Question about Ricoh Aficio 3025SP Copier
Ricoh aficio 3025 says PLEASE WAIT and stays in this mode forever
Machine says please wait and wont come to ready unless shut off and turned back on. Never seen this befor and I work on alot of these. Thanks for the help
    Sniper:
  • 86 Answers
Check for SC codes.
Check the following probabilities;
  1. HDD faulty.
  2. Contoller NVRAM defective.
  3. Defective contact in flat cable 45pin connecting IPU board (CN100) to SBCU (CN301). Reconnect properly flat cable.
  4. Download latest firmware.
Good luck and please rate me, thanks.
Posted on Jan 29, 2009
  • 541 Answers
This can slso be caused by a bad or dirty themistor in the fuser. you need a tech to come out and test the thermistor, then=mistors. they check the heat in the fuser if the heat is tooo low your machine can be stuck in warm up mode.
Posted on Sep 27, 2009
When copier complits one job it remains on please wait all the time. no sc nomber shown
hi there,replace the potensial sensor in the drum unit.its the silver one which sit inside,on top.
Nov 12, 2014 | Ricoh Aficio 2060 Lower Fuser Pressure...
When I turn the copier on it stays in warm up stage forever
that could be a hard drive problem lets try the following switch off the machine, while holding down 8+0 switch on the machine when the machine is in test mode key in 690 press start or initialize the machine will say please wait when its finished switch off the machine wait a few seconds and switch on if it does not go ready the hard disk drive should be replaced
Apr 04, 2011 | Toshiba COPIERS E-STUDIO 600 Copier
MY RICOH AFICIO MP C6000 IS SHOWING AN ERROR CODE SC326
That is a "second laser synchronization error". Try this: Hit the yellow button, press numbers 1, then 0, then 7, then hit the orange key. When it goes into SP mode, turn off the copier and unplug it. Wait 15 seconds then plug back in and turn on. If that does not fix it then you need to call a tech to service the machine.
Mar 05, 2011 | Ricoh Aficio 1035 Copier
Ricoh af2027 please wait with a wrench no code
Hi that normaly indicates the there is something wrong with the HDD. open the back of the machine and unplug the HDD. Swith the machine on. If it turns on the HDD is faulty. The machine will work without the HDD but you will not be able to use the doc server. To fix the HDD plug it in to a PC and initilize it. (right click my computer, manage, disk management, right click on drive, initilize. Put it back in the machine.) Should solve the problem.
Apr 27, 2010 | Ricoh Aficio 1035 Copier
My ricoh aficio 2232c was unplugged and when I plugged it back in it keeps saying Please Wait across the screen and doesn't do anything else. Please help
If no error code comes up then you have a hard drive error in your Print controller.
Remove the back cover (unplug machine) remove the cover for the controller (controller is in upper right on rear side of machine and disconnect the hard drive.) Plug machine back in and see if it comes to ready. if so replace the drive, if not controller is bad.
Jan 19, 2010 | Ricoh 6513 Copier
I have a ricoh Aficio 3025 all in one, it is now giving me a fault code of SC543 please advise
its temp. or fixing error. try to clear it in service mode.
yellow 197 red when it says SERVICE MODE turn off and on machine, if it does not help you need to call service to replace thermistor, or lamp, or rise temp. ,or ...
Nov 12, 2009 | Ricoh Aficio 3025 All-In-One Laser Printer
My machine show c 210
Please specify the machine model,in the Ricoh 1035 not exist the C210 error code.
If your machine show CC201=When the paper jam condition is not reset for 10 minutes the code is automatically generated.For reset please enter in the SP mode turn main switch OFF,unplugged and wait 10 sec.Plugged and turn ON the power switch.
Sep 05, 2009 | Ricoh Aficio 1035 Copier
Ricoh sc 551
This is a fuser temp. problem -- must reset and/ or replace thermistors.
Press clear modes button then 1-0-7 then hold down the clear stop button.
When display changes touch copy sp modes.
Turn may power off and wait about 30 sec.
Turn power on.
If the machine comes to ready you are ok for now.
If code returns you must replace thermistors.
If you need to replace thermistors, contact me and I will get you part numbers and instructions.
Jan 15, 2009 | Office Equipment & Supplies
Richo 2232c
Make sure all the covers are closed on the copier. Check for any broken magnets, door switches, or sensors.
If that doesn't work you should contact a Ricoh representative in your area to do further troubleshooting tests on your equipment.
Jan 13, 2009 | Ricoh Aficio 2015 Copier
Ricoh Aficio 2015
Pressure roller warm up error. Usually means that the fuser roller isn't at the right temperature when you turn the copier on.
Try turning the copier completely off. Wait 30 seconds. Turn it back on again and see if it goes away.
If not a technician should look at the fuser section to see what the problem is.
Jul 15, 2008 | Ricoh Aficio 2015 Copier
Ricoh Aficio 3025SP Copier Logo
1,373 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Bernard D'Souza
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
