Question about HP Compaq Presario V2000 Notebook
Won't power up.
Output is good from AC power supply and with or without the battery installed I get nothing when I try to powerup the laptop. No lights ,whirrs, clicks or other signs of life at all.
Check or replace the circular bios battery. Its a small round disc type about the size of a quarter.
Posted on Jul 26, 2007
My Acer KAV60 laptop won't turn on. When I push the power botton, it blinks green once then nothing.
Has the laptop been damaged? Dropped? Same on battery? Remove battery, try AC only. Try another cord/charger with the EXACT same power specs. Reseat Memory mods. Test the DC volt output, at the laptop plug in, with a multimeter. Power issues are difficult to diagnose long distance.
Jan 31, 2013 | Acer Aspire One PC Notebook
My computer won't turn on and when I plug it in the charging light won't come on
Please check the adpter output voltage with multimeter in DC mode.
If output voltage is good then check any contact problem of the power jack with laptop dc jack for proper contact.
Try to power on with only ac power supply by removing the battery.
Jun 14, 2011 | Computers & Internet
Installed Vista SP 2 abd now won't powerup
Reset yout bios,
If you using a PC take of the battery from the motherboard
If you are using a notebook, pull out the battery and the ac power
push the power button for like 30 seconds
Good luck
Nov 28, 2009 | HP Pavilion dv9000z Notebook
Lights come on but no fans or powerup
Please follow the steps below.
1. Please removed the battery and unplugged the power supply.
2. Held down the power button for 45 seconds.
3. After 45 seconds reinstalled the battery and the power supply and pushed the power button and if it works then you don't need to replace your motherboard.
4. Else try it couple of times or up to five times before it worked if worst comes to worst.
Thanks
Aug 26, 2009 | Acer Aspire 5050-3242 Notebook
Power button
hello
Follow the instructions.
  1. Take out the battery and the Ac power. Keep the power button pressed till all residue power is radiated.
  2. now connect the Ac power without the battery and try to start the system. Hope you have fixed the supply with proper soldering.
  3. if the system gets start then there is no problem with your system hardware is OK.
  4. now try battery. charge it fully and this will tell you if your battery is good.
  5. if it works with power supply but not with battery then there are two possibilities.
  • battery gone
  • charging module in the mother boad malfunctioning.
Thank you
Aug 16, 2009 | Computers & Internet
Travelmate dont switch on when i connect my adapter. even no led glows when the adapter connected. tried a new adapter still not working send me ur valuable suggestions to sheku1984@gmail.com
Remove your pc battery and try connecting directly to AC supply via your adapter. If you have a multimeter, you could measure your adapter's potential difference to be sure of the right voltage output ok. If nothing happened here, then you should open the pc's RAM compartment and remove the RAM(s). Re-install them properly and test one after another. You could also get a fully charged compatible battery and test alone, ie, without AC this time. If all these didn't work, then the culprit is the power unit. Good luck.
Jun 10, 2009 | Acer TravelMate 2300 Notebook
Laptop Dead, Wont power up
its power button doe not work please change it as soon as possible
Apr 14, 2009 | Acer Extensa 5420-5687 Notebook
AC/Battery powerup
Well I think if you a tester test the battery if it is fine. It is not absolute sure that the battery is fine because it shows it is fine from the laptop.
If the battery is fine then there is something wrong at the connection of the battery with the motherboard.
Jan 28, 2008 | Compaq Presario 2170US Notebook
Oshiba Satellite A55-106
Can be because power supply is not correct supply or give incorrect supply voltage causing battery to drain or not charge fully,battery can be caput aswell, some laptops doesn't start if battery isn't conditioned properly. JJ
Sep 15, 2007 | Toshiba Satellite Pro 6000 Notebook
HP Compaq Presario V2000 Notebook Logo
49 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
