Question about Nintendo Rock Band for Wii
Yellow drum pad just stopped working
The yellow drum pad just suddenly stopped working
  • 6 more comments
  • Anonymous Mar 14, 2009
    Same problem. The yellow drum pad just stopped working.
  • Anonymous Mar 21, 2009
    The orange pad stopped working, swithced them over. Defintely the right symbol pad.
  • Anonymous Mar 28, 2009
  • Anonymous Apr 04, 2009
    orange symbol stop working
  • Anonymous Apr 20, 2009
    I have the same problem with my orange symbol. Suddenly stopped working
  • Anonymous Apr 27, 2009
    yellow stopped working, sensor plate might be cracked
  • sheliarobert May 01, 2009
    My yellow symbol pad stopped working
  • Anonymous May 09, 2009
    yellow pad stopped responding
  • 32 Answers
START WITH CHECKING THE 2 WIRES INSIDE THE SET HOUSING UNDER WHERE THE YELLOW PAD ATTACHES. 1 WIRE PROBABLY NEEDS TO BE REATTATCHED WITH SOLDER.
Posted on Jul 01, 2009
My friends brakes just all of a sudden stopped working on there 98 cavalier. The pads are good there is brake fluid any ideas what the problem is?
check all brake pads are good
check disks and or drums are ok
check brake pipes are ok
check master cylinder is ok
check wheel cylinders are sealed, i.e. not leaking and functioning positively
ensure the system has no air in it
check that the servo works
Jul 19, 2015 | Cars & Trucks
Printing just fine in black, all of a sudden I am getting streaks across the top of my paper. Then it will stop. After about a 100 or so it will start again. Does anyone know if you change the mono type to...
Yes in the Iqueue advance printing part click it from color to mona and remove the cyan magenta and yellow drums and that will prevent the black toner for hitting the drums and marking before it gets to the fuser
Oct 18, 2011 | Xante Ilumina Digital Color Press Printer
Yellow drum pad stopped working, only had these for 5 months=(
You need to replace the piezo sensor, you can get them at radio shack really cheap. $2. The same thing happen to me, I pulled the drum pad off and the sensor was totally cracked, I guess from hitting it too hard. Just unsolder old ones and solder new one on.
Aug 21, 2009 | Nintendo Rock Band for Wii
1999 GMC Safari brakes grab mostly in sudden stop situations. Replaced the front pads still same issue
try having the rear drums resurfaced. and clean and deadjust the rears a bit. the rears are doing the grabbing
Aug 04, 2009 | 1995 GMC Safari
World tour drum pad won't respong on old ps2 console
Hi-
You can repair your drums actually for pretty reasonable!
Here is a link to a video on how to repair the drums yourself,
you'll have to purchase the cable yourself, but you can find one if you search eBay for "guitar hero drum cable"
I hope this helps!
Jul 12, 2009 | Sony PlayStation 2 (PS2) Console
Yellow pad on drums does not want to work this is the second time
If the drumset for the Wii is similar to the drumset for the Xbox 360, then there will be a small cord connecting into the orange and yellow pads. Make sure these are plugged in all the way and are not being pulled at. It could also be that the cord could have been damaged. If that has happened, the only solution I know of is to buy a new set of drums.
Apr 24, 2009 | Activision Guitar Hero World Tour Guitar...
Drum set for xbox 360 rock band 2
to sync: hit the sync button on the drum set and the xbox at the same time, you may have to hold the one on the set.
other problem: make sure you have good batteries in it, make sure the set is synced with the television, go into the freeplay mode under the drum trainer and do a drum roll on your yellow pad- if it skips some notes you either have to deal with the bad pads or you can send it in or get a new set all in all
Mar 16, 2009 | MTV Games Rock Band Bundle for Xbox 360
Rock band for WII, blue drum pad stopped working
CHECK INSIDE DRUMSET HOUSING UNDER WHERE THE BLUE PAD ATTATCHES. THERE SHOULD BE 2 WIRES CONNECTED WITH SOLDER. IF 1 OR BOTH HAVE COME OFF THEY WILL NEED TO BE REATTATCHED WITH SOLDER.
Jan 17, 2009 | Nintendo Rock Band for Wii
Noisey during wash cycle
sounds as if your brake pads have broken, try removing the lower acess panel you should see the broken pads lying somewhere under the machine(at least pieces of them), i bet if you spinn the machine the drum doesnt come to a complete sudden stop after lifting the top( it should if the brakes are engaging
Sep 26, 2008 | Amana 3.2 cu. ft. Top-Load Washer
Hard pedal low stopping power
First you need to check the brakes lines and the brake pads must be replaced on your car they may be worn out........ Get it checked from the local service center........
May 30, 2008 | 1991 Buick Regal
Nintendo Rock Band for  Wii Logo
537 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
