Question about Motorola Mobility RAZR V3
Phone does not ring or vibrate & cannot listen to music
My Razr does not ring or vibrate at all. If I try to change the ringtone or even listen to my music, I get a system error message "Because the audio device is busy, this file could not be played". There is nothing else playing. Any ideas?
  • 1 more comment
  • Marla Morris Jan 29, 2009
    Oddly enough, it did work or it was a HUGE coincidence! I took the battery off while the phone was turned on at least 10 times & when it restarted, the problem still existed. After my 1 yr old threw it across the room and I repeated the process... it worked! Now I cannot condone violence against electronics, but I guess I good smack did the trick for me!
  • Deb Ch Mar 08, 2009
    I have the same problem which is why I have been looking for assistance. I found I had 13 missed calls and thought I must have put the phone on silent by accident, but I haven't. I have checked all settings and can't see what the problem is.
  • Anonymous Mar 15, 2009
    i think i dropped my phone on the floor, and since then it is not ringing. I cna change the ring styles fine but still can't hear it ringing. I tried the set up as well. No luck.
Throw the phone on the floor and step on it. or simply throw it against the wall it worked for me =)
Posted on Jan 29, 2009
My iPhone 5c won't ring
Does the phone plays music without any problem? If you play music to hear it on the loud speaker, and there is no sound, then you probably have a hardware failure, (bad speaker). But if you get to listen to the music, then try this next steps to see if it can be fix.
  • From the iPhone's home screen, tap the Settings app.
  • In Settings, tap Sounds in the third group of options.
  • In Sounds, swipe down to the Sounds and Vibration Patterns section. In that section, look forRingtone. That displays what you have set as your current iPhone ringtone. Tap it to change that.
  • This menu shows you the list of all the ringtones available on your iPhone.
    To get new ringtones, tap the Store button in the top right corner. This will take you to the ringtone section of the iTunes Store where you can stock up on new ringtones.
  • If you choose not to buy new ringtones, but instead use the ones loaded on your phone, the first set of options in the Ringtones section are ones that you bought from the iTunes Store or created using another app and have synced to your iPhone. The ones below the divider came pre-installed on the iPhone.
    Alert Tones, farther down the screen, aren't ringtones exactly. They're alert sounds normally used for alarms and other notifications, but they can be used as ringtones, too.
  • When you tap on a ringtone, it will play so you can preview it and decide if it's what you want. When you've chosen the ringtone you want to use as your default, make sure it has the checkmark next to it. Then tap the Sounds button in the top left corner or click the Home button to go back to the home screen. Your choice is saved automatically.
  • Now, whenever a call comes in, the ringtone you just selected will play (unless you've assigned individual ringtones to callers, that is. If you have, those ringtones take precedence). Just remember to listen for that sound, and not a ringing phone, so you don't miss any calls.
  • Mar 13, 2014 | Cell Phones
    SET A RINGTONE & PLAY MUSIC
    u need to change the phone sound ic or change the phone speaker.
    Feb 13, 2012 | Samsung B3310 Cell Phone
    The User Manual does not explain how to change the ring tone, can you help please?
    Hi gary468780 There are two ways by which you can change your samsung mobile phone ringtone . For changing ringtone of your cell use one of the following methods : 1} Go to Music option from main menu then you will get music library files to play and listen music if you like any song then you can set it as your ring tone by selecting option menu and then select set as Ring tone 2} Go to setting option from main menu and then select profile setting and then edit the profile setting after editing profile you will get another menu from which select Vice call ringtone option and then change ring tone and save it
    Jun 06, 2011 | Samsung GTC3300 Cell Phone
    Cannot get Ringtones!
    Go to settings, - Ring Styles, - select style - change it to loud, go to detail of loud and select ring volume and increase it to 7.
    Jan 09, 2009 | Motorola Mobility RAZR V3
    My razr v3 won't use dowloaded ringtones
    you should have the phone debrand by flashing a new firmware on the phone and this would remove the block place in the phone.
    Sep 30, 2008 | Motorola Mobility RAZR V3
    Ringtones not working
    try areflash of the phone or a master reset ot clear to correct this issue
    Sep 28, 2008 | Motorola Mobility RAZR V3
    Newest razr v3 ringtones
    i know this sounds some what funny but make sure the phone is not on vibrate. because there are volume settings for the phones applications. just try that.=]
    Apr 01, 2008 | Motorola Mobility RAZR V3
    In vibrate mode, phone continues to vibrate after being answered
    The phone is in "vibe then ring" mode.
    Go to tools then ring styles using the "-" at the top center of the keypad. It will be set to vibe then ring, press "change" alter the style to vibe, vibe then ring, silent, loud or whatever you like. That is also where you find what ringtone is used for the ring.
    Oct 30, 2007 | Motorola Mobility RAZR V3
    Motorola Mobility RAZR V3 Logo
    88 people viewed this question
    Top Motorola Mobility Cell Phones Experts
    Virgil Wolter
    Level 1 Expert
    vince
    Rami Obeid
    Level 1 Expert
    Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
