Question about Cingular Wireless 8125 Smartphone
Need help to set up WiFi on 8125 smartphone
My phone wifi can connect to the internet hot spot (I don't have a router yet at home) but will never download anything. I have a laptop with the same wireless installed but even at home this laptop can connect to someone's connection and surf the net without any problem. I wonder how to set the phone to surf the internet too. I don't want to use Netmedia way or GPRS. i just want to use WiFi thanks
  • Sarah Emmanuel Oct 05, 2007
    I have a update htc. I think the different from this phone and from my laptop is the kind of network card install. Though I get the signal now but it is not that good to get the far away signal but my laptop can get the signal from my library hich is about a mile away.
    Guru:
  • 120 Answers
You may need to upgrade the htc wizard to use 102.11g networks. You can do this yourself if you follow these steps. Google a program called total commander. download and install it on your phone. Now open total commander. Listed on the very top of the folders list will be \\ -Click on \\ -then click registry (you are now in the devices registry, be careful not to change other things) - select hklm (this stands for Hkey local machine) you need to go to this location HKEY_LOCAL_MACHINE\COMM\TNETWLN1\PARMS (so you would choose comm, then scroll down to tnetwln1, then select that and scroll down to parms and select parms) then assign the follow changes to the keys listed in PARMS... Assign a value of 1 to dot11SupportedRateMask Assign a value of 8 to dot11SupportedRateMaskG Perform a soft reset (do this by holding the power button for roughly 6 seconds, until a box comes up asking you if you want to shut off the device. Turn it off, then turn it back on and the changes will go into effect) Then simply try to log on your router Peter
Posted on Oct 02, 2007
SOURCE:
What if I don’t have a smartphone? An I still access data?
The short answer is NO. You need a device capable of accessing the internet, so a smart phone, laptop, tablet, etc is required. You also need to have a device that can connect via a hot spot, so must have inbuilt wifi, or a sim card to access mobile data.
May 05, 2018 | Cell Phones
How can i connect my tablet to wifi without a house that dos not have Internet access in county wexford ireland.
Are you trying to just connect to wifi to access a local network or are you trying to access the internet? If you just want to connect to a local network, maybe to access other devices on the network, you would need a router broadcasting the network that all the devices connect to. If you are only trying to get access to the internet, consider purchasing a hot spot device. It will provide cellular type service and will broadcast a wifi signal that you can connect your tablet or other devices to for internet access. Hot spots will cost you a monthly fee for the service and you will have to purchase the device itself. Another possibility is to use your cell phone as a hot spot and tether the tablet to it. Just remember whatever data you use on your tablet will be charged to your data plan on your cell phone. On my nexus 5x phone, it's fairly easy to turn on (settings, under wireless and networks select more, select tethering and portable hotspot, turn on portable wifi hotspot, set a password if you want to). Once turned on, the phone will broadcast a signal that you can connect other devices to for internet access. Some cellular providers don't allow tethering. If that is the case with yours there are some apps that will still allow you to set up tethering such as AndroidTethering or Easy Tether. In the past, I've had some trouble connecting wirelessly using the apps and found that using USB tether options worked better for me.
Aug 11, 2017 | Tablets & eReaders
Can i somehow use my s7 galaxy as a wireless router i currently use the mobile hot spot for my computer
You can just open a WiFi hotspot (only for users that can connect to WiFi for ex.smartphones, laptops, computers with WiFi adapters etc)
Jan 30, 2017 | Galaxy Computers & Internet
Our rj45 is reading no cell. what could be wrong?
I'm not sure what do you mean by "your rj45". If it's a model of a router, maybe you mean that you can't get connected you smartphone to the router?
Are you sure SETTING of your phone is activated?
With setting activated, take your phone to a hotspot - site where you have free Internet connection.
If still can't connect it, probably the WiFi adapter circuit (well, anything like that) of your cell phone is failing. an you shouls check it with an authorized repair service.
Ok, that's my idea. Actually you can input a google search for
SMARTPHONE WON'T CONNECT TO INTERNET and you'll get sume return like these, to make an idea about issue
Why won the internet work on my Android powered smartphone
Cant connect to Wi Fi on an android phone Heres the fix Smart Mobile Phone...
How to fix the Internet on an Android smartphone Smart Mobile Phone...
