I have a 10 year old whirlpool washing machine that has a steady drip into the bucket whats the fix
  • 370 Answers
Replace the water valve. It probably has sand built up in valve and is getting stuck up just a little bit. Replace the water valve and this will fix it.
Posted on Jan 29, 2009
BuIld date, please, for Whirlpool washer MOD GHW9400 PTO; SER. CSR4107238; Type199-085 BT/BD
talk with the service agent for the machine as they will be able to get the manufacture date from the serial number ( no guesses there) as for the leak when it happens will indicate where it is
at 10 years old it most likely is the ripple hose from the tub to the pump as they develop cracks in the ridges and valleys from age and will drip or leak from there
dripping when pumping could be pump seal or hose to the tub loose or perished
there is also a small plastic hose running from the base of the tub up to the water level switch which may be cracked or loose
hoses and parts are cheap so if the machine is not making noises and is following the program, a check on the ;leak would be the way to go
Oct 28, 2016 | Whirlpool Washing Machines
Jamed/15 teen years old
this could be a number of things,,,brive motor sezed up,,,brum bearings sezed up or broken up,,,steady springs fell off or broken,,,, lets fase it its no spring chicken at 15 years old,,,
maybe its time has come to send it to that happy washing ground in the sky????
Sep 04, 2010 | Whirlpool Washing Machines
Very slow drip from water dispenser. How do I fix
Good day,
A slow continues drip, but still dispenses O.K. is caused by the dual water valve on the bottom rear of the machine not closing completely.
Only fix is replacing the water valve assembly.
Mar 04, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool Ultimate Care 2 leak after wash cycle
Hello, you may have a small drip from the pump or a small drip from the hose that goes from the pump to the rear of the cabinet. To make sure you will have to run the unit with the cabinet removed. A local service tech can remove the cabinet quicklyand isolate the leak.
Dec 23, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool washing machine won't drain
Dear friend,
ngfam at you service!
You can not fix this problem your self!!!
This sounds like it will only fixed by service then you will be happy again!!
Yes sounds like you need service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
Aug 25, 2008 | Washing Machines
Whirlpool infiniti washing machine
there is a lint trap ahead of your pump they clog you must remove the pump and clean it . two bolts and two hose clamps.
Aug 03, 2008 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Whirlpool Topload washer dripping
of course its proably just a water valve leaking
Jan 24, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
LSR8233JQ washer water drips into tub from fill port
Yes the fill valve has been damaged by the silt. If you remove the hoses from the valve you will probably notice that there is either one or both steel screens missing from valve body. You cant remove the screens if they get clogged.
Jan 19, 2008 | Whirlpool LSR8233J
Washing Machines Logo
Top Washing Machines Experts
