Question about Welbilt MR622W Microwave Oven
Micro wave I had a piece of loose foil and burned the back of my microwave and would like to put paint on it , it works fine but looks bad to me . what are your suggestion and can I paint it and what kind should I use. Thanks Glenda
  • 1,214 Answers
A paint formulated for microwave ovens is available. Go to and you can buy there, or do a Google search.
Posted on Jan 29, 2009
My Kenmore Brew n Wave coffee pot is working (there is power to the unit). However, whenever I try to use the microwave function, the light comes on, the countdown timer works, but there is no "fan" (is...
You have blown a fuse. Check inside the oven chamber and look for missing powder paint or signs of arcing, if so there is a paint to repair microwaves for this issue or else just dispose of the microwave. If the inside is good remove all the screws and remove the cover. Replace the fuse. If the magnetron was making louder noises prior then replace the magnetron. Since the fuse went the giant capacitor is likely bad. While the cabinet is open make sure to look for burned wires, check the continuity of thermal cutoffs, and check the main circuit-board for burned traces or components. The relays in most electronics are known for arcing (spot welding) and staying in the wrong position. Tap them hard with the back end of a screwdriver. During all of this use safe electrical practices by having the power cord unplugged. The capacitor could still have a high charge on it so be careful.
Nov 30, 2013 | Kenmore Brew 'n Wave 63992/63999 Microwave...
Try2910227 serial ywmh2205xvb-0 model arcing on the back corner were the rack sits.Is there a way to repair this seen is the unit was purchaced in June of 2011.
Yes, take the rack out and recycle it. I do not know why these micro-wave company put racks in the micro wave ovens. You get some insulation on the inside the micro flaking off next the rack.
The mega-tron tube is a very high energy transmitter. The energy will come out of the top inside the micro wave oven in a wave guide. Micro wave energy that generation by the tube is high frequency into Gega Hertz. You have a metal tray in side the micro wave acts like a big capacitor it stores energy in form of heat the next you know it look like Marconi is putting on a lighting display.
Leave the wire tie on a loft of bread and put in you micro wave oven to defrost. The next thing you might see is a load bread burning, instant toast. ----The use of micro wave were invented by the British before WWII. The mega tron tube generation very high frequency radio wave and these wave struck an object 100 miles away some of this beam energy would balance back to a receiver-----You have Radar.... I wish you and your family well being and be careful of micro wave ovens it can burn from inside out. GB you...stewbison
Aug 22, 2011 | Microwave Ovens
I'm getting a flash inside the oven and the plastic on the inside roof has a burn mark. I removed the plastic cover over the micro wave generator and it did not spark. is the oven dying? It is a 1983 0ver...
It looks like the metal part inside the oven is exposed to the high frequency rf waves. this may sound strange but try coating the metal part with fresh paint. remember no metal inside the oven will stand the waves created inside the oven the spark u see is the waves hitting the exposed metal part inside the oven
Oct 13, 2009 | Magic Chef MCD1311ST Microwave Oven
My cookworks micro wave works fine but upon cleaning the inside i noticed on the right sideof the inside a small square ''piece of card/plastic'' has a hole/burn mark-can i obtain a replacement
Look at for this part. Have your make and model of couse and describe the part as clearly as you can. They are very good at sorting things out.
Sep 28, 2009 | Microwave Ovens
Oven appears to function normally but doesn't cook at all.
With micro waves, this could be a number of things. They are hard to diagnose using this forum but I'll try. There are three things you can check. One being the thermal fuse. On some models, when it goes bad it put some things out. with others it puts every thing out.
if it's good, check the mag tube (Magnatron). Most of the time, it will be burned on the end if it's bad. tube. The last thing would be the fuse. It is made of ceramic and is a 20amp. It looks like a old round car fuse but it's not. It's made just for micro waves. Honestly, if the thermal fuse and the round 20 amp fuse is not the problem, you may be able to replace the micro wave cheaper than replacing the parts.
