Question about Linksys Wireless-G Broadband Router
No power my linksys wireless-g broadband router has no power it doesn't work?plssss. help me.....
  • Mark Egan May 11, 2010
    Is it plugged into a power source? Is the power source known to be "live"?
    Is the power source plugged into the back of the router? Push on it or connect/reconnect to make sure.
    Problem Solver:
  • 13 Answers
I would replace the power adapter to the unit if you have made sure all the power connections are secure.
Posted on Feb 10, 2009
How can I get the router IP of my Linksys 2.4GHz broadband router?
The Linksys G router gives you both wired and wireless connections over a broadband Internet connect to create a local area network. The Linksys router is compatible with wireless G and B devices, through the 2.4-GHz wireless band. The wireless speed is at 54 megabytes per second and you can get 100 megabytes per second with a wired connection. You have to set up the wireless configuration on the Linksys before using it on your network.
Plug the router's power cable into an electrical outlet. Attach an Ethernet cable into the Internet port on the back of the router. Connect the other end into your broadband modem. Connect your computer to the Linksys G using another Ethernet cable. This Ethernet cable can go into any of the wired router ports. Open your Internet browser. Type "192.168.1.1" in the address bar and hit "Enter." This is your router's IP address and the home of its Web configuration page. Click "Wireless." Click "Manual." Alter your SSID, also known as your network name. You can change this name to any value that you want. You can also change the wireless channel if you are in an area with many wireless connections that may interfere. Click "Save Changes." Click "Wireless Security." Choose an encryption method to encrypt your wireless transmissions. WPA or WPA2 are common security protocols you can use in wireless networks. Input a network key, also known as the network password. Click "Save Changes."
Setting Up WPA Wireless Security on a Linksys Wireless Router http://www6.nohold.net/Cisco2/ukp.aspx?pid=80&vw=1&articleid=3696 Wireless G-Broadband Router support http://homesupport.cisco.com/en-us/wireless/lbc/WRT54G b> b> Changing the Wireless Network's Name (SSID) on a Linksys Router http://www6.nohold.net/Cisco2/ukp.aspx?pid=80&vw=1&articleid=4037
Mar 27, 2013 | Linksys Wireless-G Broadband Router
How can we set a password to the linksys wireless-g boadband router
Power On your router after after Connecting your adapter, turn on the router, wait for few seconds and then connect the router to your PC's Lan Card Port from one of the ethernet ports (not the labelled internet port). Open your internet browser and type in http://192.168.0.1 (if it doesn't work, use http://192.168.1.1) and press enter to open the page, once it's loaded, you'll be presented with the login page, in the USERNAME box, type in admin and leave PASSWORD blank (empty) and then press Enter. Once you are logged in, go to the admin section and change your password. If Admin panel isn't available, you can look for configure or change password.
If the above method doesn't work, click this LINK and follow the instructions. Let me know if you need further help.
Good Luck.
Thanks for using FixYa,
Aug 31, 2011 | Linksys Wireless-G Broadband Router
WIFI not working with Linksys wireless-g broadband router/Comcast
Unplugging the wireless router and connecting it again should not have altered the wireless connection/configuration. You have connected the cables correctly because the Internet works when you connect a LAN cable to the router.
The Linksys wireless configuration or the wireless card configuration in the computer was changed it to lose the wireless connection. The wireless card configuration needs to be changed to match the wireless router's settings or change the Linksys with new configuration settings and configure the wireless card accordingly.
To secure your router with a login password and wireless security, please follow my instructions - click on this link :-
http://www.fixya.com/support/r3559128-wireless_router_security
Should you need further assistance, please leave me a comment.
Dec 25, 2009 | Linksys Wireless-G Broadband Router
How can i get Linksys Wireless-G Broadband Router go wireless?
The Linksys Wireless-G is ALREADY wireless. Do you have any computers with 802.11g network cards? Laptops usually have these. Make sure you have properly configured the router, because if it is NOT correctly done then things may not work too well.
Nov 02, 2009 | Linksys Wireless-G Broadband Router
Blinking power light - router not working properly
Blinking power light on the Linksys routers indicate 2 things. 1st is firmware problem, 2nd is the worst one which is defective router. You can still revive it if you can reload the firmware. If not, it's a dead one and you need to purchase a new one. And man, your router is a very old one. You must switch to wireless G router, its 5 times faster than your wireless B and it only cost 30 or 40 bucks
May 09, 2009 | Linksys BEFW11S4 Wireless-B Broadband...
Username password
Perform a factory reset. With a pen hold in the reset button next t the power jack whilst you plug the power back in. Wait for 10 seconds, that should get you back to a factory setting, log back in 192.168.1.1, User: (blank) Password: admin
Mar 31, 2009 | Linksys BEFW11S4 Wireless-B Broadband...
Linksys Wireless G Router Set up
I ended up loading the router setup cd onto another laptop, and it worked fine. I still don't know why the first laptop had the error code, but they now both, work perfectly fine. Thanks, anyway.
Sep 06, 2008 | D-Link DI 514 Wireless Router (DI-514)
Linksys Wireless-G BroadBand Router
Who is your ISP (Internet Service Provider)?
If you're using a Cable provider, do the ff. steps. (For Linksys router)
1. Launch Internet Explorer and type http://192.168.1.1
2. It will prompt you for username and password. Leave it blank on username and type admin for the password.
3. Under SETUP tab, click the sub-tab MAC Address Clone. The click the button Clone My PC's MAC. Then click on Save Settings.
4. Unplug the power to the modem and the router for 30 secs. After that, power on the modem first, wait for all lights to go solid then power on the router. Check if the internet works.
Hope this helps.
Jul 19, 2008 | Linksys Wireless-G Broadband Router
Linksys Wireless-G Broadband Router Logo
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
