Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
Hotpoint Aquarius WD440 Error
Hotpoint Aquarius WD440 washer/dryer machine has recently starting stopping mid-cycle with the Rinse Hold light flashing along with the On/Off light flashing. This is just before it takes in the conditioner and leaves the clothes wet as well so no spin. Any ideas what the problem is?
  • 5 more comments
  • Anonymous Jan 05, 2008
    why does the on/off, drying high heat, reduce creases, time saver lights continually flash when I attempt to any wash programme. It sounds like the machine is filling up with water for about 2 mins then eventually stops and nothing happens.
  • Anonymous Mar 31, 2008
    Yes I have exactly the sam problem, any Ideas of how I can resolve it.
    I have got a Hotpoint WF340P which has exactly the same fault.
  • mollie82 Jun 03, 2008
    when I try to put a dry load on the high heat, reduce creases, time saver, on/off button and the dry button all flash and i cant turn the dryer off. If its the filter how do i clean the filter??
  • laurencarr19 Nov 30, 2008
    I have the same problem it just stops mid cycle and the Rinse hold button flashes as well as a couple of other buttons on/off button flashes as well. drum is full of water and clothes are soaked. Im trying to find out what the problems is. I again cant see any visiable filter as I was told that could be blocked.
  • Anonymous Dec 03, 2008
    Yes my hot point WD440 starts to fill up then stops and the on/off light as well as the reduse creases light flash and the moter keeps whirring i unplug it and wait for the door to unlock; then i remove top cover and clean all the holes out where the water comes in from with a copmressed air gun, is there another filter somewhere?
  • Anonymous Apr 08, 2009
    exactlt the same problem here - clothes currently stuck in the machine!
Remove the white plastic cover on the back near the bottom. To the right as you look at it their will be a black concertina pipe with a hose clip on its top edge. Undo this and pull the pipe downwards to reveal the filter. There will be a plastic ball inside (which is supposed to be there) remove this and clear out the cr*p.
Re-assemble as removal.
That should fix it
Posted on Apr 27, 2009
    New Friend:
I have an aquarius washer dryer WD440 and the on/off button is flashing and the rinse hold button also. when I unplug it and plug it back in the lights look fine but the drum is stuck, I have cleared out the filter at the back but still the same problem, please help, thanks
Posted on Aug 03, 2010
    Problem Solver:
  • 5 Answers
Some machines have a visible filter at the front, low down, if one cannot be seen then it is inside the machine under the drum, you have to lean the machine back (unplug it first!) and unscrew a clip on the rubber hose to release the plastic filter, you may find some coins in there, good luck!
Posted on Oct 23, 2008
  • 38 Answers
You will find your filter is blocked
Posted on Jul 26, 2007
    New Friend:
Same here help
Posted on Jul 10, 2013
Open the top and the grey thing to the right houses the filter towards the back.
Posted on Nov 02, 2008
But where is the filter there appears not to be one!
Posted on Oct 22, 2008
4 Suggested Answers
SOURCE:
  • 172 Answers
SOURCE: AQUARIUS HOTPOINT WD440
How many times does it flash.
it still sounds like you have an obstruction in something.
Posted on May 10, 2008
SOURCE: my hotpoint aquarius wd440 has flashing lights
First of all try cleaning the filter inside the back as described by others if this does not work there is a filter in the top. how you clean this is quite easy. all you do is remove the top of the machine by undoing the 2 screws at the back then pull top top backwards when you have removed the top you well see a large metal casing on the left if you are looking from the the back of the machine the filter is in there to remove the casing you pull the small pipe off then undo 5 star headed screws then gently pull the casing off noteing that there is a large pipe at the front when you have remover the casing you will see the filter (the small pipe you removed at the start fits on this filter) clean the filter then put it all back together.
Posted on May 17, 2009
SOURCE: hotpoint aquarius wd440. Flashing lights
press and hold on off button till the display panel lights up.Then press and hold the on/off button and the start /cancel button together.You will now reset the washing machine settings.And just pick your cycle again
Posted on Sep 01, 2012
Hotpoint aquarius wd440. Flashing lights
Oct 04, 2009 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius wd440 washer/dryer wont pump out water HELP!
Try unplugging the unit and plug it back in. This may reset the controls.
Jun 02, 2009 | Hotpoint Aquarius WD640 Front Load...
Hotpoint washer dryer lights flashing
Check first the thermal fuse.
Test heating element to ensure is not grounded, and staying always on. Test the fan and ventilation system.
If you find no fault in there , then test the timer control board.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Apr 23, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
Hotpoint washer/dryer aqaurius stopd mid cycle with message F-01
f01 is a motor short circuit. you will probably need a new one and maybe the circuit board that powers it if all the lights went out unless the fuse is gone.
Jan 28, 2009 | Hotpoint Aquarius WD63 Front Load...
Hotpoint wd440 flashing dryer heat button and onoff button !
I had to have a tech come out for the same problem two weeks ago. They had to clean the lint collector which you cannot get to on your own. He said now that this has been done everytime I use the machine, take the clothes out and then run a rinse spin cycle.
Aug 04, 2008 | Hotpoint Aquarius WD63 Front Load...
u might have a blockage in the drainpipe. hope it helps. good luck!
Jun 16, 2008 | Hotpoint Aquarius WD640 Front Load...
May 09, 2008 | Hotpoint Aquarius WD640 Front Load...
Aquarius Hotpoint WD440. 1400 Spin
The next step should be the pump out. If it is not pumping check your pump filter for obstructions. Check the drain hose and also your drain in the wall. If all are clear you may have a bad pump. You should have an error code coming up when the machine stops also, please let me know what it is. Thanks and I hope I can FixYa.
Mike
Hotpoint Aquarius WD420 5+5Kg
The water level vacuum switch are not working , check hose might lose.
Dec 31, 2007 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
3,253 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
Eric Taylor
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
