Question about Refrigerators
Frost free fridge freezing up
FRIDGE FREEZING UP PERIODICALLY ... LIKE EVERY 30 TO 40 DAYS. TEMP. STAYS CONSTANT THOUGH. ALL ELSE WORKING NORMAL. WOULD REALLY LIKE TO HAVE A SCHEMATIC DIAGRAM FOR THIS MACHINE BUT AGENTS/MANUFACTURERS BLUNTLY REFUSE.
ANY WAY YOU CAN HELP WILL BE APPRECIATED. THANKS!!!
  • mikeclack Feb 25, 2009
    ACTUALLY, THE UNIT IS AN UPRIGHT FRIDGE ONLY. THE PROBLEM IS NOW RESOLVED BY REPLACING THE TWO TEMP. SENSORS. IN FACT I STRIPPED ONE OPEN AND FOUND THAT THE NTC RESISTORS CAN BE PURCHASED FOR A FRACTION OF THE AGENT COST. TAKES A BIT OF TIME AND TROUBLE TO FIT BUT WORTH IT.
    THANKS A MILLION FOR COMING THROUGH FOR ME
    MIKE
    Sniper:
  • 50 Answers
There used to be a schematic behind the front grill that you pull off to clean condenser try there. every appliance used to have a wiring diagram. . now your problem ; it sounds to me that a baffle between freezer and fridge is being hit or the knob next to the thermostat is being set for colder temperatures in refrigerator section. also if the fridge side gets close to empty that could cause items in fridge to ice up.
Posted on Jan 29, 2009
My whirlpool frost free fridge freezer's alarm keeps going off, ice-cream doesn't freeze?
Check condenser is clean, fans working, thermostat set correctly, try to check internal temp with digital thermometer
May 17, 2012 | Refrigerators
I have an amana bottom freezer fridge. 3 years ago ,y freezer was frosting inside and the fridge temp was not getting cold enought. a repaiman replaced the thermostat. now the freezer is beginning to...
To fix up a frosted up vents, I had a control board replaced for $180. Then 6 months later, the bottom freezer frost up AGAIN. rather than dumping more money to fix it, I was about to buy a new fridge, but had a crazy idea: I disconnected the water to the freezer, bought plastic trays for ice cubes for $3 at walmart. Fridge has worked like a charm for 6 months. no signs of frost. Saved $1000's.
Dec 12, 2011 | Amana ABB1927DE Bottom Freezer...
I HAVE WHIRLPOOL ET4WSKXKQ05. FREEZER STARTING TO GET FROST AND FREEZES, BUT NOT COMPLETLY. THE FRIDGE PART IS GETTING WARMER DAY BY DAY.
Most times this is a bad cold control, but there are other things to check for. Make sure the condenser fan is working and the coils are not covered with dust. A separated heat exchanger ( small capillary tubing soldered to the large suction line ) can separate from one another and make the fridge run too long. - tape tubing back together. A poor working evaporator fan motor could also make the fridge run too long and freeze - replace the fan motor. An inefficient compressor or refrigeration system could make the fridge run too long and freeze - have a service tech check this out. A misaligned control settings, make sure the air damper and cold control have not been bumped and are out of normal settings. Stuck open air diffusers or air dampers are becoming more and more common for allowing too much air to be blown into the fresh food section and freezing things. On all frost free fridge's the freezer temp air is blown into the fresh food section, if you have "easy" to freeze items ( eggs, veggies in water, etc ) in front of or under where the freezer temp air comes out, they could freeze - store them in a different spot. Doors not closing properly making the fridge run too long is something else to check for.
Hope this will help to solve then problem..
Aug 14, 2011 | Refrigerators
The refrigerator and the freezer are staying too cold. The temp controls are at the lowest possible and still things in fridge freeze. I can hear the compressor cycle of for a while then on for a while....
things: Most times this is a bad cold control, but there are other things to check for. Make sure the condenser fan is working and the coils are not covered with dust. A separated heat exchanger ( small capillary tubing soldered to the large suction line ) can separate from one another and make the fridge run too long. - tape tubing back together. A poor working evaporator fan motor could also make the fridge run too long and freeze - replace the fan motor. An inefficient compressor or refrigeration system could make the fridge run too long and freeze - have a service tech check this out. A misaligned control settings, make sure the air damper and cold control have not been bumped and are out of normal settings. Stuck open air diffusers or air dampers are becoming more and more common for allowing too much air to be blown into the fresh food section and freezing things. On all frost free fridge's the freezer temp air is blown into the fresh food section, if you have "easy" to freeze items ( eggs, veggies in water, etc ) in front of or under where the freezer temp air comes out, they could freeze - store them in a different spot. Doors not closing properly making the fridge run too long is something else to check for.
Hope this will help out.....
Jun 09, 2011 | Refrigerators
I have a problem with my refrigerator not cooling consistently. It seems like at least once a day it will start warming up but the compressor doesn't come on. When I turn the temp up control nothing...
I believe this is normal behaviour in all auto defrost (which means virtually all modern) fridges. In fact, this short heating period is usually programmed to happen 2 to 3 times a day. You might rightly ask why the refrigerator compartment needs to undergo "defrost" cycles when the compartment is, if the refrigerator is operating correctly, above freezing? The reason is although the compartment is above freezing, its cooling coils are well below freezing temperature, and it's these coils that need the frequent defrosting, before they build up so much frost on them that they "ice up" and no longer allow the fan blown air that cools the refrigerator compartment to pass through them.
Nov 12, 2017 | Kenmore Refrigerators
Not cold enough. freezer works but fridge wont stay cold. i can shut it off for a day and it will work for two more. after that it quits again.
It you have a frost free fridge, then what is happening is that either the defrost element or the thermostat is faulty, causing ice to build up and block off cold air circulation to the fridge. Sometimes the frost builds up around the circulation fan and ceases it up.
That is why when you turn the fridge off for a day, the frost melts and drains out the back of your fridge and so the fridge works ok for a few days until the frost build up again.
Another thing to watch out for is the defrost timer. Sometimes they fail and stick on one cycle and dont advance through. pull your fridge out. The timer is located in the back near the compressor. There is normally a small dial on it. With the fridge turned off, you can twist the dial clockwise and you will hear the timer mechanism click through the different cycles. Make small ink mark on the timer dial. Say at 12 oclock. Turn fridge on. Chech the fridge every couple of hours and see if the mark advances through and does not get stuck in one position for lengthy periods of time. The defrost cycle should normally be around 8 hours and it repeats again.
Let me know if you need more help with the defrost element or thermostat. But it is best to get an experienced repairer to change those.
Good luck
Ash
Oct 31, 2009 | Estate TT21AKXKQ / TT21AKXKT Top Freezer...
Fridge side won't regulate temp. however the freezer will freeze to -9 and stay right there! How do you test the thermostat? or is this a common problem. The fridge was built in 01' and nothing has been...
the thermostat is either off or on, and it controls the fridge temperature the freezer is just a by product of the remaining gas from the fridge usually -20/30 degrees lower than the fridge, two problems would cause this leaked gas would reduce the cooling capacity of the freezer but the fridge should stay ok although the compressor would be constantly on trying to keep temperature. the thermostat can fail after time not being able to keep a regular temp and not switching the compressor on enough to cool the system. unless you have a frost free where is usually a relay that controls the compressor witch have a life time rating of so many operations.
Jul 23, 2009 | Electrolux Refrigerators
Frost free fridge
Check and set both temperature adjustments, one for freezer should be no more than 1/2 and the refrigerator also as a starting point.
May 05, 2008 | Candy CPCA240FFK Bottom Freezer...
Refrigerators Logo
160 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
