Question about Marantz SR-7300 6.1 Channels Receiver
Receiver will not turn on
My Marantz SR7300 receiver will not turn on. When I plug it in I hear a relay click but nothing else. Internal fuse is ok, nothing appears smoked.
  • 64 Answers
It is probably shorted out. the fact that you hear a relay click is bad news for you. Take it in and tell them that you cannot get power from the switch through to the main board.
Posted on Jul 26, 2007
SOURCE:
Marantz NR1402 AV receiver Going to standby Mode
There could be a short in one (or more) of the speaker connections. Try disconnecting all speakers and turning on the receiver. If it still switches to standby, there may be an internal problem.
Mar 03, 2014 | Marantz Nr1402 Av Receiver
Audio Receiver only makes one "Clicking" sound when I push the power button
Definitely sounds like a relay... How old is your unit? Sometimes they get stuck and need a good cleaning with DeOxit. Good luck!
Aug 21, 2017 | Yamaha HTR-5940 Receiver
Plugged marantz sr8100 into 230V outlet without transformer. Did this likely cause irreparable harm to receiver?
Hello
If you have plugged in to 230AC with voltage settings was 110VAC, the transformer has been damaged already [opend winding]. If the voltage settings was 230VAC itself, there will be no harm to its internal transformer. Anyway, open it, anc check the fuses. In some cases, fule only will blow out, preventing from furhter damages. I'm not sure about it, but check it. If the fuse only has blown out, and there has no harm; you are lucky I should say. OK.
Apr 07, 2011 | Marantz SR8001
Just picked up a Marantz SR-19, Everything looks like it works but I get No sound out of it. Unfortunately, there is NO remote and was wondering if there is a setting like Mute or a speaker select on the...
A Mute indicator would tell you if it was muted. Make sure no Tape or Multichannel Input are selected by mistake.
There are supposed to be jumpers across the Pre_Outs to Main In's in the back when you're NOT using external amps. You could substitute short RCA cables.
Jan 28, 2011 | Marantz SR-19 Receiver
My Marantz sr 4001 receiver has no output. Is
There is no fuses for the speakers. Check setup. If the receiver has 7.1 channel input try to connect a source there so you can check output (amp) section and the speakers.
Jul 18, 2010 | Marantz SR4001
Hello i have a marantz receiver sr7400 fuse
Unplug the unit. Carefully unscrew the screws for the case. Probably 4 screws, 2 on each side of the unit. Remove the cover. Look for the fuses, and replace with exact same type/specs of the faulty fuse. If the fuse, is on a printed circuit board, be careful dislodging the fuse. Hope this helps.
Apr 07, 2010 | Marantz SR-7400 Receiver
I have the same problem. The fuse blows every time I plug the Sony STR-DE135 into the wall. I did not find the F901 at Radio Shack, so I bought a fast acting 5 Amp 125V Fuse at the Hardware store. It blew...
There is usually one or two normal clicks on power-up. A self-protection relay activates after a short delay for circuit and power stabilization plus some internal cheking for shorts and thermal issues.
If it keeps blowing fuses you are stressing it a bit more every time you feed it another one. I'd get it in to a Pro for repair.
Mar 02, 2010 | Sony STR-DE135 Receiver
'clicking' off a few seconds after turned on
Does the receiver work OK?
These are probably electromechanical switches (called relays) which yamaha uses a lot. They use electricity to connect/disconnect something by magnetic force and this causes the "clicks". It is used for example to connect the speakers to the output of apmlifier only after it has finished initializing to protect both the amp and the speakers.
When I turn on my RX-V465 I hear at least one click, it is probably connecting power to the amp. When turning it on with Radio button on remote I hear 3 clicks over 2-3 seconds.
So these clicks are normal and nothing to worry about. They occur also when you switch to the PURE DIRECT mode.
Feb 27, 2010 | Yamaha RX-V463 Receiver
I have a Marantz SR5500 and the unit will not stay powered on.
I have this problem. it is caused by an o/c mains transformer primary winding. the clicking and flashing light is the stanbyy circuit trying to switch the power on to the main (large) transformer when it gets no voltage out it switches back off
May 19, 2009 | Marantz SR5500 Receiver
Receiver Not Powering On
Unit has a problem in power supply or output circuits. Take in for service
Dec 08, 2007 | Sony STR-DA9000ES Receiver
Marantz SR-7300 6.1 Channels Receiver Logo
397 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
