No power indication,no rasters,and no sound. Only click sound.
Only click sound is heard when I turn on the TV. No rasters, sound ....Experts out there, please help... Thanks.
    President:
  • 1,214 Answers
Go to the Anantek website and search for your TV or similar TV's to see if anyone has posted repair hints. I've fixed several TV's and other electronic equipment from their website.
Posted on Jan 29, 2009
KP-61HS30 has sound but no video
1) the problem you have is lack of raster , the problem in tv has 4 phase 1) raster 2) picture 3) synch 4) sound.
2) test the power supply , check the horizontal output +125vdc ,vertical output from +80vdc, +al other circuit +12vdc, if there are missing fix it, see the diagram attached.
3) TEST the signal from tuner,i-f, detector, AGC
GOD BLESS YOU
Jul 12, 2012 | Televison & Video
TV won't stay on! The TV will randomly make a "click/pop" sound and turn off. I will unplug the tv for a bit and then reinsert power cord. The tv will "click" (just like when it is turning on) then a...
Power supply board have problems.It dying.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Sep 14, 2010 | Vizio P50HDTV10A 50 in. Plasma HDTV
Model TC-32LX700 Power indicator light on from is
Problem is caused by voltage irregularity. Pulled plug for an hour and then plugged it back in. TV reset and it works fine. If this does not work it needs a TV technician.
Sep 14, 2009 | Panasonic TC-32LX700 Television
Vizio P50HDM No Picture/No Sound
this is most likely the sustainer board(s) problem. Replacing the sustainer boards should correct this problem for you. you can get the parts at vancebaldwin.com
May 29, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Sharp 32'' tv -no raster showing channel numbers only
since you have sound and display it's not the hivoltage. You're electron guns are not being turned on. Most likely the IC which biases the guns or the IC which contains the biasing resistors.
Jan 28, 2009 | Sharp 25R-S100 25" TV
Sony KP-53V80 is not turning on.
4 LED flashes indicated a faulty IC board
Jan 18, 2009 | Sony KP-53V80 53" Rear Projection...
No raster, No sound, No channel number
wepu, Buddy it sounds like you got a power supply problem. As you say the picture is all blue?? With no video or sound and the fact that the channel display is out is the first indication that i would guess this. Do you still have the owners manual that you got when you first got the set? Good, cause thats the only place i can think of where to look in case of service over in your part of the world as I did try!! Man I tryed but to no avail. No one has heard of this model but that dosent mean that it dos'ent exsit!.. If your a tech or know your way around solid state circuitry then you should have no problem finding the fault once you get a service manual from the service location in your owners manual. Now if your not a tech and a handy man ?? If I were you I wouldnt mess with the tv as theres over 25000 volts inside the set and i've seen it make a grown man cry. Man dont attempt the repair or troubleshooting if you dont have the right or proper tools and equipment!!! Good Luck
May 26, 2006 | Philips 21PT4475 TV
No raster, No sound
Your problem discription is not very detailed but certainly it sounds like the first place to look would be at the fuses if the set is completely dead. Good luck.
Televison & Video Logo
65 people viewed this question
Top Televison & Video Experts
