Question about West Bend 41090 Bread & Dough Maker
Breadmaker not kneading
I, my breadmaker has not been used much, but is out of warrant and stoped working. The symptoms: When I press start, the paddles won't turn and a clicking sound is heard at intervals as if the heating element is coming on or off. Thanks to anyone who helps out.
  • 1 more comment
  • Moritz Lehmann Jul 27, 2007
    Thanks for your suggestions, but the machine never starts kneading.
  • wysperdwytch Nov 27, 2007
    i don't have this model but an older one with the same problem..... it's a 41030 and i keep hearing clicks and the light that i guess is the power light is red not green and the paddle doesn't swish.....there is a little icon that says "rest" and i'm not sure if it's heating or not....... any help would be appreciated....... j.b.
  • eerags Mar 13, 2008
    hi, i have a different machine but basically the same problem. i know that it usually doesn't start kneading until it is preheated but after about 10-15 mins it starts making a kind of jammed sound but nothing is even trying to move. i have tried removing everything and the holder for the pan in lose but not moving.
A lot of breadmakers function exactly as you describe functioning normaly. The heater comes on to warm the ingredients to about 110 degrees. This heating takes place for 10, 15, or 20 minutes before kneeding starts. mhbtall@juno.com
Posted on Jul 27, 2007
Raisin & nut Dispenser is not retracting after dispensing fruit etc
The trapdoor feature on bread machines often malfunction. Once it starts happening the best thing to do is just add your raisins, nuts, etc. yourself about halfway through the 2nd knead. If you have one of the machines that just has one long first knead then add them at 7 minutes before the end of the knead. daryl441@msn.com
May 11, 2014 | Panasonic SD-2501WXC Automatic Breadmaker...
That usually means your drive belt has snapped (broken) Does that model have a removable plat on the bottom of the machine?
Feb 08, 2013 | Morphy Richards Breadmaker Kneading Blade...
Breadmaker wont knead
if after waiting at least 30 mins after pressing Start and your machine still isn' kneading is your breadmaker humming but not turning the paddle?
Jan 26, 2013 | Breadman TR777C Instruction Manual PDF...
Breadman Pro TR875 is stuck & will not start up to knead the dough. Timer is hi-lighted & shouldn't be. No pushing of any buttons will not clear & start over
Addressing Power-up/Start-up Issues:
  1. Unplug the breadmaker.
  2. Confirm the power source you're drawing from is live using a blender, toaster, etc.
  3. Plug the breadmaker in, unplug it, then plug it in a second time.
    1. Some models have a built-in off/on toggle power switch. Turn it to the ON position.
    2. Some models confirm power by making and audible tone when plugged in.
    3. Some models have a colored light and/or a lighted display screen that lights up.
    4. Some models require you press down on the Stop button until the unit powers up.
E. Some models require you press down on the Start button until the unit powers up.
F. Some models require you press down on the Select button until the unit powers up.
G. Some models require you press the Select button first before pressing the Start button.
In the end, were you able to confirm that your breadmaker is receiving power?
No. Sorry to hear that. Have the breadmaker serviced by a small appliance repair shop or simply discard it.
Yes. Fantastic! Now reboot the breadmaker's electronics by pressing down on the Stop button until you receive a visible and/or audible confirmation, usually within 1 to 5 seconds. Note: Some models require you press down on the Start button instead. And yet a few others require you press down on the Select button instead.
Often the + and - Delay Timer buttons are pressed by mistake, delaying Start by up to 12 hours. If you suspect this handy feature has been engaged accidentally, you'll need to reboot the breadmaker's electronics.
Note: All breadmakers use a belt and pulley system. If your breadmaker powers-up but the mixer won't turn during the kneading cycles, your timing belt is probably broken. You'll need to disassemble the breadmaker to visually confirm. The belt and pulley assemblies are located at the bottom of your breadmaker.
Did this answer help? Hope so. Please rate it as soon as you can. Thank you. r53w6t
Jun 07, 2011 | Breadman TR900S Bread Maker
West Bend Bread Maker model 41056 does not start. When machine is plugged in, LED displays a time but buttons do not work and red light does not go on. (Pan was in machine and anchored.)
Power-Up/Start-Up Issues:
    1. Some models have a built-in off/on toggle power switch. Be sure it's turned on.
    2. Most models confirm power by making an audible beep when plugged in.
    3. Most models have a colored light and/or a lighted display screen that lights up.
    4. Most models require you press down on the Stop button until the unit powers up.
G. Many models require you select a baking mode by pressing the Select button before the pressing the Start button.
Q: In the end, were you able to confirm your breadmaker is receiving power?
No. Sorry to hear that. Have it serviced by a small appliance repair shop or simply discard it.
Yes. Fantastic! Now reboot the electronics by pressing down on the Stop button for 1 to 5 seconds. Note: A few models require you press down on the Start button instead. And even fewer require you press down on the Select button instead.
Often the + and - Delay Timer buttons are pressed by mistake, delaying Start by up to 12 hours. If you suspect this handy feature has been engaged accidentally, you'll need to reboot the breadmaker's electronics. See reboot directions above.
Did this answer help? Hope so. Please rate it as soon as you can. Thank you. 465ygbea
Jun 07, 2011 | West Bend 41053 Bread & Dough Maker
Need kneading blade for old Regal auto breadmaker K6773
Nope, haven't solved the problem yet. I got into the wrong category of breadmaker: mine is a regal K6773 "Automatic Breadmaker."
Dec 16, 2008 | Regal Ware K6725 Kitchen Pro Bread Maker
Need kneading blade
I had great success in finding what I wanted for my breadmaker at http://breadmakerpartsemporium.ioffer.com/. They have manuals and parts for most breadmakers at very reasonable prices.
Nov 18, 2008 | Kitchen Appliances - Others
Kitchen Appliances - Others Logo
300 people viewed this question
Top West Bend Kitchen Appliances - Others Experts
Jim Goldsmith
Jim Goldsmith
Irene Tulloch
Angel Joseph Jr.
Angel Joseph Jr.
Are you a West Bend Kitchen Appliances - Other Expert? Answer questions, earn points and help others
