Question about Akai PDP4290 42 in. EDTV-Ready Plasma Television
AKAI PDP4273M1 - Unit powers up then shuts down.
The unit powers up, large AKAI in white letters with blue background appears for 1 to 2 seconds, then AV in left corner of screen lights up,
and no video appears in right corner, unit powers down. A few seconds later same sequence takes place until you unplug the tv.
Discovered that if I hold down the sequence button or the menu button the unit will stay on and continue to display AV no signal. If while holding down those buttons I hook a video input up the tv plays however the audio is low.
I just repaired one for the same trouble. The input to the main processor from the standy switch had shorted to groung. This was probably caused by static inserted when pushing the power button. The processor is not a replaceable part. The part number for the main board is E3761-058010-2. It costs between $140 and $150. I found it on-line at Shopjimmy.com.
Good Luck!
Posted on Feb 25, 2009
My HTC HD 7 phone keeps turning off it goes to the white screen with green HTC then shuts off and keeps doing the same thing over and sometimes when i try to use it and i tap the screen then it shuts off...
I finally had to have them replace the unit. If doing a factory reset does not help, then I would have them replace it. Mine started rebooting infrequently, but then started doing it more often. They didn't waist any time getting my replacement out.
Please make sure you back up all your contacts/email before proceeding. I use Google on my phone through the Outlook option. Google/Outlook syncs all my mail, contacts, and calendar.
RESET: Software: SETTINGS > ABOUT > RESET YOUR PHONE
Hardware: 1) Turn off phone 2) While holding down both the Up/Down Volume buttons, turn unit on 3) Keep holding down the volume buttons until white screen appears 4) Press the Down Volume button to reset to factory defaults. 5) Restart phone
Jun 28, 2011 | HTC HD7 Cell Phone
I turn on my nuvi 1300 and get a white screen
Hi famoflu5,
It sounds like you have the "white screen of death" (I made that up) non-responsive screen...meaning you cannot enter data or make the unit respond to finger or sylus presses. There is a procedure for getting the screen back to normal, provided there are no other software or electronic issues.
Try these steps:
1. Turn off the Nuvi.
2. Hold the upper-left of the screen while turning power on.
3. Release the Power button when the Garmin screen appears.
4. Continue to hold the upper-left corner of the screen for 30 seconds, until a white screen with "Press dot" appears.
5. Press dot and that should get you back to normal.
Also, you may to need perform a hard reset for your unit to clear out any erroneous data.
These GPS units can be reset by holding the Power button for 10-15 seconds to completely shut the unit down. Then, do the same procedure for 10-15 seconds again, to power it back on.
It would be best to assure the unit has external power, and hopefully a full battery charge, for best results. Also you can download a complete manual from this link for more info:
http://www8.garmin.com/manuals/3130_OwnersManual.pdf
Starting on page 47 of the manual in the appendix, it tells you about calibrating the screen (problem discussed above), updating software, and clearing user data.
If these steps don't bring your unit back to life, you may need to contact a regional repair facility or the factory for service.
Let me know how this turns out, and if I can help you further.
Regards,
Bill
09-19-10
Sep 19, 2010 | GPS
I have a Goodman PHK036-1 unit outside and it had a Lennox Thermostat. I want to replace it with a Lux DMH110 Thermostat and I need to know the wiring for this. I had someone help me last night but the...
Disconnect all wires to start.
1)Go out to unit shut off power and remove electircal panel.
2) Locate the terminal board where thermostat wires are connected. Write down where each color goes to
each letter and then try to do this at the thermostat.
R= Red wire= Power
G= Green Wire= Fan Leg
W or W1= White Wire= Heat Leg
Y1 or Y2= Blue or Yellow Wire= Cool Leg
C=Brown or Black or Orange= Common if used
Jun 27, 2010 | Heating & Cooling
Dell optiplex gx150 power button just flashes - help?
System seems to be in hibernate or standby mode and frozen in that state. Hold dosn power button for 5 seconds or until all signs of life shut down. Wait about 30 second and power up the system.
Jul 25, 2009 | Dell Optiplex GX270
TV screen Flashes blue and then shuts off.
When it flashes blue, are the flashes bright blue lines going across the screen with the picture in the background, if so, It sounds like the Blue tube or blue driver circuit is breaking down after a short period of time. If this is the case, the uPC that controls the set is detecting a large current drain on and is shutting the set off for protection, An engineers expert eye is required I`m afraid. Ian.
Jul 24, 2009 | Sony KP-65WS500 65" Rear Projection...
Picture on Akai PDP4273M1 suddenly degraded drastically - no whites, very low contrast. Turned it off for 10 minutes then back on, instead of bright blue I get most black splotches with some blue. Any...
You could smash the TV and find that it will work better or call a local repairman. I know the exact problem with this TV, but only a technician should even open a TV. The guy I got the TV from totally butchered the inside of his Akai in a failed attempt to fix his TV himself. Instead, he created a fire hazard and is lucky he did not burn his house down.
Apr 30, 2009 | Akai PDP-4247 Television
Akai pdp4273m1 has sound but no picture
I also have the akai PDP4273M1 tv with power and no picture and I looked at the power supply board inside and found 1 of the FMG26S chips blown and I am looking into replacing this to see if that does it and if not do a search for SANKEN PSC10165B M and for approx 170.00 you can get a whole new power supply for it and its easy to put in..
Jul 14, 2008 | Akai PDP4290 42 in. EDTV-Ready Plasma...
Error Code 5 flashes when unit shuts down
Good Day;
It sounds like the TV may have a shorted CRT, picture tube, but let's trouble shoot:
1. Unplug TV from wall.
2. Remove speaker grill, two on bottom, the screws are covered with plastic caps, right and left side on bottom next to floor.
3. Remove inner panel.
4. The blue tube is the one the right side, remove socket, with phillips driver, make sure it's not touching anything.
5. Plug and turn TV back on, if picture appears with no blue it's the tube.
6. If still shuts down, bad blue CRT driver IC.
CAUTION: Call a factory authorized service dealer to give you an estimate, if this sounds too hard.
Good Luck, Day, Big Irish.
Jun 18, 2008 | Sony KP-51WS510 51" Rear Projection...
Desktop gon blue background
i advise you to reinstall windows.
May 24, 2008 | Dell Dimension 4600 PC Desktop
Nintendo ds
Setting the Time and Date
Changing the time
  1. Remove all games from the Nintendo DS.
  2. Turn the system on by pressing the POWER button.
  3. Tap the screen using the stylus when the "Touch the Touch Screen to continue" message appears.
  4. When the main menu appears, tap the stylus on the Settings Menu Panel at the bottom middle part of the screen. icon_settings.gif
  5. Tap the calendar/time icon (the blue icon, second from the left). icon_clockdate.gif
  7. Tap the up or down arrows above the hour and minute to change the time. When finished, tap the "Confirm" button in the lower right corner.
  8. Wait for the the confirmation message to disappear, then tap "Go Back," then "Quit," then "Yes" to exit. The unit will shut down automatically to save the settings.
Changing the date
  7. Tap the up or down arrows above the month, day, and year to change the values. When finished, tap the "Confirm" button in the lower right corner.
Dec 30, 2007 | Nintendo DS Console
Akai PDP4290 42 in. EDTV-Ready Plasma Television Logo
360 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
