Question about Memorex MVDP1077 Portable DVD Player
Won't pickup the dvd everytime
Some dvd's won't come up it says loading and the disc is spinning and then it reads stop with no movie set up
    Problem Solver:
  • 10 Answers
There are a few possibilties
1 make sure the disc is clean
2 your lens may need cleaning
3 some dvd players don't read burn copies of disc's some just read +R discs some just read -R disc
Posted on Jan 29, 2009
My Toshiba Blu-Ray player, BDX 2700, will start to load a movie but it stays at 00:00:00 and it won't continue or play. What's wrong?
either a mechanism problem---disc not turning etc or an electronic issue --someone would have to open the unit and insert a disc to see what is happening----also unlikely but possible the optical pickup that reads the discs is dirty or near failure---this will usually show up first on blu ray before a regular DVD.
Apr 23, 2012 | Toshiba Televison & Video
No disk message
Hello
Check it with a standard company burned disc. if it does not read it, make sure that either the disc does not spins inside, or the laser pickup unit is faulty. Just open the top cover of the set, and insert the disc, see whether it spins at high speed at first and then slows down. if the disc do not spind, the sled motor is faulty. If the disc spins, and still the player do not read disc, the laser pickup unit should be repalced.
Feb 27, 2012 | Samsung DVD-E235 DVD Player
Will not play
Hello Brandon
The fault is with its Laser Picku Unit itself. The sled motor, the motor that spins the disc inside the DVD player, should wok like this as you details here. Just see, when we put in a disc inside any disc player, it will sart spins, after it has been loaded properly into the mechanism. The the laser pickup unit will start scan the recording on the disc, reads it; recogonize its contents, then starts to play from the first track. This is an automatic process ot all disc players, and suring this reading process, the spin speed of the disc will vary, may stop, or rewind to a little and then spins again. This is a common process to all the playeres.
Here, with your DVD player, the laser pickup unit tries to read the tracks, but fails, the again it starts to readit, fails and finally show a 'No Disc' display, as it hasn't got any details about the recoding at the inserted disc.
There are three main causes for this fault. The first one is with a faulty strip wire. This wire is one, that connects the laser pickup unit with main board. You can see a flat ribbon type cable that connectes to laser pickup unit at the mechanism, to the main circuit board of the player. Replace this cable fist. This cable can be purchased from most of the electronic spare part shops at your town, and won't cost more.
The second chance is with dirty or dusty laser pickup unit lens. To cclean this lens, the easisest way is to put in a lens cleaning disc into the unit, play it for at least three times, by ejecting it out and get it into. This process will clean up any dirt or dust accululated on the lens, and will help you. The cleaning disc also can be bought from most of the electronic spare part selling shops at your town.
The third chance is with a faulty Laser Pickup Unit istsef. If so, there is no repair to this unit other than replacing it with same type and number. It is a skilled work, and you have to disassemeble and reassemble the deck mechanism. If you have experience to dothis, you can do it by yourself at home Ok
Please do rate this solution, if it found helpfull to you.
Dec 29, 2011 | Durabrand PDV-709
Bush portable DVD player will not load my disc
Hello
Just put in an audio CD disc or an MP3 disc, and see whether it reads them or not. If the player can read these discs, and only refuses to read DVD discs, make sure that the laser pickup unit of it is faulty, and should be replaced with same type and number. If none of them reads, there are two possibilities, the first one is of laser pickup disc itself and the second one is the strip wire [a flat flexible cable connected between laser pickup unit and the mainboard of the player] is faulty. First replace the strip wire. If it helps you, it's OK. If not replace the laser pickup unit also. The strip wire can be bought from most of the electronic spare part shops at your town. When buying laser pickup unit, its number must be noted, and exact replacement should be done. Otherwise, it won't match with the main board. OK.
Nov 08, 2011 | Televison & Video
I have an Orion FTDV2004A tv/vcr/dvd combo. I was playing a DVD movie. When I paused it, it would not start playing again. Now, every DVD I put in, says "reading" and then "incorrect...
Hello
Just power OFF the set by its main power OFF switch, and switch in ON, while listening very close to its mechanism side and see whether there is any sound of disc spin. If disc do not spin inside the mechanism, due to a faulty sled motor, the fault you descrbes here will occur. If disc spins inside, and still it does not reads the disc, the laser pickup unit is faulty and should be replaced. OK.
Nov 06, 2011 | Orion FTDV2004 20 in. TV/VCR/DVD Combo
When loading a dvd it displays, "NO DISK". Is it
Hello
There are mainly three motors for most of the DVD players. One to spin the disc we insert in, other to load the laser pickup unit to-and-fro inside it to read the disc and an other one to load the tray mechanism 'in-out'. According to your description, the disc spins inside, and you can hear its spin. So motor which spins the disc has no trouble at all I should say. Then comes to the second motor that moves the laser assembly inside it. If it do not work, the laser pickup unit won't move and no reading will take place and 'No Disc' display will be the result. The last chance is with Laser Pickup Unit itself. Just get this unit repaired by any well experienced service technician or by the authorised service center, because, there are special tools to open this unit. As it is a compactable one, more care should be given to it while repairing. Suspect the second motor I described earlier, and the Laser Pickup Unit. OK.
Jun 14, 2011 | RCA DRC628 Portable DVD Player
Attempts to load then reads no disc
The problem is with the lens assembly. sometimes you may have to replace it(lens assembly) or optical pickup
Jul 03, 2009 | RCA DRC629N Portable DVD Player
Sony Portable Cd/DVD Player DVP-FX810, "loading", "check disc"
Hey Teddybearman, I have exactly the same problem as you have. Did you manage to find out how to fix it?
Regards,
Seqdarsca
19 July 2010
Jun 07, 2009 | Sony DVP-FX810 Portable DVD Player
Unknown disc error message
OKAY GUYS TRY USING THIS VERY COMPATIBLE MEDIA
(MEMOREX BRAND DVD-R) THIS WILL SOLVE A LOT OF YOUR PROBLEMS
Aug 27, 2007 | Televison & Video
Memorex MVDP1077 Portable DVD Player Logo
336 people viewed this question
Top Memorex Televison & Video Experts
 Grubhead
Grubhead
Radames Pagan
Radames Pagan
Are you a Memorex Televison and Video Expert? Answer questions, earn points and help others
