Question about Lexmark X2350 All-In-One InkJet Printer
PC not reading printer
I am using Windows XP and my PC is not communicating with the printer. I am using a USB cable. When I go to print a test page a window opens up saying no communication with printer.
  • jckvalatie Mar 09, 2009
    I have used the Lexmark X2350 for several years and replaced the cartridge many times. The time, I printed the alignment page and scanned it in as directred. But I couldn't print anything after that. I keep getting "the printer is not communicating.....' message and I have turned everything off and on, unplugged and replugged the UBS and power cables, checked to make sure they were properly plugged in at the outlet and computer, over and over. Still won't print. (It's just connected to my personal computer, nothing fancy. I would love help!
  • 102 Answers
With the Lexmark printers communication subsystem you MUST let the driver ask for you to plug in the printer. DO NOT plug the printer into the USB port until told to do so.
To fix a fouled install:
(1) Uninstall the Lexmark drivers in Add Remove Programs
(2) Shutdown the computer
(3) Disconnect the printer from the USB port
(4) Restart the computer
(5) Run the Driver Installation software
(6) Cancel ALL attempts by windows to auto install the printer
(7) When the software asks for the printer connect it and continue
Posted on Feb 05, 2009
Printer will not communicate with the computer
1. Walk over to the printer and print a test page directly. The procedure for printing a test page will vary from model to model, so you may need to consult the user guide that came with your printer. For most network printers, you can print a test page by navigating the "Information" menu on the control panel and choosing "Print Configuration" from the menu. For many desktop printers, you can print a test page by holding the power button until the page begins to print. If you can print a test page from the printer, but not from the computer, you know there is a communication problem between the printer and the PC.
2. Remove the printer cable from the back of your printer and the back of your computer. After the cable has been removed, carefully put the cable back into place, making sure that the printer cable is tight. If your printer uses a parallel cable, be sure that it is fully seated on the back of the printer and on the computer. If you are using a USB cable for your printer, be sure that the tab is fully seated in the computer, and that the square end of the cable is firmly connected to the printer.
3. Power down the printer, the restart your computer. Click on the "Start" button and choose "Control Panel" from the menu. Double-click the "Printers and Faxes" icon, locate your printer, right-click on it and choose "Properties" from the menu. Click on the "Print Test Page" button to send a test page to your printer.
4. Look at the network card on your network printer to see if there is good communication between the printer and the network. You should see a flashing green light on the network card. If there is no light--or if the light is amber or red--the communication is not happening. To test the network communication, remove the network cable from both the network cable and the network port on the wall, then reseat the cable and check the communication again. If the problem remains, you will need to remove and replace the printer's network card.
Aug 10, 2012 | Lexmark X4650 InkJet Printer
Problem printing with IBM 4610 TF6
It can be a connection problem, since the printer and the computer are not communicating, probably the cable is bad, so if you have a different cable that we can try that will be better so we can check if its only a cable problem ...
Hope that helps......
Aug 28, 2008 | IBM 4610 TG4 Thermal Label Printer
My printer refuses to print. The Red Status light came on so I checked and found there was a paper jam - cleared that. Can get green light to come on if I press the job cancel button but still cannot get...
Perform a Factory Reset
Turn the printer power switch OFF on the right side of the printer. Check that the front cover is closed.
Turn the printer power switch ON while holding down the GO button until the Toner, Drum, and Paper LEDs are lit.
Release the GO button. All LEDs will be off.
Press the GO button 8 times. The Ready LED will flash briefly while the printer is reset. After the printer is reset the Ready LED will be lit.
Print a Test Print Page
Print the Print Settings by pressing the GO button three times.
- If the Print Settings pages do not print, check for alarm lights on the printer. Clear the printer error before trying to print again.
- If the Print Settings pages print, the problem is isolated to printing from your computer. Verify the printer cable connects from the back of the computer directly to the printer. If the cable has become disconnected, loose, or connects through another device, the printer may not be able to print.
Check the Printer Driver Properties
Follow the instructions below based on the operating system installed on your computer.
Windows 7:
Click on the Windows icon => Control Panel => View Devices and Printers.
