Question about Acer Aspire 5315 Notebook
My Acer 5315(vista) keep loosing wireless connection help please
My laptop is less than a 1 year old, it was ok but about three weeks ago it started loosing wireless connection, how ever i`ve change location and i`m using another network, could this be the problem? Sometimes it might connect and stay for 30mins then it cut off the connection again. Is there any solution to this? I`ll appriciate if any one can help.
  • 1 more comment
  • CuZ_69 Feb 06, 2009
    Hey Dev_Null
    Thannks for you`re effort trying to help me but it waz something to do with eNet Management profile settings, now i`ve sort it out, once again... cheers!
  • hoagy30 Feb 18, 2009
    My Wifi works fine in the AM after being closed for the night. Ok for an hour or so, but then it stops working. I fI shut it doen and remove the battery, and reinstall the abttery, and start it back up, the wifi comes back---always to some low powered router, and not my 100 % powered one.I can get i back on track to mune, but the after the hour is up, my wifi dies. I can buy another cad for about $20.00, but where do I go to reinstall it. Nothing in any manual I can find will tell me that. HELP!!!
    Mary R.
  • Devin Gunther
    Devin Gunther May 11, 2010
    The network you were using before. has that connection information been flushed from your prefered network list?
My laptop wont connect to my wifi just started a few weeks agto
Acer Wireless Not Working? - Easy Fix by Drivers.com
www.drivers.com/update/drivers-news/acer-wireless-not-working/
Jun 17, 2014 - In some Acer models you can use a combination of keys on the keyboard to ..... My acer aspire wont connect with wifi, it say windows cant connect.... I've just had a similar problem with my Acer Aspire laptop (wireless .... It is startedto happen just a month ago before it was ok I am using this since 6 months.
Acer notebook won't access the internet [Solved] - CCM
ccm.net > Forum > Network
Sep 17, 2014 - My Acer Aspire one series notebook says it's connected to my wireless... I know for a fact that my wireless is working fine, as my normal laptop is accessing it and ... it a while ago, sometime in Autumn 2010) but now it just won't work. ... 1) First make sure that you have configured the WiFi settings correctly. Can't get Aspire One D255 to connect to wifi [Solved] - CCM
Jan 15, 2015
Can't Access Internet-Wireless Working! [Solved] - CCM.net
Dec 19, 2012
My laptop Browsers won't connect to the web [Solved] - CCM
Oct 10, 2012
More results from ccm.net
wifi wont connect all of a sudden - Aspire - Laptop Tech ...
Dec 14, 2015 | Acer Computers & Internet
How do i switch my acer aspire laptop 5315-2513 to wireless?
At the top of your key board right below the power button, there is a row of hotkeys the far left one is the wireless button. Press that and the wireless should be turned on.
For example, F10 is the switch for your wireless, you may press Fn + F10 and you will see a pop-up balloon saying that your wireless is now enabled.
Dec 01, 2009 | Acer Aspire 5315 Notebook
Acer aspire 9410, cannot connect to the internet using dial-up
You have two different devices here. A modem and a wireless network adapter. Two totally different devices. It sounds like the modem quit working but the wireless network adapter still functions. I'm assuming that the modem is built it. If you absolutely have to have it you could buy a PCMCIA modem if your laptop has a PCMCIA slot to plug it into. You could also have a corrupted modem driver.
Oct 01, 2009 | Acer Aspire One PC Notebook
Acer 5315 lost driver and hardware
The drivers you need are here
ftp://ftp.work.acer-euro.com/notebook/aspire_5315/vista/
Aug 03, 2009 | Acer Aspire 5315 Notebook
Acer 6930 wireless won't connect anymore.
Hi acording your describle, you need do
1) please check the bios first, to set wireless to enable
2) check windows right buttom bar is there a wireless icon show there and click to see any detect wireless signal, if nothing to detect
3) check or compare to other laptop wireless configuration, check any incorrect setting.
4) if all sense ok, you need check the wireless card and wireless antenna wire connection, open a samll cover at back of laptop, there is a MINI PCI slot with a wireless card, take out and clean the card pins then put back.
5) still trouble please change another wireless card (same model)
it should be fix.
hope help you to fix it, please take a rating le me know how much helped you, thanks. for any question in any time please !
May 17, 2009 | Acer Aspire 6930-6455 Notebook PC
Wireless connection problem
hello.i have a problem with my laptop (acer ASPIRE 5315).when i install XP sp2 i get a problem with my wireless connection where i cant connect via its wireless!!!it asks me to install broadcom 802.11g.it happens just with windows xp but doesn't happen with Vista system.I need your help please
Apr 14, 2009 | Acer Aspire 5315 Notebook
How to connect to a wireless network in Windows Vista acer 5315 - router name is show but not connect help me plzzzzzzzzzzzzzzzz
0. Check if your wifi module is turned on by switching on a hardware switch on a border or back of your laptop.
1. Click once on right bottom corner on icon with two monitors.
2. Choose connect to network.
3. Choose one of access points
4. Enter password
Mar 21, 2009 | Acer Aspire 5100 Notebook
Laptop not connecting to wireless internet.
Right click on the my network icon go to properties and click on make new connection, allow the wizard to walk you through the process from start to finish and you should be ok. Just follow the prompts.
Feb 20, 2009 | Acer Aspire 5315 Notebook
Acer Aspire 5315 with Windows Vista Home Basic will not connect wirelessly to our router but will connect to others.
hi i have just bought a Acer Aspire 5315 on vista i wanted to put it back to factory reset but it seems that they have taken out the back up to do this can i get a disc from any were or any help i would be most greatful thanks dee
Jan 07, 2008 | Acer Aspire 5500 5570-2609 Laptop
Acer Aspire 5315 Notebook Logo
184 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
