Question about Dell Inspiron 6400 Notebook
Laptop overrheating Hi all Recently my laptop is over heated and within one hour it shows power is almost out, change the battery or plug in the AC power.  What might be the reason for this sudden degrading of my laptop battery Note: i used to plug in the ac power continuosly for almost 12 hrs. Will this damage my laptop.
  • 68 Answers
Probably dust in fan duct. Open the lid at the bottom, carefully remove a fan and vacum the dust then put everything together
Posted on Jan 29, 2009
  • 382 Answers
Possible cause of over heating is usually from dust in the cooling fins. A can of compressed air will usually do the trick. Depending on the amount of dust, sometimes it has to be disassembled to remove and clean. The lack of proper cooling makes the fans work harder and the heat also degrade the batteries performance and deminish its charge capacity.
Laptop wont turn on.
*Take out the battery,
*Remove main supply,
*Hold power button down for 30 secs,
*Put only power supply in, do not put battery in
*Turn laptop on
*Put the battery in.
Aftermarket Car Headlights
Jun 11, 2012 | HP Pavilion dv6-1030us Notebook
The watch will show incorrect time within hours of
Usually this is a faulty battery - make sure you go to a reputable jeweller and have the battery changed. Even somewhere like Kmart will only use decent quality batteries.
I bought batteries off eBay once that were very cheap, and I had this problem all the time. Now I only buy Energizer, Duracell, etc.
Nov 25, 2009 | Freestyle Watches
MEDION MD96640 - plugged in, not charging
There is a possibility that the battery is defective.
Turn the laptop off and remove the battery and AC power. Clean the brass contacts on the battery and the laptop.
Plug in AC power only, boot the laptop up without the battery and go into the BIOS and set the BIOS to default settings. Save the changes and let the laptop boot into Windows. Once in Windows power down the laptop again and remove the AC power.
Reinsert the battery and AC power and boot the laptop up. See if that has helped.
Good luck.
Sep 21, 2009 | Computers & Internet
Inspiron runs on ac power but not battery
Sounds like you have a faulty ac adapter or jack on the laptop and its not charging the battery fully. More like a trickle charge. I would recommend leaving the laptop on default power settings or the best power settings and see if their is a differance in life or either shutdown the laptop and let it charge until the light shows fully charged.
Jul 20, 2009 | Dell Inspiron 1501 Notebook
T20 batteries wont stay charged
It might be that you are using older batteries. However, you should try dimming your backlight to the lowest possible setting and performing any other power-saving actions such as limiting the processor's power (if available on your laptop.) Hope this helps.
May 09, 2009 | IBM ThinkPad T20 2647 Notebook
I have a toshiba laptop, and in the last few weeks something weird started happening. When the laptop is plugged into the AC, the power meter in windows tells me that the power source is still batteries,...
Change your AC charger.
It's NOT charging "When the laptop is plugged into the AC, the power meter in windows tells me that the power source is still batteries, and the battery level drops by about 1% every few hours"
That's the reason why: "battery has completely died"
If you do not change it you'll continue to "still it gives me the same low battery indication and will not turn on. "
Jan 04, 2009 | Computers & Internet
I walked away from my laptop for a few hours. When I returned to use it the screen was black. Since that time the low battery indicator has been lit (pink). I alway have it plugged in so It should not be...
This isn't a software issue. If your laptop is still under warranty have it serviced. If not, see if the costs involved are even worth it. Something within the hardware sounds like it caused a chain reaction and has affected more than just the battery.
Nov 05, 2008 | Gateway Computers & Internet
No power
Better to connect another AC adapter and check it.If ur laptop have Warranty then please take it from nearest Service centre.
Thanks,
Feb 12, 2008 | Tatung (TWNB12N01) PC Notebook
Dell Inspiron 6400 Notebook Logo
81 people viewed this question
Alun Cox