Right mouse click the Brother printer. Left click See What's Printing. The print queue will open. If print jobs are listed in the printer queue, click Printer (at the top of the window) and click Cancel All Documents to delete the pending print jobs. Click Yes to confirm deleting the print jobs.
Click Printer at the top of the window again. Make sure that Pause Printing and Use Printer Offline are not check marked. If either setting is marked, click on the check mark to remove it.
Click Properties from this Printer menu list.
Click the Ports tab. Verify the correct port is selected (LPT1 is using a parallel cable and USB is using a USB cable). Remember to click Apply if you select another port.
Click the General tab and Print Test Page button. The Windows test page should now print.
- If the Windows test page prints, try printing from a program.
Windows Vista:
Click on the Windows icon => Control Panel => Printers or under Hardware and Sound click Printer.
Right mouse click the Brother printer. Select Run as administrator and left click Open. The print queue will open. If print jobs are listed in the printer queue, click Printer (at the top of the window) and click Cancel All Documents to delete the pending print jobs. Click Yes to confirm deleting the print jobs.
Windows XP and 2000:
1. For Windows XP Professional, click on Start => Printers and Faxes.
For Windows XP Home Edition, click on Start => Control Panel =>Printers and other hardware => Printer and Faxes.
For Windows 2000, click Start => Settings => Printers.
2. Double-click the Brother printer to open the print queue. If print jobs are listed in the printer queue, click Printer (at the top of the window) and click Cancel All Documents to delete the pending print jobs. Click Yes to confirm deleting the print jobs.
3. Click Printer at the top of the window again. Make sure that Pause Printing and Use Printer Offline are not check marked. If either setting is marked, click on the check mark to remove it.
4. Click Properties from this Printer menu list.
5. Click the Ports tab. Verify the correct port is selected (LPT1 is using a parallel cable and USB is using a USB cable). Remember to click Apply if you select another port.
6. Click the General tab and Print Test Page button. The Windows test page should now print.
Nov 01, 2010 | Brother HL-5240 Laser Printer
My Lexmark x125 all in one only prints blank pages
configure the proper port for the printer if you using usb cable for printer select the usb port in the properties of the printer ......
check the port you configure to printer
Oct 06, 2009 | Office Equipment & Supplies
LexmarkX74-75 Communication Not Available
Fix this Error - use an advanced registry cleaner for Windows that allows you to safely scan, clean, and repair registry problems with a few simple mouse clicks. Problems with the Windows Registry are a common cause of Windows crashes and error messages. By using PC tune-up utilities such as registry cleaners regularly, your system will be more stable, your software will run quicker, and your operating system will boot faster.
http://www.errorfixreviews.org/
Good luck
Jun 22, 2009 | Lexmark X75 All-In-One InkJet Printer
Lexmark 1200 Series
unplug your usb cable,uninstall printer then reinstall
Nov 09, 2008 | Lexmark X1270 All-In-One InkJet Printer
RX620 wont communicate via powered USB hub.
on a windows system, go to printers and faxes, delete all icons there. unplug the printer, reboot your computer, then as soon as your computer is up, connect the usb cable... now wait.....
after about 5 mins, check printers and faxes if it has an icon for your printer, if it does then print a test page, if it does not show an icon, try another cable, try another usb port or try it on another computer entirely...
Sep 05, 2008 | Epson RX620 All-In-One InkJet Photo...
Windows XP will not recognize Brother HL 2040 Laser printer
you could try this: unistall the HP printer driver first, uninstall the brother driver , restart pc, load brother driver with the usb cable unplugged from printer. Software will prompt for the cable to be connected to printer
Apr 10, 2008 | Brother HL-2040 Laser Printer
Continuous garbage text when connected to pc
In reading this HP forum I have found many other LaserJet 1100 owners who are trying to do the same thing as you.
Many of them recommend various cable solutions from Sewell. When you contact Sewell, make sure to specify your printer model, and ask what specific cables and/or adapters you need to make it work vis USB. They sound quite knowledgeable, and seem to have dealth with this before.
Mar 06, 2008 | HP LaserJet 1100 Printer
Lexmark X2350 All-In-One InkJet Printer Logo
192 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
