Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
There is power to the tv but it wont turn on.
I had a power surge one night and now the set wont turn on.
    Genius:
  • 2,920 Answers
It probably burned one of the circuit boards youll need to call a repairman out to lookit over
Posted on Jan 29, 2009
My 32 LED TV won't turn on and there is a dim light that comes on and off as it is on the off position
There may have been a voltage surge that affected the electronics. You might try unplugging the set and while so holding the power button . Than after about 30 seconds release the power button plug it in and turn on. If still no go, then the surge damaged probably the power supply section of tv. That is the first component to receive the hit of the surge and the most likely to be adversely affected.
Aug 30, 2015 | Televison & Video
Wont turn on but tries too come on,power light blinkink
Internal power supply failure. Was there a lightning storm in your area recently or utility work being done recently? This two things usually kill TV's and other electronics with surges when power is restored. If the set is under warranty call the manufacture, if not, call you homeowners insurance agent to see if the damage is covered w/or w.o. deductible. At least you can get something toward repair/replacement costs. Future fix, purchase and install a surge arrestor in your main AC panel for the whole house or buy a power strip with a built in surge filter/protector for your expensive equipment.
Jan 23, 2014 | Samsung PN51D490 3D Plasma TV
A power outage last night. The tv was off, now it wont turn on. A blinking timer light on the front of tv is on.
Always include model numbers since problems are sometimes associated with particular models. This may be a sign that a line surge during power fluctuations has damaged the power supply. There are a least two supplies in any modern set; a small supply that provides voltage to the remote circuitry and this one is always on. The second supply is the main one that is turned on when the set is to be used. Reluctance to turn on is often a signal that certain components (capacitors) are failing in the main supply and they will continue to degenerate. Try pulling the plug and leaving the set overnight without any power. If a circuit is only 'confused' (locked up) this should reset everything. If it still will not turn on, then either the small supply for the remote circuitry was damaged during a surge or that the main power supply is not responding to the power on command.
Jun 09, 2011 | Mitsubishi Televison & Video
72 inch rear projection tv took a power surge last
if ure handy pop the back off and there should be a main power board and a fuse on it, make sure you use the same fuse if it is blown do not stick another type or size in it, put it back together and turn it on if it blows again it will be somthing else if not it should work
Sep 10, 2009 | Televison & Video
Tv won't turn on
Was the power button from the main outlet(wall) kept in the ON (position)throughout the knight! i.e. switched off by the remote only? In that case a power surge druing the night could have fried some part of the TV circuit. In such case there are many fuses inside the TV which need to be checked out If the main tubes are gone kaput then better to replace the entire set......................sodeep
Sep 03, 2009 | Panasonic CT-32HXC14 32" TV
TV wont turn on
have you checked the fuses inside the set. The power outage could have surged just enough to blow the fuse. Dont forget to unplug it when you check the fuse.
Jan 21, 2008 | RCA P52937 52" Rear Projection Television
Tv won't turn on
I suggest you unplug the set for about 15 minutes and then plug it in and try again. Sounds like you may have had a power surge/bump in the middle of the night. Althoguh you are using a surge protector, doesn'r mean the devise hooked to it can't lock up during a power surge.( Surge Protectors are an insurance policy only, not a garrentee ). If unplugging the set and waiting doesn't fix it, it will need to have the power supply section of the board repaired. Good Luck
Ed
NC Electronic
Mills, Wyoming
Jan 06, 2008 | Protron PLTV-32 Television
RCA g36788LV TV
check fuse n power supply section
Oct 27, 2007 | RCA G36788LV 36" TV
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
94 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
