Question about Dell Latitude D430 Notebook
Dell Latitude D430 not powering on.
I have an AC adapter that has a light on it when plugged into a power source. But when I plug it into the computer the light goes out and the laptop won't power on, and I have to unplug it for a minute before the AC adapter will light up again. The same AC adapter powers on another laptop fine. Dell has replaced the motherboard 2 times and the whole laptop once. Any ideas?
  • 3 Answers
Get a new laptop
Posted on Jan 29, 2009
I already change the adapter but same result.
If your adapter is ok, the most possible problem is that your laptop dc power jack. So you may check it out. Either replace it or get it repaired.
Replacement Dell Latitude D430 AC Adapter 90Watt 19.5V 4.62A
Feb 24, 2013 | Dell Latitude D430 AC Adapter 65 Watt...
Dell latitude runs but does not boot up
Remove battery + power cord from AC adapter. Wait 10 minutes. Plug in only the power cord. Power-on the laptop.
If laptop starts correctly, plug in battery while it is up using the adapter. Leave on for battery to recharge.
Oct 19, 2011 | Samsung Dell Latitude D600 14.1 LCD SXGA+...
I went out leaving my dell latitude D620 laptop on for hours, when i got back the screen was blank. i powered on and the lights came on and went off again
1. Check and see if the LED is on with the AC adapter, if possible, try a different Dell AC adapter (ANy D or E series Dell with a cannon plug connection should run that system Also ensure that the adapter is plugged into the wall.
2. If a known good power adapter does the same thing or if the LED goes out as soon as the adapter is plugged in to the system then the motherboard is suspect
Jun 07, 2011 | Dell Latitude D620 Notebook
How do I get my computer to recognized my new ac power adapter?
The computer doesn't need any drivers to recognize an AC Adapter. If you have purchased the correct AC Adapter for your laptop then it should just work when you plug it in. If it does not then my guess is either you have received a faulty AC Adapter or the DC Jack which you plug into in the back of the laptop is bad.
I am assuming your battery is dead and when you plug it in and turn it on nothing happens?
You can also try taking the battery out and try to power it on with the AC Adapter plugged in.
The Dell Latitude D610 takes a PA-10 or PA12 AC Adapter. It's 65W or 90W
For 90 watt Adapter the output voltage on your AC Adapter label should read 19.5V and 4.62A
At least that's what the Dell brand reads so it should be close to that.
Jan 20, 2011 | Dell Latitude D610 Notebook
Dell latitude 100L power light flashes green as if
It sounds like you have a bad AC adapter . When you plug it in to the outlet in the wall and into your computer , do you see a charge indicator light on the computer? I'm asking you this because even with a bad battery your computer should operate without any problems with the AC adapter plugged in.
May 13, 2010 | Dell Latitude 100L Notebook
My Dell Latitude will not turn on. When I press the power button it will come on for 5 seconds then go off. Can anyone help ?
Plug in the AC power cord, remove the battery, and try powering up. Anything? Any lights?
Remove power cord, hold in the power button for 30 seconds, then try plugging it in again and powering up without the battery. Any change?
Mar 13, 2010 | Dell Latitude D800 Notebook
Ac adapter not recognized appears on the screen...how do i fix this?
Sounds like you may need a replacement for the adapter.
Can you borrow one for the identical model?
Check and ensure that the power requirements for the laptop are matched by the output voltages on the ac adapter.
Good luck
-Carlos:
Jan 25, 2010 | Dell Latitude D430 Notebook
Not charging
which green light?
light from the ac power adapter or the light from the battery?
if ac power adapter you are referring to try a diff power wall socket if ac power adapter still off then replace ac power adapter alone.
if battery light is off but the laptop works fine with ac adapter alone try updating the laptop BIOS.
if ac adapter light turns off when it plug to the laptop replace motherboard.
Oct 13, 2009 | Dell Latitude D531 PC Notebook
Dell Latitude 505 that will not run on AC
Sounds like a BAD adapter. When was the last time it worked in the laptop?? I would try another adapter if possible. When was the last time the adapter work on the laptop?
Jun 03, 2009 | Dell Latitude D505 Notebook
Dell Latitude D430 Notebook Logo
241 people viewed this question
Alun Cox
