Question about Pentax Optio M20 Digital Camera
USB Cable is shutting off my computer
When I plug the USB cable in to my computer, the computer is automatically shutting off (while attached to the camera)
Help
  • Rob
    Rob May 11, 2010
    Try a different usb port. Might be a bad port.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Pentax Master
  • 102,366 Answers
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files.
Posted on Aug 21, 2012
Quack
  • 542 Answers
SOURCE: USB cable
My Optio uses a standard mini USB connector - you can buy them for a tenth of the price for example, here in Aussie I bought one for $2 at a local computer mart
Posted on Aug 30, 2005
debbily
  • 101 Answers
SOURCE: Bad USB conection?
it's not likely the cable went bad.  Do you have more than one USB port you can try? do you have other USB devices to test the port? did you reboot?
Posted on Oct 13, 2007
Actaviosan
  • 100 Answers
If your camera's driver is not installed, it will not work.
Make sure you go to the manufactures site, and download the correct driver there.
However, if your driver IS installed, then yes, your USB cord might have gotten bad.
Thank you.
Posted on Nov 26, 2007
  • 39 Answers
SOURCE: USB cable problem when transferring
could be a bent pin maybe?
I would just go out and buy a card reader so that you can read the memory card without the cord. and then you wont have to worry about it.
the card reader cost about 20 a new cord would be more.
Hope that helps,
Caleb
Posted on Jun 27, 2008
djgoodson
  • 17 Answers
SOURCE: USB Cable is shutting off my computer
almost positive it would be the camera. you might want to look around in local news and reportrs and stuff about power lines in the area to see if anyone else has the same problem. if not, take it in a shop
Posted on Apr 02, 2009
I have a hp printer/scanner 3510 and hp computer, the printer works fine but it won't scan!! the lcd screen says, "the computer is not responding. check if the usb cable is attached" the cable is...
Unplug the USB cable to the printer. Uninstall the HP printer software. Reboot. Reinstall the HP printer software and WAIT until the installation program tells you to plug in the USB cable.
Mar 09, 2014 | HP Photosmart C4280 Aio Printer
Computer doesn't recognize garmin
Your computer uses USB Mass Storage Mode to detect your Garmin unit. If your computer does not detect your Garmin unit, you can try these troubleshooting steps:
Unplug the USB cable from the computer.
Turn the unit off and then back on again.
Plug the USB cable into your computer.
The unit either automatically goes into USB Mass Storage Mode or displays USB Mass Storage Mode as an option on the screen.
Note: If your computer still does not detect the unit, make sure that you plug the USB cable directly into the computer USB port and not the USB hub. If the cable is already plugged directly into the computer, try plugging it into a different port.
If you still experience problems, please contact Product Support.
Garmin car gps
Sep 23, 2012 | Garmin nuvi 1350 Car GPS Receiver
Hi, my Immation Portable 160GB as soon as I plug it into my computer, the light is on, the HD seems to be working, but on my pc it doesnt even appear on MY COMPUTER the disk to open. I plug it and windows...
If your computer or laptop has a problem detecting a USBhard drive or a USB device, and another computer can detect it, then theproblem could be a RF interference problem. Try using an USB cable that is a shielded USB cable (ie. AnUSB cable that has a clear plastic covering and you can see a metallic weavewhich covers the wires) OR a USB cable that has a Ferrite core attached to theUSB cable (the ferrite core is a cylindrical object approximately 30mm long X15mm diameter and it is attached to the USB cable near the connector).
Jun 17, 2011 | Imation Apollo Portable - Hard drive - 160...
My wd external hard drive lits up when you plug it in a usb port but it doesnt read on the computer problems
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
make sure the lead/s that attach to this drive have a secure seating and are not bad/faulty the light on only tells that its getting power it might not be getting enough power you might test the lead/s or
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again, sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
hope this helps
May 22, 2011 | Western Digital 320GB MyBook External USB...
Where do you plug in the mp3 player to transfer music?
You MP3 player will be supplied with USB cable. Attach the cable to the MP3 player and plug the other end of the cable into a computer's USB port.
The computer will see this as an removable device, you can then open this device and copy mp3 music files from your computer and paste these files into your MP3 player.