Smart Phone won connect to home wifi
Aug 13, 2015 | Computers & Internet
I am trying to get wif on my samsung galaxy it tells me get guest password can you help
You would need to refer to your Belkin's instruction manual for how to set up WiFi on it. The password for any WiFi hot spot is unique to that hot spot so there is no general 'guest' password per se - it depends on how you setup the WiFi router.
WiFi routers also have a web-based interface where you can open a browser from a connected PC and manage the device. Again, the device's instruction manual will tell you how to do this.
If the router was supplied by your internet service provider you should be able to call them for help.
Jan 27, 2015 | Belkin Surf N300 Wireless N Router
How to get wifi
First you need a WiFi wireless card or an USB WiFi adapter.
This will allow you to connect to a free WiFi hot spot location such as MacDonalds, Starbucks etc.
If you want to setup your own wireless network at home the you need a wireless router and then configure the wireless card/adapter in your computer with the router's wireless settings.
SETTING UP A BROADBAND CONNECTION
First you need to decide what type of broadband andInternet service you require and these are -
1. DSL that uses your existing telephone line.
2. Cable that uses a cable service and can include a cable TV service.
3. A wireless 3G network which uses the mobile/cell phone network and can beseparate or combine with your cell phone account
Note - Combined services generally offer discount pricing and may include amodem/wireless router.
If you use a wireless router with the DSL or Cable Internet service and yourlaptop has a wireless card then you can also connect to the Internet at WiFihot spots like McDonalds, Star Bucks, the Airport etc.
If you use the wireless 3G wireless broadband service, then you can access theInternet anywhere where your ISP has 3G wireless coverage. You need to checkthe service coverage area where you need Internet service.
Once you decide what type of broadband your require, then you need to checkwith the various Internet Service providers to see if they can offer and thecost of the various plans.
Note the download limits and the associated additional costs if you exceed themonthly download limits. Once you sign up with a Internet Service provider,their documentation will include setting up instructions and/or installationCD.
Jun 10, 2012 | Computers & Internet
The my ps ask me securyti key for acccess at internet bat i don'no what is .....please you can me help?
The question seems incomplete or not clear but If you are trying to access a secured internet connection at your home or cafe through wifi connectivity, it will ask for the secured password or security key. If it is your home connection ask the person who set the internet connection, if is at a cafe, wifi spot ask the service provider. Hope i understand your question rightly.
Sep 02, 2011 | Computers & Internet
Cannot connect samsung Galaxy tab to internet
Your question is very messy. I don't understand what are you trying to say.
Connecting to Internet need WiFi (your home wifi through your router, cafe wifi hotspot, etc) or GPRS (data connect through your carrier/SIM, like 3G, 2G, HSDPA, Edge).
For WiFi, normally you'll need a security key.
For GPRS, you'll need some settings from your carrier.
_______________________________
Sent from my Galaxy Tab using Tapatalk
Sent from my Galaxy Tab using Tapatalk. FYI: We the administrators of (mygalaxytab.net) do not endorse any posts of discounted third party phone sales.
Be careful as they may be con sites and most usually .
Dec 08, 2010 | Samsung Cell Phones
What do I need to make a wifi hot spot for my lap
In order to create an effective Wi-FI hotspot in your home or place of business you will need the following:
1.) A broadband internet connection, such as DSL or cable.
2.) A wireless router, Linksys makes a decent one but the brand is not really relevant for our purposes.
3.) Your laptop must have a wireless adapter on it. If it did not come with one, you can purchase one that will plug in to a USB port.
4.) That should do it, though configuring one can be tricky if you've never done it before. Post if you need some more help with it.
Oct 10, 2009 | Computers & Internet
Internet
I had a smartphone called O2 XDAIIS and the same thing occured. The problem is the Wifi that it is connected to is not allowing you to go on to the internet. Or the wifi router is not suitable for your smartphone. At least there are settings that diabled you from the internet. 1. Check your smartphone settings 2. Check you router settings Hope this helps!
Aug 30, 2007 | i-mate K-jam Smartphone
Cingular Wireless 8125 Smartphone Logo
434 people viewed this question
Top Cingular Wireless Computers & Internet Experts
Alun Cox
k24674
Are you a Cingular Wireless Computer and Internet Expert? Answer questions, earn points and help others