Thermal fuse $28.99.
Round 20amp fuse $1.53
Transformer $100.00.
Mag tube $87.00
Capacitor $45.00
Go to and enter your model number. This will pull up every part in the micro wave and their prices. Then you will ba able to decide if you want to replace the parts. With yours being one that's built-in over the stove. These cost more and are worth putting more into. If I can help any more comment back and I'll do what I can.
Please rate solution
Sep 07, 2009 | Maytag MMV5186A Microwave Oven
Will not heat. has power going to transformer
There are a couple of steps you can do inorder to varify the main reason for your micro wave not heating.
Microwave doesn't activate / heat.
  1. Make sure microwave is plugged in properly.
  2. Check that door closes completely and its latch is aligned.
  3. Check that interlock switch in door works properly (required for activating microwave).
  4. Replace a blown fuse if it's accessible, or contact a service technician.
  5. Inspect plastic coupling beneath tray.
  6. Check ring and roller assembly for misalignment or debris.
  7. Make sure that tray is sitting properly on turning mechanism.
  8. If carousel motor is broken, contact a service technician.
  9. Make sure there's no aluminum foil or metal trim on dishware.
  10. Food residue or burned spots can cause electrical arcing. Clean chamber thoroughly. Replace wave-guide cover if burned or carbonized.
  11. Sand away burn spots, and smooth rough metal edges.
  12. Touch up spots with microwave interior paint if necessary.
  13. If chamber has burn holes, contact a service technician.
After doing these steps I am sure you would be able to figure out the problem area.
Please let me know if you need any further information.
God Bless.
Jul 09, 2009 | GE Microwave Ovens
Arcing inside and there is now a small hole on the panel side. Is this fixable?
It looks like there's lightning (arcing) inside my microwave When you see arcing inside your microwave, it's because of food or liquid left in the cavity or on the wave-guide cover:
  • If the wave guide has any burn spots, replace it and clean the unit well.
  • If the cavity has any burn spots, spot-sand it smooth and touch it up with microwave interior paint.
Note… If there are any burn holes in the cavity, don't use the unit-seek help from a qualified appliance repair technician.
Thanks for contacting Fixya
Jun 20, 2009 | Microwave Ovens
Boiling waer under micro wave lots of steam into micro wave, turn on micro wave ,pop noise like glass miro wave comes on louder hum than normal no heat
Q - The microwave display counts down and the inside light is on,  but nothing is heating and the fan is not running.
A - This most commonly is a bad door switch, other possible problems are a faulty relay or solder joint on the power module, but a bad door switch is most common.
 Q - My microwave is running and sounds like it is working but will not heat up anything.
A - Many thing can do this but, common things are....loose high voltage wire.....poor solder joint on board.....magnetron.....power relay.....
Q - The microwave makes a loud "hum or buzz" noise but will not heat up the food?
A - 9 times out of 10 this is usually this is a bad magnetron, the other time is sometimes a bad high voltage diode. See components section.
Mar 03, 2009 | Amana Radarange Microwave Oven
Microwave back wall slightly damaged by alumminun foil. Is this a big deal. Wife is afraid it will leak radiation. I say phooey!
A microwave oven does not generate ionizing radiation, it's just radio waves. All it can do is burn you.
But the spot should be repaired so that food particles and grease do not accumulate there and cause arcing or rust.
It will have to be sanded smooth and clean and dried thoroughly.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 26, 2008 | Microwave Ovens
GE Profile
Some burns are not cleanable. Use of soap and water is the safest way to attempt cleaning it. If it burned the paint, then it will need to be touched up with G.E. oven cavity paint ONLY, which your local dealer or servicer should be able to get for you.
Do not attempt to clean it with any flammable or toxic solvents.
May 22, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
62 people viewed this question
Top Welbilt Microwave Ovens Experts
William Miller
William Miller
Are you a Welbilt Microwave Oven Expert? Answer questions, earn points and help others
