Question about Mbt ZTS Inc. Mini-MBT, Mini Multi-Battery Tester for More than 15 Different Bat
Why should the voltmeter be connected in parallel n ammeter connected in series with respect to the component in the circuit
  • 1 more comment
  • Wayne Mineard
    Wayne Mineard May 11, 2010
    Because if you connect an ammeter in parallel with a component, you are actually creating another branch, thereby reducing the actual current through the component.
  • Gordon Meredith
    Gordon Meredith Jun 14, 2014
    If you connect an ammeter in parallel you are creating a low resistance current path around the component your trying to test. Your tester has a low resistance so you dont effect the current flowing through the component your trying to test. When a current tester is in parallel, it is a dead short, and you will probably burn out your tester.
  • Gordon Meredith
    A voltage tester is connectect in series so you can test the voltage dropped across the component in question.Voltage in volts equals the current through the component in amps times the resistance of the component in amps.If you know the resistance of the component, and the voltage across it you dont need to use a ammeter to find the current.Just devide the voltage by the resistance.
    New Friend:
  • 68 Answers
Think of electricity as water and an ammeter as measuring the volume of water and a voltermeter as measuring the pressure
Posted on Feb 06, 2009
How do I connect a 5 wire digital Volt/Ampmeter from my solar panel to my battery.
If you can identify which is the voltmeter and which is the ammeter, it should be simple. Say the solar panel has output wires of Red (positive output) and black (negative output). The ammeter goes in series with the load (cut the red wire and insert there). Voltmeter goes between Red (solar panel side usually) and Black. That accounts for four wires. The fifth wire may be an earth ground but I'd be guessing. If you can post a link from the manufacturer, I will comment further.
Oct 09, 2014 | RoadPro Road Pro 12 Volt Dc Portable...
How do you hook up amp meter for battery charger
DO NOT CONNECT IT to both poles + - !!! the amp meter have very small internal Ressistance, it blows of :) Connect it like in the picture d640b1d6-15c8-40ff-9dc1-eac0eb3b2a1f.png
Apr 16, 2014 | Cars & Trucks
Battery light on and off
The battery light means the alternator is not charging the battery. The charging system would need to be checked out when the light is on.
Feb 07, 2014 | 2001 Pontiac Montana
A voltmeter should be connected in a series with a component?
A Voltmeter is connected in parallel with a component because in voltage mode it has a high impedance and measures the voltage drop across the component being tested and does not affect any parts of the circuit.
An Ammeter on the other hand is connected in series with a component because in current mode it has a low impedance and measures the actual current through the component being tested
Nov 20, 2010 | Mbt ZTS Inc. Mini-MBT, Mini Multi-Battery...
Need apair passive crossover for pair of maxp64 600 watts
You can easily make one yourself. All you need are two non-polar capacitors of about 1 Farad each. Radio Shack and any respectable electronic component store have them. For a high pass filter (AKA crossover) connect in series with the speaker wires. For low pass operation like a sub-woofer, use it in parallel with the speaker.
Oct 02, 2009 | Car Audio & Video
Readings of Ammeter and Voltmeter.
The voltmeter will display 3V and the ammeter will show a small amount of current this is the current being used to swing the needle or in a digital meter the current used to get a sample.
May 07, 2009 | Kitchen Appliances - Others
Why must voltmeter be connected in parallel w/ circuit component
When connected in parallel it reads the voltage drop across said component.
When connected in series the current flows thru the meter allowing the measurement of the current flowing thru circuit.
Hope that helps.
Jan 04, 2009 | Mbt ZTS Inc. Mini-MBT, Mini Multi-Battery...
Why must be a voltmeter be connected in parallel with the circuit component?
to check voltage or Resistance that's the way it has to ne.
it is only used in series when checking amperage.
usually not over any circuit over 10 amps; depending on the
manufacturers ratings of your meter.
Paul
2002 hyundai sonata headlights
GENERATOR OUTPUT LINE VOLTAGE DROP TEST
This test determines the condition of the wiring from the generator "B" terminal to the battery (+) terminal (including the fusible link). 1. Be sure to check the following before testing: a. Generator installation and wiring connections b. Generator drive belt tension c. Fusible link d. Abnormal noises from the generator while the engine is running. 2. Turn the ignition switch to the OFF position. 3. Disconnect the negative battery cable. 4. Disconnect the generator output wire from the generator "B" terminal. Connect a DC test ammeter with a range of 0-100A in series between the "B" terminal and the disconnected output wire. (Connect the (+) lead of the ammeter to the "B" terminal. Connect the (-) lead of the ammeter to the disconnected output wire.) An inductive-type ammeter which enables measurements to be taken without disconnecting the generator output wire is recommended. Using this equipment will lessen the possibility of a voltage drop caused by a loose "B" terminal connection. 5. Connect a digital-type voltmeter between the generator "B" terminal and the battery (+) terminal. (Connect the (+) lead of the voltmeter to the "B" terminal. Connect the (-) lead of the voltmeter to the battery (+) cable.) 6. Reconnect the negative battery cable. 7. Connect a tachometer or the scan tool. 8. Start the engine. 9. With the engine running at approx. 2500 rpm, turn the headlights and other lights on and off to adjust the generator load on the ammeter slightly above 30A. Limit: max. 0.3V When the generator output is high and the value displayed on the ammeter does not decrease to 30A, set the value to 40A. Read the value displayed on the voltmeter. In this case the limit becomes max. 0.4V. 10. If the value displayed on the voltmeter is still above the limit, a fault in the generator output wire may exist. Check the wiring between the generator "B" terminal and the battery (+) terminal (including fusible link). If a terminal is not sufficiently tight or if the harness has become discolored due to overheating, repair, then test again. 11. After the test, run the engine at idle. 12. Turn off all lights and turn the ignition switch to the OFF position. 13. Disconnect the tachometer or the scan tool. 14. Disconnect the negative battery cable. 15. Disconnect the ammeter and voltmeter. 16. Connect the generator output wire to the generator "B" terminal. 17. Connect the negative battery cable.
Jun 05, 2008 | Hyundai Motor 2002 Sonata
Weak reception, broken surface mount component
You can not find any schematics for the Magellans.  The schematics are classified.  Even when repairing GPS's for Magellan we didn't receive full schematics.  If your talking about the RF cable connector on the I/O Board (the board attached to the rear housing), then it's an easy solder fix.  For the capacitor/resistor:  I'm not sure where you found the capacitor origin, but if it's black with four legs coming off and parallel with the IC then tell me and I'll msg you back the rest.
Oct 09, 2007 | Magellan RoadMate 700 GPS Receiver
Mbt ZTS Inc. Mini-MBT, Mini Multi-Battery Tester for More than 15 Different Bat Logo
272 people viewed this question
Top Mbt Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Mbt Measuring Tool and Sensor Expert? Answer questions, earn points and help others
