Question about Compaq Presario Notebook
Computer shut down
I have a compaq presario m2000, while working on it, it just shut down. I reset battery. No good. Unplugged power adapter and plugged back in and now when I hook cord into computer a spark shoots where adapter plugs in and I still have no power and to get the power cord to work again I have to unplug from wall socket and plug in again.
    Sergeant:
    Champion:
  • 318 Answers
The sparking has probably caused your circuit protection inside the AC adapter to turn off the current.
Also, when you are plugging an adapter in,,do not have it plugged into the wall power outlet when plugging into the laptop,,,plug into the laptop first and then plug into the wall.
Posted on Jan 30, 2009
Any solutions to my notebook problems
The first thing to always try is resetting your PC. With a laptop, you must unplug it and remove the battery. While the laptop is unplugged and the battery removed, hold down the power button for a minimum of 30 seconds. This will reset the PC. Plug it back in and see if it works now. Always try to reset the PC first, for many different problems.
May 31, 2014 | Compaq Presario Notebook
Compaq Presario M2000 stopped turning on
If there is no power going to the laptop then disconnect battery and hold the reset button in for 30 seconds, then try it again. Sometimes the memory can be damaged which can cause the laptop not to boot..?
Feb 08, 2013 | Compaq Presario M2000 Notebook
Compaq M2000 turns on using charged laptop battery but doesn't charge or turn on when using power adaptor, with or without the laptop battery
1) The AC adapter should ALWAYS be plugged into the laptop FIRST, then plugged into AC power. If not, this could create a voltage spike.
2) Let's look at the DC Power Jack, for the Compaq Presario M2000 series of Notebook PC's,
http://www.notebookparts.com/products/description.php?II=9741
The DC Power Jack is mounted to a removable circuit board.
Enlarging the view of the jack, shows us there is an Inductor.
The small 'can' standing up on the power board. This chipset could have gone south. (Bad)
How to know? Replace it, or dig out your dual trace oscilloscope. See if the Inductor works.
Could also just be cracked solder joints, of the DC Power Jack, TO that small circuit board. Solution would be to resolder it/them.
[ I WOULD however, search for a BETTER price, than listed in the link above, IF available ]
DC Power Jack is in good shape, soldered tight to the motherboard, and ruled out as the problem?
(Since you know the AC adapter is good)
Then the problem would be the Inductor on that power board, or power correcting chipset.
What one is it? Dunno.
DO KNOW is has J leads on the bottom.
CAN give examples, and perhaps you can identify using them.
1) https://docs.google.com/viewer?a=v&q=cache:oER5NNz8cwcJ:www.fairchildsemi.com/ds/FD/FDS6675BZ.pdf+Fairchild+FDS6675BZ&hl=en&pid=bl&srcid=ADGEEShOhWPjm_M-ROHme4iEMrztCTOd-28jNiy1hVLQQh_VOyv8zcXEVDB_iTQA6MuZO88UmRkDgjyW9j4CP2aIJ-4DS-h6JNM3lvxldeApQeecmz_DADCw1s7tmNLxfPknqX14SZP6&sig=AHIEtbS_rYUAeo_8rB9YHkW05ZjLqeH4Jg
2) http://www.utsource.net/ic-datasheet/KB926QFB1-1829416.html
Service Manual, (Free), for Compaq Presario M2000 series of Notebook PC's,
(Remember, follow Anti-Static Precautions. USE an ESD wrist strap, and connect it's alligator clip to a good ground source),
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-compaqhp
Drop down to the line that begins with - Compaq Presario 1100.
(1100 in blue)
Scroll over, click on M2000. (In blue)
(Ignore if you are aware of the following;
PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the file name { M2000 }, it may take up to 30 seconds, before the first page comes up )
Compaq Presario M2000 series of Notebook PC's, disassembly guide,
http://www.insidemylaptop.com/take-apart-compaq-presario-m2000-notebook/
Regards,
joecoolvette
May 12, 2012 | Compaq Presario M2000 Notebook
COMPAQ Presario *v6000?*
Hi there.
Reset the surge protector if you have one, or unplug it and leave it unplugged for a couple of hours, then try again.
Post back with the results please
Good luck and thanks for using Fixya!!
Feb 27, 2009 | Compaq Presario S6300NX PC Desktop
Will not power up
FirewallAvat: Your problem is likely because your battery is dead and the adapter isn't charging it. This may be due to broken connections in the cable from the adapter. Flexing often causes the wire inside to break near the plug. Generic replacement adapters are available, or the wire can be cut back a bit and a suitable replacement soldered on. The cause might also be broken solder connections on the main board at the power jack, This is common from stress due to the power plug flexing. It is usually possible to open the computer and resolder these connections, although sometimes there's too much damage from arcing before the connection fails entirely.
DocBrown: Does the power LED on your computer come on when you connect the adapter? If not, try the adapter in another outlet anyway. Sometimes one outlet in a strip can go bad. Check the output of the adapter with a voltmeter. If it's bad, replace it or try repairing it as noted above. If the adapter is good but the light isn't on, you might have the bad power jack as well.
Nov 08, 2008 | Compaq Presario M2000 Notebook
Compaq presario M2000 power cord won't charge my laptop
Check that your power adapter is working fine it may be that the power cable is broken somewhere between the adapter and the laptop. You could try another charger / adapter.
Jul 15, 2008 | Compaq Presario M2000 Notebook
Computer wont come on
well, sounds like your power cord took a dump on you check and make sure power cord light is working first i would suggest
takeing up to office depo or computer store or maybe some one you has a lap like your try the power cord on it and see if it boots up that computer or takea differnt power cord and try reboot it they sale altn. power cords for laptops (cheaper in ebay ,ubid or just type in power cords in your search engine ). i hope this helps lala linda
Jun 03, 2008 | Compaq Presario M2000 Notebook
Presario M2000
i need intel presario m2000
May 08, 2008 | Compaq Presario M2000 Notebook
Dead laptop
Check the ac adapter is the proper one for that laptop. Check the power jack is not damaged or loose. let laptop site without battery or power for a few hours. remove battery and retry power. try another ac adapter if that doesn't work, you may have a reset button but not likely to solve the problem. sounds like motherboard is damaged, or something blew.
Aug 27, 2007 | Compaq Presario M2000 Notebook
Compaq Presario Notebook Logo
164 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
