Question about Palm Treo 650 Handheld
Screen not synched
I have the palm treo 560 that i got off ebay. Was working perfectly until recently, i realized that the screen is not in sync. for instance in the menu screen, if i touch something that is first on the list, it brings up the second item. if i try to use the key pad on the screen. if i'm pressing 1 it shows 2 if i want 3, i have to touch way down in the corner for 3 to be used. before i could type a message and just click send on the screen, now it doesn't allow me to do that. I have to navigate with the arrow keys and highlight send so i can actually send my message. Can someone please tell me how to fix the problem or do i need to get a replacment screen?
Try doing a warm reset with a blow dryer
Posted on Feb 01, 2009
My palm treo is working perfectly fine apart from
change the screen....it ll costs u around 2000 bugs!!
Sep 30, 2009 | Palm Treo 700wx Smartphone
Treo 700p locks on Access Powered
I called Sprint tech support. With the battery in, hold the red power button down until the screen comes on that asks you if you're sure you want to reset your Treo (you will lose all information but hopefully you're like me and synch it frequently with your desktop.) I reset it and then synched it with my desktop and got almost all my info back - just had to redo email passwords and some settings. It was easy.
Sep 29, 2008 | Palm Treo 700p Smartphone
Transfer of treo programs to Palm Centro
The Centro and Treo are virtually identical. Have you tried reinstalling the applications from scratch on the Centro (vs. relying on Palm synch to automatically synch all applications)?
Aug 25, 2008 | Palm Treo 600 Handheld
Treo 650 Problem
probably dodgy software conflict. Try taking battery out and leaving for anhour or two then take out sim carrier. Put battery back and see if it starts properly. If not looping put sim in and try to switch phone on. if this works then there is a problem with software you have loaded so switch off back up before you sync. Then once you have synched the phone add back applications one at a time until you find the one that causes the problem. Of course you have to do it all over again once you have found the culprit!
Another cause, if you have attempted to upgrade the firmware, is a failure of the upgrade process. if you can't get this to work I am afraid the phone is bricked and needs to go back to Palm for repair.
Kevan ;-)
Nov 19, 2007 | Palm Treo 650 Handheld
Calendar not synching properly
hi
often there are events with a regular cycle
the outlook just repeats its every week, month or year
if you dont define the 'end' period it just keep creating them
set the period to sync to 6-12 months and try again
D
Oct 14, 2007 | Palm Treo 750 Smartphone
Syncing a 600 and 650??
I have Treo 600, 650 and old Handspring Visor -- all sync perfectly well using Palm Sync Ver. 4.0.1 software.
Sep 22, 2007 | Palm Treo 600 Handheld
Palm treo hot synch
try restarting the computer. it works for me
Aug 13, 2007 | Palm Treo 600 Handheld
How do I get the hotsync to sync everytime there is a change?
You may be used to PocketPC ActiveSync. HotSync is an asynchronous synch model - you synch upon demand but not continuously. Pocket PC devices synch all the time while in the cradle. There are advantages to both models. If you want to synch a Palm OS device, you need to press the button. There are some extra appliactions available on www.palmgear.com that will force your device to synch upon a schdule.
Sep 12, 2005 | Palm Treo 600 Handheld
Problem syncing with two computers
The HotSync Manager was not designed to work this way. While it may seem like a good idea to do what you are doing, I would never consider doing it. HotSync was designed to be a one-to-one relationship between a set of data on your PC and a set on your handheld. You are giving contrary messages to each PC by using it this way. If you synch to an exchange server (via your Outlook account) you can get away with doing this because PocketMirror or the palmOne Outlook conduits and other conduits have settings you can make to notify HotSync that you are 'two-timing' :-). However if you synch to Outlook in work and then to Palm Desktop at home (I suspect this is your scenario), I disrecommend this. I recommend setting the Home PC to be a slave. That is, I set the conduits at home to be handheld overwrites desktop for the four personal information conduits - Calendar, Contacts, To Dos and Memos. Then when I am at home if I want to change some data, I add it to the handheld not on the PC. That way you have a kosher set of data that is up to date on the handheld and on your work PC. When you synch to the home PC, this data is cloned to the home PC from the handheld. You can continue as you are but you will always have some uncertainty on your data integrity. Losing precious contacts or not showing up for a key appointment is a bad deal.
Sep 11, 2005 | Palm Treo 650 Handheld
Synching treo 650 with 600
In a nutshell, make sure you have a recent synch to your PC of the 600. Install the Treo 650 desktop software Synch to the username of the 600 Your are done. You should rename the Treo 600 or hard reset it (you will get data corruption if you synch two devices with the same username to one PC). If you are paranoid, you can make a backup copy of your c:\program files\palm\ folder to begin with. This contains most of your settings and extra software on the 600. As you are an Outlook user, your personal data is probably in a PST file or it is stored in Exchange.
Palm Treo 650 Handheld Logo
53 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
Raj Patel
Andrew Taylor
Andrew Taylor
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
