Question about GE 28112EE2 Cordless Phone
How to set ringer for more rings prior to going to recorded msg
    Genius:
  • 2,035 Answers
From the Handset Setup Menu:
1. Press the caller ID-volume ( up or down arrow button) button to scroll to the RING TO ANSWER sub-menu.
2. Press mute/program button to enter the menu. RING TO ANSWER 3 4 5 6 TS shows in the display.
3. Use the caller ID-volume ( p or down arrow button) button to scroll to the your selection. The default setting is 5.
4. Press the mute/program button to confirm. You will hear a confirmation tone and the new setting shows in the display.
NOTE: If you select Toll Saver (TS) the unit answers after the 3rd ring if there are NEW messages, OR the unit answers after the 5th ring if there are NO new messages. This allows user to access their answerer from another location and then hang up after 4 rings to save long distance charges.
Posted on Jan 29, 2009
  • 153 Answers
Go to the settings in menu
  • nicra7 Jan 29, 2009
    there u wil find the ringer menu
    u can change it there
Calls go into msg and phone does not ring; volume set. When it's on vibrate only, I get the vibrasion, but when volume turned up, no sound. How can I correct
The phone type makes a difference.
On iPhone check Settings / Do Not Disturb.
Also Ringer Off on left hand side.
Volume has to be adjusted with Home Screen in view.
Oct 01, 2015 | Tracfone Wireless LG 440G
When answering mode is on I do not want to hear the ringing(4x) tones before going to answering.I've switched off the 'call screen' option. still I hear the ringing although not recording at least.
Just set the ringing volume to off.
You can choose from four ringer volume settings (off, low, medium, and high) separately on each handset or the base.
With the phone in standby, press or on the handset or VOLUME or VOLUME on the base. The handset or base sounds the ringer at that level. Use on the handset or VOLUME on the base to make the ringer volume louder. Use on the handset or VOLUME on the base to make it softer or turn it completely off.
Note: If you set the ringer volume to Off, the handset or base won't ring. Other handsets or base will ring according to their individual settings
May 29, 2015 | Uniden DECT 6.0 Cordless Phone ID
I have a Meridian 9316 phone in my office and it continuously rings with no pause how to I stop the ringing besides from turning the volume off
Setting the ring tone and ringer volume You can choose one of the four different ring tones and set the ringer volume. To set the ring tone and volume: 1. Make sure that the ringer is turned ON. 2. Press the Set Options key. 3. Press the down arrow three times or press [3] to go directly to the item. 4. Press [3] and follow the instructions on the display. When picking the ring tone, press the volume bar to adjust the volume. 5. Press [Save] to end when you are satisfied with the ring tone and ringer volume.
Apr 30, 2015 | Nortel Meridian 9316CW - 1 Line...
No sound in ringer
First You Go to Phone setting in Sound & Ringing Setting and check the Phone Ringing Setting if Ringing Setting alrdy OK
But No Ringing So
Secnd Option:
Your phone Ringer Default SO Please change Ringer
and Ringing Sound Problem will Solved
Aug 27, 2010 | Sony Ericsson Cell Phones
No ringtone
First Option:
You Go to Phone Setting in ringtone setting and check the Ring tone Setting If Ring tone Setting Ok But Not Ringe tone So
Secne Option:
Your Phone Ringer Default So Please change Ringer
And Ringing Problem will Solved Quickly
Aug 15, 2010 | Nokia 1100
Cannot hear the phone ringing that i am calling?
First Option:'
You Go to Phone Setting and Ringing Setting If Phone Ringing Setting ok
So
Secend Option:
Your Phone Ringer Fault So Please change Ringer and Ringing Problem will Solved Quickly
Jul 09, 2010 | Motorola Mobility Tundra VA76r Cell Phone
Pebble ringer inop
1 try this go setting initial/setup/master clear
password 000000 (6time) or full up 0 .
Mar 03, 2008 | Motorola Mobility PEBL U6 Cellular Phone
How to set Ans/Fax receiving mode of SCX-4521F?
Try setting the receive mode to FAX/ANS. If you want the fax not to pickup before a phone call comes in, you should set the number of fax rings to a higher number, like "5" for instance. Set the answering machine rings less and the fax higher. The machine will usually record a message first and then detect a fax tone.
Jan 24, 2008 | Samsung SCX 4521F All-In-One Laser Printer
Motorola W 490 individual ringtone
To assign a ring alert (ringer ID) to an entry:
Phonebook > entry, then press
Options > Edit Contact > Ringer ID > ringer name
Note: The Ringer ID option isn’t available for
entries stored on the SIM card.
To activate ringer IDs:
Settings > Ring Styles > style Detail
> Ringer IDs > On
Dec 13, 2007 | Motorola Mobility RAZR V3
GE 28112EE2 Cordless Phone Logo
60 people viewed this question
Top GE Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
