Question about Danby DKC646BLS Full Size / Pony Beer Keg Cooler
Danby Keg Cooler foam problem
I just bought a Danby Keg Cooler "Chill'n Tap" and am having problems with what they call "Wild Draw." There is too much foam being dispensed. I have tried everything recommended and it is still an issue.
  • 4 more comments
  • baylor Dec 31, 2007
    i am having major foaming problems
  • Anonymous Jun 18, 2008
    Same problem here, too much foam not enough beer
  • tstewart705 Jul 21, 2008
    My fridge has always worked fine but I have not had a keg in it for few months and now all I am getting is foam and no beer. It first seemed to be drawing air but now I am not sure. I have tighten all the connections and when I pour it only dispenses foam?????
  • sandoval10 Mar 29, 2009
    My Danby produces exessive foam. Changed beers, cleaned equiptment, fiddled with pressure...still too much foam.
  • Anonymous Apr 13, 2009
    I have a edgestar kegerator i get a couple glass es of foam then good then wait a while and foam again pressure at 12 5 'of beer line
  • Anonymous Apr 21, 2009
    I have foamy beer and have read here to leave the pressure at about 13 p.s.i. also read between 8-10p.s.i. someone also wrote 2-4p.s.i. I have it on 13p.s.i. now also read to wait about four hours for cage to get cold before tapping.(well I tapped it as soon as I put it in before I read this) it was semi cold as it was in the cooler at the store (but took a while before I got it in).I would like some input on the proper p.s.i. and also would it be o.k. to leave it tapped at this point or should I untap it until the 4 hours is up ? thank-you so much if you can help.also should the air be left on all the time?
    New Friend:
I had the same problem, Questions is where is the foam, do you see it in the lines after the keg tap? If so, I bet you money the plastic hose is improperly crimped at the steel connector that fastens on the keg tap..Look inside the tube you might see the bad crimp job, then use a proper sized drill bit to bore it out, I dont recall the inner diameter of the hose but dont go to large with the drill bit where your causing the inner walls of the tubes to shred. After doing that, use the CO2 tank to blow out the pieces through the top with the faucet disconnected of course. Duck and move any breakables cause theyll shoot out like a bullet. After about 8 kegs of bad pours i finally figured it out..it pours so nicely now. I keep the pressure @ 8psi with ML if you needed that info..
Posted on Dec 07, 2011
  • Al Gilson Apr 17, 2012
    This solution helped me out. Turns out that when the silver fitting was stuck on to the hose, the hose wasn't cut cleanly and there was debris in the hose. A quick jab with a screwdriver, and I was able to pull that excess rubber out of the hose which removed the blockage. Thanks Rob F! We're pouring nicely now!
If you are getting foam then finally poors fine you have a temperature problem. If you are getting constant foam then you are probably looking at a pressure problem. First of all make sure that you let your keg sit for at least 4 hours and get down to 38 degrees before you tap the keg. Also ensure that your pressure is set to at least what the pressure is in the keg (generally 13 psi). If you can, try to ask the beer manufactures (if you use a microbrewery) what pressure to set it at. One brew master told me to start at 15 psi and adjust from there.
If you still get foam and you can guarantee that the temperature is correct then you are getting some agitation from something else. Double check all your washers and even check your stop valve on the CO2 line to the coupler. Sometimes the lines are not the correct length or even the correct diameter, when the beer is forced through the line if it starts out thin and then expands or vice versa that gives beer a chance to get agitated and cause foam.
Finally the equipment that is used on these systems are generally not that great. I had a Danby Chill'n Tap and replaced the coupler and the tap and all the lines and that solved my issues, even though my problem was probably a cracked valve for the < $80 it cost me to replace everything it wasn't worth my time to figure out exactly what was wrong with it.
Posted on Apr 15, 2009
You may want to go through the fixes here.
http://www.kegworks.com/company/kegworks-community/home-bar/draft-beer-systems/troubleshooting#flat
Also download and read through the "Draft Beer Quality Manual" from the same site.
Hope that gets things flowing again..
Slainte
Logan
Posted on May 08, 2010
Go to micromatic.com and read the posts on the problem. It is not a pressure problem. It is a temperature problem. The beer in the line gets too warm and then it gets very foamy.
Be cautious about lowering the pressure because it will cause your beer to go flat.
