Question about Whirlpool RBD305PD Electric Double Oven
Oven display problem
We had a power outage and now my oven will not work. it displays "e1" (in red) "F5" (in green). Anyone know what this means or how to fix it? Thanks!
  • 2 more comments
  • Mike Lincoln Aug 03, 2007
    I cut the power but eventually the error code came back. I at least appreciate the answer. Looks like I'm calling my builder!!
    Thanks
  • WPsucks shit Dec 28, 2007
    I also just had a power outage, and am having the exact problem...whirlpool is garbage!!!!! It is always nice to pay $2000 for a oven...use it 3 times and have it break.
  • Anonymous Jan 07, 2008
    I looked at my oven and notice that the control panel is not lit up the ovens work how can i get the control panel to work. this just happen today. The oven is not even two years old. I have turn the curcuit braker off and back on but it didn't help
  • klawson411 Jan 06, 2009
    After a power outage the display panel will not show time, but the timer still works. How do I get the digital panel to display the time? There is a"PF" showing on the panel which I assume stands for power failure.
On the door the inside glass cracked. how do i take the oven door off to replace the glass
Posted on Aug 25, 2008
    President:
  • 331 Answers
F5-E1 is a fault code denoting a failed door lock/latch mechanism. Before having it replaced, go outside to you main breaker box and turn the power off to it for a couple of minutes... try to reset the controller. If the fault code appears again, the door lock/latch mechanism needs to be replaced.
Posted on Jul 30, 2007
SOURCE:
My 2001 Kenmore oven error says ``E1 -F5-`` What does that mean
The E1- F5 error is a door lock error. The control has likely failed. Sometimes when you disconnect power to a range and reconnect it the electronic range control gets messed up.
You should disconnect power for 15 seconds and reconnect and see if that helps.
If it doesn't fix the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.Then turn off power again for 15 seconds and back on. Sometimes these work, but if the control has failed it won't make any difference.
Thank You and please rate my answer if it was helpful..
Jun 19, 2011 | Kenmore Ovens
After a power outage my oven is unable to work
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.(((((((((
Jun 06, 2010 | KitchenAid Architect II KEBK206SSS...
Oven gets a "fault" shortly after putting power back on.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.&^%#TR
May 30, 2010 | Whirlpool GBD307PDS Electric Double Oven
Replaced control panel on whirlpool electric double wall oven. e1 f5 code pops up,fault code says check door latch. checked switches on latch with meter check ok.what to check next
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE [email protected]#$RED
Feb 28, 2010 | Whirlpool RBD275PD Electric Double Oven
What does an E1 F5 error on a Kenmore stove mean.
Dec 31, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
My whirlpool accubake SC465 has the code"E1 F5". What does that mean?
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!#@EWSF
Dec 04, 2009 | Whirlpool RBS305PDS Electric Single Oven
I used the self cleaning oven and now it wont unlock and it keeps beeping f5, e1 what does this mean and how can i unlock the oven?
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.&URTGF
Mar 27, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Whirlpool Gold Electric Oven F5 E1 code on bar code
For some reason I get the same error code every time we have a power outage. If you push and hold the "lower off" button for about ten or 15 seconds it will unlock and reset. Hope this helps.
Jan 26, 2009 | Whirlpool GBD307PDS Electric Double Oven
Lost power now oven won't do anything...
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.^^^^^
Aug 07, 2008 | KitchenAid Architect Series KEBC208KSS...
E1 and f5 error/Door locked
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!!
Dec 22, 2007 | KitchenAid KEBC207 Electric Double Oven
Whirlpool RBD305PD Electric Double Oven Logo
376 people viewed this question
Top Whirlpool Ovens Experts
Craig Butler
Craig Butler
Steve Allison
Steve Allison
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
