droid bionic because i forgot passcode?
This might help
Droid Bionic Stuck on too many unlock attempts Verizon Wireless Community
  • Power the device off.
    • Press and hold the Power button then select Power off
    • If the device isn't responding Remove / replace the battery
  • Press and hold Volume down and Volume Up, the press Power
  • Display shows Available boot modes
    1. Normal powerup
    2. Recovery
    3. AP Fastboot
    4. BP SBF Flash
    5. BP Only
    6. AP BP USB Bypass
    7. BP Tools
  • Use volume down to scroll to "Recovery", press Volume up to select
  • Once display shows Android triage screen, press Volume up & Down at the same time
  • Display shows Android Recovery
  • Options are:
    1. Reboot System now
    2. Apply Update from SDCard
    3. Wipe data / Factory Reset
    4. Wipe Cache partition
  • Use volume down to scroll to Wipe Data/factory Reset, press power to select
  • Display shows Confirm Wipe of all user data - This can not be undone
  • Use volume down to scroll down to YES - Delete All data - Press Power to Select
  • Device will perform format wipe
  • Display then shows Android System Recovery
  • Ensure reboot system now is selected then press the Power button to select
Oct 16, 2015 | Motorola Cell Phones
I want to display my volume icon
Dear Costmer,
please Followup ,
To enable the display of the Volume icon, follow these steps:
  1. Click Start, and then click Control Panel.
  2. Double-click Sounds and Audio Devices.
  3. Click Show volume control on the taskbar.
  4. Click OK.
When you have the new desktop features of Windows XP enabled, follow these steps:
  2. Click Sounds, click Speech, and then click Audio Devices.
  3. Click Sounds, and then click Audio Devices.
  4. Click Show volume control on the taskbar.
  5. Click OK.
amit.mishra.lenovoservice@gmail.com
Feb 13, 2015 | Toshiba Satellite Computers & Internet
Error code c0E01 minolta ep4000
C 0E01 - main erase lamp LA3 abnormality.The erase lamp located in area of OPC drum.2_16_2013_7_26_57_pm.jpg2_16_2013_7_29_23_pm.jpg
Feb 15, 2013 | Minolta EP4000/5000 CS/PRO Copier
For the last four days,i have been getting a message that reads "waiting for gps signal. the tom tom device displays a screen that shows 5th ave. in new york.
I recommend a few things, one, see if it has a reset button, and reset the device. This could help that problem. OR two, and this one may be better if you have alot saved, poke around in the settings and see if it got switched somehow to "display" mode. In display mode GPSs show a given location and do not generally accept signal. Finally, if all else fails, get out the USB cord, go to the website, register the device, and download all alvailable firmware OS and map updates. This will probably fix it.
If you need more help let me know I CAN help with this problem.
Jim
Aug 05, 2009 | GPS
Vertical lines showing. it is an Optoma HD70
If the lines present in the menu when displayed this indicates device mounting troubles. Possibly loose in socket. If you change aspect of displayed image do the lines move, if they do, its an electronics problem, if they are constant, and nothing is displayed in the lines. Tighten device in socket, or seek professional service.
Jul 07, 2009 | Televison & Video
Code problem
CALL THE NEARST DEALER OR GO ONLINE AND TYPE THE MANIFATURE NAME ONLY AND LOOK THREW THE LIST OF SUBJECT AND CLICK ON THAT LINK
ROD
Jan 29, 2009 | Minolta EP4000/5000 CS/PRO Copier
Computer doesn't detect printer on installation
is it a usb printer? if so follow this:
Device Manager displays only non-Plug and Play devices, drivers, and printers when you click Show hidden devices on the View menu. Devices that you install that are not connected to the computer (such as a Universal Serial Bus [USB] device or "ghosted" devices) are not displayed in Device Manager, even when you click Show hidden devices.
  1. Click Start, point to All Programs, point to Accessories, and then click Command Prompt.
  2. At a command prompt, type the following command , and then press ENTER: set devmgr_show_nonpresent_devices=1
  3. Type the following command a command prompt, and then press ENTER: start devmgmt.msc
  4. Troubleshoot the devices and drivers in Device Manager.
    NOTE: Click Show hidden devices on the View menu in Device Managers before you can see devices that are not connected to the computer.
  5. When you finish troubleshooting, close Device Manager.
  6. Type exit at the command prompt.
    Note that when you close the command prompt window, Window clears the devmgr_show_nonpresent_devices=1 variable that you set in step 2 and prevents ghosted devices from being displayed when you click Show hidden devices.
If you are a developer or power user and you want to be able to view devices that are not connected to your computer, set this environment variable globally:
  1. Right-click My Computer.
  2. Click Properties.
  3. Click the Advanced tab.
  4. Click the Environment Variables tab.
  5. Set the variables in the System Variables box.
Dec 24, 2008 | Brother MFC-640CW All-In-One InkJet...
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
