Question about Toshiba Satellite A100-S8111TD Notebook
Audio/video playback device not working properly how to fix?
How to fix the problem plz help thanks
  • Anonymous Feb 03, 2009
    I only get a black screen when i connect the s video connection to my toshiba satellite proa100.Tried everything.Please help
  • Gyanendra Kumar May 11, 2010
    hi,
    Please specify the issue that what eactly the error is?
  • 479 Answers
Hi ,
please check that some notebooks are supporting 4 pin cable only so if you are using 7 pin try 4 pin otherwise vice versa.
Posted on Feb 04, 2009
How do I get my volume to work on my computer
most audio control programs (ie. realltek) are designed to automatically mute the main audio output if it detects that there is a device connected to the headphone jack, i suggest unplugging any such device. more over .... in some instances windows will allow you to set which playback device your audio stream is being sent to via the playback devices system dialog box. this video will show you how although the guy is this video is note entirely correct the process is much the same Fix Windows 7 Audio Playback Devices CLICK CC BUTTON FOR SUBTITLES
Jan 22, 2016 | Computers & Internet
My logitech z-5300 speakers were working perfect to play itunes & sounds from all programs. Got video camera & tried to use it but no sounds played around in control panel now my speakers wont...
Hi
You do not say which operating system you are using. My answer can therefore only be general rather than specific to your operating system.
The Video Camera you tried to install probably has an in-built microphone. Connecting this is may have changed the default settings for your audio devices.
You have a number of options for fixing this problem.
SYSTEM RESTORE
Start > All programs > Accessories > System Tools > System Restore > Restore my computer to an earlier time > selected a highlighted date in the calendar and an Event in the schedule before the date you tried to install the video camera > restore > restart the computer (you should hear the windows logon on tones if you are using a windows operating system) > (My) Music > Sample Music > double click on any track to test the sound playback.
AUDIO SETTINGS
Start > Control Panel > Audio devices > Audio (Playback Devices) > Set Defaults (set the Speakers to be the Default Playback devices > apply > ok > restatrt computer > (My) Music > Sample Music > double click on any track to test the sound playback.
AUDIO/SOUND DRIVERS
Reinstalling the Audio/Sound Drivers would also probably resolve the problem by restoring your Default Audio settings, if you have the Driver CD for your Laptop or Desktop Motherboard > install Audio/Sound Driver > restart computer > (My) Music > Sample Music > double click on any track to test the sound playback.
I cannot direct you to a driver download site, because you have given no information about your computer.
If this answer helps you, please take the time to rate it. This helps answerers better understand the needs and the point of view of the asker and helps us explore the best ways to provide useful, high quality answers.
If you need further help, please feel free to post another question or add a comment to this question.
Thanks for using FixYa.
Aug 31, 2011 | Logitech Z-5300 Computer Speakers
I have a new reformat pc all installer sofware are working properly but soundcard installer is not working on my computer. hoe can i fix tihs problem, and how to fix this easely? thank you so much god...
Well, try this.
Ensure speakers are connected to the correct port. Usually the green one on your sound card. Then --
Open Control Panel, Device Manager.
Expand Sound, Video and Game Controllers
Right Click your audio device and select Properties.
Does it say, THIS DEVICE IS WORKING PROPERLY in the Device Status box? If not,
Click the Driver Tab and select Update Driver.
If yes, Go to Device Manager, Sound
On the Playback Tab, is there an Audio Device listed and selected? Is it the correct one?
If yes, select the Sounds Tab. Select a Sound Scheme.
You should now have sound. If not, recheck your connections. If all is well, replace your sound card.
Nov 27, 2010 | Intel Pentium D 820 2.8ghz Dual Core CPU -...
Just installed new motherboard and now receive following message......itunes has detected a problem with your audio configuration. Audio/Video playback may not operate properly. How do I fix this?
Try reinstalling quicktime. Go on control panel uninstall quicktime. Then go to this url:http://www.apple.com/quicktime/download/win.html
Download it again. And install it again. Itunes should now work.
If it doesn't, for Video problems: Open QuickTime Player and go to 'Edit' -> 'Preferences' -> 'QuickTime Preferences' -> 'File Types' -- check here to see if the file format of your problem video files is selected.
For Audio problems: Open QuickTime Player and go to 'Edit' -> 'Preferences' -> 'QuickTime Preferences' -> 'Audio' -- Here you will see a Device is needed that will play your sound. Select 'Audio Playback and Recording Devices', If you are having an Audio problem it may be due to having no device or an improper device.
Good Luck
Nov 25, 2009 | Dell Dimension 9200 PC Desktop
Audio on Dell Webcam Central And voice record isn't working
I have a Dell 1545 with Dell web cam central & I've had this issue. The problem is that Dell web cam central installs it's own microphone settings onto your laptop called something like Dell web cam Live!. This isn't the built in microphone in my laptop & maybe not yours either. You have to change the settings for your computer system & Dell web cam central. Go to start> control panel> sound> recording .. on mine there is an option for Microphone "High Definition Audio Device" ... that is the built in mic. You want that for your default & apply it. Also .. as a side note .. I disabled the web cam central Live! microphone completely from this window. Then open Dell web cam central & go to the "Record Video's" option. In the middle of this is an orange button with a video camera icon. Next to this on the same button is a little arrow pointing down .. click that. Under microphone .. choose Microphone "High Definition Audio Device" just like the sound option in control panel. I've done this & it's completely fixed. I can record videos with sound & use my built in mic in voice/video chat.
Aug 15, 2009 | Dell Inspiron 1545 Notebook
No Audio
Here is the link to the page for the driver for your audio. once you install this you should be up and running again. Hope this helps!!
Jun 28, 2009 | Intel Computers & Internet
Choppy Video Playback
it's probably the codec you're using. divx works nicely.
Feb 17, 2009 | Sony Playstation 3 (PS3) Console
I tunes has detected a problem with audio configuration audio/video playback
Go to Start> Run
Type in 'Services.msc' without the quotes.
Find Windows Audio in the list. Most likely it has not 'started', as stated beside each of the items in the list. Click on it, then click 'start'. Re open your itunes and it should be working.
Oct 17, 2008 | HP Compaq WF1907 Monitor
No playback device
First make sure that you have installed the drivers for your sound card. Please check this and let me know..
Jun 01, 2008 | Acer Computers & Internet
Toshiba Satellite A100-S8111TD Notebook Logo
346 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
