Question about Ingersoll Rand Type 30 Electric Driven Two Stage Horizontal Air Compressor 120 Gallon Fully Packaged Ir 2545E10VFP
Service of ingersoll rand
Want to do a service on a compressor what are the parts required and what are the procedures
  • 3 more comments
  • anzo54k Jan 31, 2009
    The compressor is a fixed belt driven compressor about 10 years old
    last tune up about 2 years ago
  • anzo54k Feb 06, 2009
    was told something about a pressure switch and after draining oil to run diesel for 5 min to clean is this advisable
  • Anonymous Feb 18, 2009
    How do you reset the timer on it after the PM?
  • Rick Wymer
    Rick Wymer May 11, 2010
    IR Makes Many Compressors, do You have a Specific Model #?? Year of Manufacture?? Single-Stage, or Two-Stage?? How often Has this Unit had Tune-Ups??
  • 32 Answers
Actually not a lot of Parts.
1) Remove & Clean the Air Intake Element
a) Check and see IF the Secondary Pump Head has a Filter/Breather and Clean That also...
2) Drain and Change the Oil (per Manufacturer Requirements-I PREFER Ingersoll-Rand Compressor Oil Myself) Don't Over-Fill!!
3) Check the Wear on the Drive Belt(s) and Tension ( Deflection shouldn't be more than 5/8" Between the Motor and Compressor)
4) I usually Blow out the Motor with about 20psi of Air, since it probably has Sealed Shaft Support Bearings, and is the Brushless Type, Not Much to do. Pull Off the Inspection Plate, and Check for How Clean the Inside of the Motor is BEFORE you "Air-it-Out", if there are any signs of Greasy Dirt, you may want to get some Electrical Spray Cleaner, and spray just enough to Wash the Contaminants off...
5) DRAIN Your Main Holding Tank: Drain Until there is NO Moisture Left, just Dry Air. You could Drain into a Pint Mason Jar-Just make Sure you Only Open the Drain just enough to let a Minimal amount of Flow, and see what Contaminants are in your Tank...(this should be done at least Once a week anyways) I installed a Auto-Drain on Mine, AND a Auto Water Drain on the Regulator is a Great idea too...
6) Check ALL your Wiring Connections, make sure they are Tight...Vibration will cause them to Loosen.
7) Sometimes is a Good idea to Check Your Keyways on Your Pulley Shafts for Wear, should be a "Press-Fit"
8) Check the Pulley/Belt alignment, make sure it's running True. IF Not, Check Your Motor & Compressor Mounting Bolts
I usually do a PM (Periodical Maintanence) about every 3 Months on My Compressors...and don't forget to Oil Your Air Tools Before each Use.
Posted on Jan 31, 2009
  • Rick Wymer
    Rick Wymer Feb 06, 2009
    Regarding using DIESEL to Clean Out Residual Oil, ABSOLUTELY NOT!!
    Your Using a Product That is to Thin to Wash out the Crankcase, BUT, Your taking a Big Risk of:
    1) Washing Contaminants into the Journals, and Possibly Scoring the Journals (that would be a Big Mistake) as I have seen some People Run their Compreesor with Diesel in the Crankcase, BIG NO-NO...
    2) NOT getting ALL the Diesel Fuel out of the Crankcase BEFORE adding Fresh Oil which would dilute Your New Oil, and the ability for it to do it's Job correctly!!
    3) BEST idea: Get a Strong Magnet, and Install it in the Drain Plug or the Immediate area (one where you can get to it), and it should Catch all the Ferrous Metals
    4) Plus in some Remote (Rare) cases, since Diesel is Combustible you could cause a Crankcase "Problem" IF something went wrong and the Compressor got to Hot, then someone Gets Injured and/or you have a Junk Compressor....
    In Closing:
    Just Drain Your Oil as Best you can, and add FRESH oil and be about your Business.
How to change from BAR to PSI on INGERSOLL RAND INTELLISYS CONTROL for INGERSOLL RAND SSR-6-20-125 AIR COMPRESSOR
Ingersolll Rand website support section should be able to provide a manual.
Failing that contact customer services.