Posted on Feb 19, 2008
Set co psi 8to10 lbs
Posted on Aug 03, 2007
SOURCE:
Bought a used danby DKC645BLS kegerator it is missing the co2 tank bracket that mounts on the back of the kegerator, where can I find one. Also the psi is set at 10 on the co2 tank and the beer comes out...
mark pasieka has an inventory of refridgeration, kegerator and bar related parts (as well as everything else)... he has this bracket in his warehouse right now... at least one... he also has tanks of CO2, oxygen acetalyne anything you may need... [email protected]
Oct 06, 2010 | Danby DKC646BLS Full Size / Pony Beer Keg...
I have a danby kegerator and i just tap the keg and all its doing is spitting air with some foam and i tasted the beer it was completly flat i need help asap!!!
try changing kegs sounds like the tube in the keg is broken the keg has a tube that runs to the bottom of the keg inside and u push air into the keg to push beer thru that tube and into a cool glass and down to ur gulletbut it sounds like u have a defective keg or an empty keg
Feb 24, 2010 | Danby DKC646BLS Full Size / Pony Beer Keg...
Inside fan on Keg Cooler needs to be replaced
Call them and ask to buy the part it should be pretty cheap. I just bought a replacement keypad for mine and they sold it to me right on the phone no hassles
Jul 23, 2009 | Danby DKC645BLS Compact Beverage Cooler
I have a danby kegerator that is spitting foam new keg settled for 3 hourd temp 38 3/16 line psi 9.5 help
Turn off the co2 for now. Turn it on when you need it, but start at a much lower pressure like 2-4 psi. Adjust pressure as needed.
Mar 22, 2009 | Danby DKC646BLS Full Size / Pony Beer Keg...
Foamy beer
Keg's are normally pressurized at 13 psi. If you only set yours at 8 psi then you are going to cause problems. You should always start at least the same psi that the keg is set to. If you can talk to the keg company as they all differ some. Common problem is to lower the psi which will cause foam until you reach about 1/2 full or a little less then you should get less foam but your beer will become very flat. Too much pressure is usually better than too little, even with too much pressure you'll see the beer come out fine but will start to foam when hitting the glass/pitcher. Also note that the coupler's that Danby use are very cheap, check the CO2 vale (between CO2 line and coupler) to see if there are any cracks or anything.
Sep 27, 2008 | Danby DKC646BLS Full Size / Pony Beer Keg...
Too much foam
well you are right the CO2 is causing the foam you may need to replace the regulator on the tank it is most likely bypassing the bellows inside...as a temp fix you can shut down the co2 and bleed off the air then just crack open the tank to (hand) regulate the flow ..
Feb 16, 2008 | Danby DKC646BLS Full Size / Pony Beer Keg...
New danby kegerator - tastes like rubber hose
There is a check valve inside the coupler of the danby kegs that cause this problem. The valve is mainly there to prevent beer from back-flowing when changing the keg. Next time you change your keg check for a little black plastic retainer and also a small white plastic ball inside the coupler. Remove those (or just smell it) and you should notice that this is the taste/smell your beer has. I removed mine after this discovery, and there isn't any issues with the taste/smell since. I've heard this is a common issue with the Danby D coupler systems. Also, you won't have any issues with beer backflow when you change the keg, provided the line going to the tap is empty (which usually is if keg is kicked).
Dec 30, 2007 | Danby DKC646BLS Full Size / Pony Beer Keg...
Foamy Beer
was the keg shaken or handled rough at all before hooked up?, and how long has it been hooked up?
Aug 31, 2007 | Danby DKC646BLS Full Size / Pony Beer Keg...
Danby Beer Keg dispenser fridge.
Draught (or Draft) beer is almost always un-pasteurized and therefore is more fragile. It should be consumed after being "tapped", and is generally truer to the flavors of the ingredients as pasteurization exposes the beer to heat and changes the flavor profile. Always use brewery approved beer line if you want to have foam free fresh tasting beer. Serving it through a plastic tube from the hardware or discount store or the plain vinyl tubing in your beer tap system you will wind up with a foamy, off tasting beer. Real draught beer is not pasteurized. It must be kept refrigerated between 35F. and 44F. A beer will become wild, turn sour and cloudy in a day or two. Below 44F. a keg of draught beer should last 20-30 days before it loses it's fresh brewery taste and aroma. Craft beers (micro brews) tend to have a shorter shelf life and you should contact the brewery for their recommendations. Why does my beer foam up? The 3 most often causes of beer foaming up are: The temperature of the beer keg The balance of the draught beer system pressures The cleanliness of the draught beer system I would suggest that you clean or replace the beer transport tube...
Aug 11, 2007 | Danby DKC645BLS Compact Beverage Cooler
Danby DKC646BLS Full Size / Pony Beer Keg Cooler Logo
2,662 people viewed this question
Top Danby Refrigerators Experts
William Miller
William Miller
Marvin
Marvin
Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
