Question about GE SCA2001FSS Advantium Electric Single Oven
SCA2001FSS Advantium oven control panel?
Control panel only has a blinking underscore in readout, no buttons working. I have flipped the circuit breaker as well as plug/unplugged it twice, to no avail. HELP Please!!!
  • 1314 Answers
SOURCE: Wall Oven No Power
yes the oven thermal fuse blew when the fan went off its also called a tco switch if you pull out the oven and take the top off there will be a tech sheet there that will give the location of the tco some are on top some are on back this can also happen if the oven is too tight in the cabinet not enough room around it to let the heat dissipate its a round metal disc with two wires on it
Posted on Jan 30, 2008
  • 1543 Answers
SOURCE: GE Advantium Microwave oven SCB2000CBB 03 LZ90Z940K
Sounds like the door monitor switch, which would take out the internal ceramic fuse. I'd replace those two plus the primary and secondary door safety interlock switches.
Posted on Sep 19, 2008
  • 68 Answers
SOURCE: jrp24bow3bb electric double oven control panel.
Hi rhonm,
You should have found a connection diagram in the top of the oven. If you didn't, call GE at the following number and they will send you one. 1-800-626-2005
It would be very difficult for any one to make a recommendation without seeing the oven or part. Are there one or two gray wires? My first guess is that they sent you the wrong part. See photo for typical double oven ERC.
Posted on Dec 07, 2008
Sea Breeze
  • 4655 Answers
SOURCE: GE Profile JT952 Touch Pad Button Issue
Try this link
Posted on Mar 28, 2009
SOURCE: ge profile advantium 120, scb1001 oven, display panel out
My GE Profile Advantium120 interior lighting it out .What do i do to replace these bulbs.
Posted on Apr 06, 2009
The control panel on my oven doesn't seem to be working. I pressing COOKING MODE for 5 seconds and nothing happens. The display just blinks once in a while.
In the power panel on your house. There are two circuit breakers with their handles joined.One of these breakers has tripped internally which will stop the heating elements but not the control panel or oven light since they work on 120 volts. Reset the breaker or replace it.
Feb 02, 2016 | Bosch Ovens
F24 shows on readout and oven shuts off
The F24 fault code is caused by a closed/stuck/shorted contact on the control panel for more than 60 seconds, such has someone leaning against the controls or objects hanging in front of the controls.
Solution: Touch OVEN OFF, or turn power OFF at the circuit breakers, wait 3 minutes and then turn it back on. If the condition persists the touchpad/control panel will likely need to be replaced. Turn the power off in order to stop the beeping.
Jan 23, 2011 | Thermador SEC272BPSS Electric Double Oven
The lock will not release after cleaning
This is GE's trouble shooting advise:
Range - Oven Door Won't Unlock After Self Clean
The Oven Door has been Locked Accidentally:
  • If no food or utensils are in oven, put it into a short self-clean cycle (1-2 hours).
  • If there is food in the oven, let the oven cool to room temperature and try to unlatch the door.
  • With electronic ranges there is a small chance that turning the circuit breaker off for a few minutes and turning it back on can release the door. latch to the "off"
  • Note: Do not force the latch at anytime!
Door Will Not Unlock After Cleaning:
On models with mechanical latches:
  • Once the oven is cool after a self-clean cycle (approximately 30-90 minutes), slide the latch over to the left.(Some older models have a latch release button that must be pushed in while sliding the latch over.)
Note: Some models with oven Set and Temperature knobs must have those knobs set in the Clean position before the latch can be moved to the left. If your door won't unlock, try turning those knobs back to Clean, then slide the latch over.
If the above suggestions do not work try the following to unlock your door:
  1. Disconnect power to range for 30 seconds.
  2. Reconnect power and see if door will unlatch.
  3. If door does not unlatch, and you do have food in the oven, wait for oven to cool completely and try again. If it still will not open you will need service.
  4. If door does not unlatch, and you do not have food in the oven, set the oven up to clean for 1-2 hours.
  5. Wait approximately 30 minutes and try to unlock the door.
  6. If the door unlocks, the control has reset itself and there should not be any other problems.
  7. If the door will not unlock or if you would like to schedule a service appointment, please contact GE Consumer Service at 1-800-432-2737 or schedule a service appointment on-line.
Note: Under no circumstances should you ever force the door or latch open.
May 17, 2010 | GE SCA2001FSS Advantium Electric Single...
My oven door lock is in the out position. Oven door won't shut
Try shutting off circuit breaker for a few minutes to let control module to power down, then turn breaker back on. This may reset the control board back to factory default and retract the lock servo. If this doesn't work then a service tech will be needed.
Aug 01, 2009 | GE Profile JTP56 Electric Double Oven
Whirlpool wall oven stopped working after power outage
Ouch...sounds like the control module is blown. Thats the electronic timer. I've known this happen on several occasions. Bad luck!
Jun 24, 2009 | Whirlpool RBS305PD Electric Single Oven
GE Advantium SCA1000DBB03 handle replacement
open door look at side there some are some screws remove them the outer door part will come off now don t be afraid to use screwdriver to help take it off good luck later
Apr 01, 2009 | GE SCA2001FSS Advantium Electric Single...
How to replace lower halogen light assembly, also, replacing turntable shaft
item 1474 is the turntable shaft and is GE # WB02X10624
You should be able to remove item 1476 and lift out the shaft to replace it..then reinstall item 1476 to lock it in place, Hope this helps ...
Sep 12, 2008 | GE SCA2001FSS Advantium Electric Single...
Whirlpool Double oven control panel
A lot of people seem to have ran into this problem. I had no luck finding a solution to this problem anywhere on the internet. I finally fixed this problem by replacing the control board. Wanted to put this info out here for others. The part swaps out fairly easy for all of you considering the fix yourself. Sears direct had the cheapest price.
Jul 08, 2008 | Whirlpool RBD305PDS Electric Double Oven
F3 Error
This is due to a Defective control board..You have to get it replaced..
Oct 15, 2007 | GE Profile Advantium SCB2001KSS Stainless...
GE SCA2001FSS Advantium Electric Single Oven Logo
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