Nov 07, 2010 | Compaq Presario 5000 PC Desktop
Diagram on how to plug an mx320 canon up to a computer
This is Canon Support, and the Getting Started guide which tells you, and shows you, how to properly cable up your Canon Pixma MX320,
http://gdlp01.c-wss.com/gds/0/0300001870/01/MX320_GS_EN-US_V1.pdf
(Copy and paste the above into your address bar, then press the Enter key)
Should this link not work for you, here is Canon Support, and the download page the link came from,
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=18119
Scroll down to the - Guides and Manuals heading. Below this heading at the bottom of the box, there is - Getting Started
MX320_GS_EN_US_V1.pdf ,in red. Click on this.
You may not see anything happening for up to 20 seconds. I downloaded it just now for a test, (To make sure it's working), and I had to click MX320_EN_US down in my system tray, at the bottom of the monitor.
Pages 3, 4, and 16 tell, and show how to hook up the cabling.
Essentially you are attaching the phone line to be able to use Fax, attaching the power cord for power to the MX320, and attaching the
USB cable from the MX320 to the computer.
You MUST set the MX320 up first, and MUST install the software first, BEFORE attaching the USB cable.
(The USB cable plug end, that goes into the computer is Flat.
It is a USB A male plug.
The USB cable end that goes into the MX320 is Not flat.
It is a USB B male plug. Square shape with the top two corners cut off.
This USB B plug goes into the back of the MX320. In the middle of the back there is an inset, or indention. The plug goes in sideways.
Should you have attached the MX320 to the computer with the USB cable, BEFORE you installed the software from the Installation CD, let me know.
[1.Make SURE the MX320 does not have the USB cable plugged into it!
Turn the MX320 off, and unplug from power.
2.Go to Start>Control Panel>Add/Remove Programs, and Remove theCanon software. All of it. Anything you see listed with Canon relatingto the MX320.
3.If it asks you to restart your computer, do so. If it does not, do so anyway.
4.After Windows has fully loaded, insert the Canon MX320 Installation CD disk. Install the software. If it asks you to restart your computer do so, if not restart it anyway.
5.After Windows has fully loaded, plug the MX320 into power. Press the Power On button. Give the MX320 time to set itself up.
Now plug the USB cable into the MX320.
You should soon see, 'Found New Hardware', and also perhaps, 'Found MX320' ]
Nov 18, 2009 | Televison & Video
It will not let me put pictures on the computer and its not the cord because i tried a new one.
Nikon comes with a great deal of really good software for ALL Operating Systems. DO NOT have your camera attached and re install the software that came with your camera. You may also go to: http://www.nikon.com and receive a download of the software related to your camera. After installed, turn your camera ON - Then plug the USB cable into the computer and then into the computer.
Key Things To Remember:
- Have Nikon Software Installed
- Turn Camera On and set for Automatic
Plug USB cable into Computer and then into camera
Enjoy Your Photos,
Paul
Sep 24, 2009 | Nikon Coolpix S560 Digital Camera
Nikon CoolPix S200 SHUTS OFF when usb plugged in
Did you install the drivers to the computer? And install the nikon software to your computer? If you didn't that is probably your problem. Otherwise you can get a cardreader and use it to get your photos on you computer.
Jan 07, 2009 | Nikon COOLPIX S200 Digital Camera
USB Connection. When connected to computer camera shuts off or displays USB error.
you have a faulty usb cable. try to buy another usb cable which supports usb2.0 for faster data transfer.
Mar 23, 2008 | Cameras
Where is port to connect USB cable?
I'm sorry you're having trouble with this. I have put together a picture that shows where the mini-USB plug is supposed to be attached to the camera. I hope it helps. This picture actually shows plugging the AV cable into the receptical, but right behind it is the mini-USB port. This is where you connect the USB cable. It looks like you have to lift the flap on the corner to reveal the plugs.
Nov 24, 2007 | Canon PowerShot SD1000 Digital Camera
Pentax Optio M20 Digital Camera Logo
Top Pentax Cameras Experts
Greg Cann
Greg Cann
Are you a Pentax Camera Expert? Answer questions, earn points and help others
