Question about NEC DTP 8D-1 Corded Phone
Phone Auto Answer
I have a NEC Model 770012 Phone which when automatically answers calls and projects them through the speaker. How do I turn this feature off? Are there any other features like this which I should be aware of?
2 Suggested Answers
SOURCE: Nec DTerm Series i - Feature Light Flashing URGENT
Thankfully I have found a solution that has worked.
A 'winking' (flashing) feature button indicates the station is in call forward - all calls mode.
To cancel this setting do the following
Lift the handset or press speaker
Dial the access code 4 + 2 (set as default)
Receive confirmation tone and restore handset or press speaker
I have found the manual at the following link to be the best resrouce ever - very easy to understand
http://www.nec.co.th/html/download/Manual/Features%20&%20Specifications.pdf
Posted on Jul 08, 2008
When someone in office calls my phone the intercom picks up instead of ringing. How do I turn that off? we use the NEC 80 version 2.25
The phone people in the office should be able to turn off call forwarding and auto answer
Call Forwarding
Call Forwarding - NECDSX.com
www.necdsx.com/dita/features/call_forwarding/call_forwarding_feature.html
  1. Cached
  2. Similar
Call Forwarding permits an extension user to redirect their call to another ... in the Call Forwarding programming mode - the same as pressing INTERCOM and ...
Jul 29, 2016 | NEC Lands Phones
How to divert calls
You can forward all to another extension or to an outside number. You can also forward busy/no answer to both of those, but then it'll cancel your busy/no answer to voicemail. Speaker 41 plus ext or 9 plus outside number will set CF ALL, speaker 43 will set CFBNA, 42 and 44 to cancel. These are the default codes for NEC pro II, Elite, and IPK. The DTP phone also works on other systems that have different codes.
Jul 23, 2014 | NEC Dterm DTP 16D-1 Corded Phone
How to change the display name
Consult the owner manual or if do not have Google the model number for manual. That info has to be in the owner manual--last resort call the customer service for the unit.
Aug 28, 2012 | NEC Electra Elite Dtu-8d-2 - 770012 -...
How to make auto answer incoming phone (hand free) with LG HBM 570 bluetooth headset in case driving car
Hi, LG HBM 730 Bluetooth Headset Wireless Headset does have the ability to auto answer a call. But it does that automatically (does not need settings for it).
Also you can set auto answer from your cell phone.I don't know the model of the cell phone you are using at the moment. So you will need to use the manual of the cell phone to know how to auto answer calls.
When you set the cellphones auto answer, then it will auto answer on your LG HBM 730 Bluetooth Headset Wireless Headset..
Have a nice day
Mar 02, 2011 | LG HBM 730 Bluetooth Headset Wireless...
How do I set up the fax feature?
Introduction The HP All-in-One can receive faxes automatically or manually depending on the Auto Answer setting. If the Auto Answer option is set to On (the default setting), the HP All-in-One will automatically answer incoming calls and receive faxes after the number of rings specified by the Rings to Answer setting. (The default Rings to Answer setting is five rings). Refer to the given instructions to receive faxes automatically or manually. Receiving faxes The HP All-in-One can receive faxes automatically or manually. Receiving a fax automatically To receive faxes automatically, set the Auto Answer option to On (the default setting). The HP All-in-One will automatically answer incoming calls and receive faxes after the number of rings specified by the Rings to Answer setting. (The default Rings to Answer setting is five rings). Receiving a fax manually If the HP All-in-One has been set up to receive faxes manually (the Auto Answer option is set to Off ), or you answer the phone and hear fax tones, use these instructions to receive faxes.
  1. Make sure the HP All-in-One is turned on and you have paper loaded in the input tray.
  2. Remove any originals from the document feeder tray.
  3. Set the Rings to Answer setting to a high number to allow you to answer the incoming call before the HP All-in-One answers. Or, turn off the Auto Answer setting so that the HP All-in-One does not automatically answer incoming calls.
  4. If you are currently on the phone with the sender, instruct the sender to press Start on their fax machine.
  5. When you hear fax tones from a sending fax machine, do the following:
    1. Press Start Fax Black or Start Fax Color on the control panel of the HP All-in- One.
    2. When prompted, press the down arrow to highlight Receive Fax Manually , and then press OK .
  6. Press Start Fax Black again.
  7. After the HP All-in-One begins to receive the fax, you can hang up the phone or remain on the line. The phone line is silent during fax transmission.
    Trust this is helpful. Please vote. :)
Dec 11, 2010 | HP Photosmart C7280 Laser Printer
I can't cancel the Call Forward Busy/No Answer feature . . .
The installer could have changed the default codes, or try 45. So you would hit speaker than 45. If not try it from the operator phone(x) press speaker, 44.
Jun 01, 2009 | NEC Electra Elite DTU 16D-2 Corded Phone
Turn auto answer off?
You probably have auto answer turned on in your phone. The headset does not have this feature. You must find it in your phone to turn off auto answer while headset in use.
ps- second user- You canot use the phone handset with bluetooth device on. At least none that i know of.
Feb 25, 2009 | Jabra BT350 Bluetooth Headset Headset
NEC DTP 8D-1 Corded Phone Logo
207 people viewed this question
Top NEC Lands Phones Experts
Craig Butler
Craig Butler
Oloyede Monsuru
ray gallant
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