Aug 03, 2016 | Ingersoll Rand Air Tools & Compressors
What level does the coolant need to be in the sight glass?
About 31,000 results (0.83 seconds) Search Results
    [PDF]IRM-G-8780 2-25hp US - Ingersoll Rand Air Compressor
    www.ingersollrandproducts.com/...
    Ingersoll Rand Industrial TechnologiesIngersoll Rand compressors are not designed, intended or approved for breathing ...does not approve specialized equipment for breathing air applications and ... unmatched service to meet your needs. ... drain, and low-oil-level .... Oil Sight Glass ... Value Package (5, 7.5, 10 & 15hp) An economical choice in a dependable ...
    [PDF]Owner's Manual - Air Compressors Direct
    www.aircompressorsdirect.com/.../irmanual2340_2475_2545_7100_15t...
    installation, operation and maintenance of your Ingersoll-Rand air ... An air-cooled aftercooler, low oil level ... for Models 2340, 2475, 2545, 7100, 15T & 3000 ... Ifcooling of the discharge air is required, .... motor does not have this button and the unit does not have a ..... l Drain compressor oil and clean oil sight glass.
    [PDF]XF 7.5 - 15 EP 7.5 - 15 HP 7.5 - 15 XP 7.5 - 15
    diagramasde.com/.../Manual%20comp%20ingersollrand%20SSR-15.pdf
    EP 7.5 - 15. HP 7.5 - 15. XP 7.5 - 15 ... The Ingersoll-Rand Company Rotary Screw Air Compressor that has been filled prior to its ... after shall have its AIREND warranted for twenty four (24) months from the ... comes first, when using ULTRA COOLANT.Coolant ...... check coolant level in the sight glass on the separator tank.
    Ingersoll Rand Air Compressors - About Air Compressors
    www.about-air-compressors.com/Ingersoll-Rand-air-compressors.html
Feb 08, 2016 | Ingersoll Rand 15 Horsepower Rotary Screw...
Craftsman service manuals
I am assuming your enquiry is about the type of lube oil used in the pump section of the compressor. It would have helped if you had provided the model number of the compressor. In any case craftsman suggests all oil lubed compressors use synthetic non-detergent compressor oil.
Something like this would be required.
http://www.sears.com/ingersoll-rand-ingersoll-rand-38440228-compressor-oil-synthetic/p-SPM2881704102?prdNo=1&blockNo=1&blockType=G1
Aug 13, 2014 | Air Tools & Compressors
I need a manual to rebuild a Type 30 Model 2475 ingersoll rand air compressor. Thanks
Dear Joe Bell,
This is Rodciel L. Camacho of VISMIN compressed air care center we are specialize in ingersoll rand air compressor.
You mean a overhauling kit?The part number of that is 34319469.
Hope i can help you..
May 07, 2012 | Ingersoll Rand - Rand Type - 30...
Need to know what compressor oil to use for 185 ingersoll rand compressor
The parts store,napa sells a air compressor oil that is compatible,It is called simply,air compressor oil.It is made just for compressors.
Oct 06, 2009 | Air Tools & Compressors
The oil fill plug broke on my Ingersoll Rand R 242-5n
Remove it and try a NAPA auto parts store. If they can't help I'd try Graingers.
Lou
Aug 30, 2009 | Ingersoll Rand Compressors 5-HP,...
Manual
Ingersoll rand parts and manuals are available at www.grainger.com, or call you local grainger store, they have a very good customer service for faxing parts lists to your place. Notice: some Ingersoll rand compressors have been recalled. Check the address below. If you have general questons about a problem that you are having, post again. Good Luck
http://www.cpsc.gov/cpscpub/prerel/prhtml02/02108.html
Jan 09, 2009 | Ingersoll Air Tools & Compressors
Ingersoll Rand Type 30 Electric Driven Two Stage Horizontal Air Compressor 120 Gallon Fully Packaged Ir 2545E10VFP Logo
298 people viewed this question
Top Ingersoll Air Tools & Compressors Experts
elunsford
John Trevino
Joe Garcia
Joe Garcia
Are you an Ingersoll Air Tool and Compressor Expert? Answer questions, earn points and help others
